OCing lowered my score
323 4
i was fooling around with 'superstep' a program taht came with my motherboard for ocing. i increased the fsb to something like 203 or 204 just to see if their was a little difference. the cpu speed went from 3007 to 3045.
i ran 3d mark 03, with the same gpu frequencies as last time.
this is the orignal test
http://service.futuremark.com/orb/pr...jectId=4553534
and my second test
http://service.futuremark.com/orb/pr...jectId=4592540
my score dropped, and so did the cpu score, by almost 60 points.
does anyone know why? maybe be cause of my slow ram, instead of 200:166, now its 204;166?
1 - 5 of 5 Posts
DOH! I have to log in??
Just don't mess with the ocing programs. They do NOT do you any good at all. System instability, jacking up of HDD, re-installing of Windows... all the pain that comes with overclocking programs for CPU.
Just don't do it, my friend.
I'd say CPU instability is the issue. Before running benchies, try running a stability program to see if the CPU is stable, if you really want to overclock.
lol ok, should i push it up to 3.1 just out of curiosity lol?
Or i should set it to 3.045 in the bios and see if theirs a diff in the 3d mark score
Go as high as you'd like, but don't forget to check for stability.
I've had some experience with one of the overclocking softwares (Clockgen), and even a small overclock caused instability for me. Just keep that in mind.
Using BIOS is the best.
ok nevermind i just had my first experience wtih the CMOS jumper
im done for now
taht is, until tommorow haha
1 - 5 of 5 Posts
