Originally Posted by Renfeld
I also have a 2600-m.mine tops out at 2570 stable.
How about this-shut off machine and clear Cmos with jumper,and set to 166 by 14 with 1.8 volt, fast write off,timings at default,T1 off. set cpu shutdown temp at 50 or 60 if aval. If it boots windows,check cpu temp first thing with sandra or equiv.then go for 166 by 15 with voltage maybe at 1.85 or so-(watch cpu temp)the 166 bus speed will keep pci speed at stock-also maybe set mem latancy at 3....what do you think ?
will try that, im new those settings i understand and have something i can try now, perfect as also i will try Xero reply as well, however i came accross this now,
i also found this on the fine print under Memory for my motherbrd, now going from left to right i have my mem stick on the right side thrid slot,i have 3 slots, so this means i should have it in the middle correct..?? based on what is said down below..??my mem stick is doubled side
DDR400-3200 Ram
a. Max memory size will be 2GB.
b. DIMM1 + DIMM2 by double side module.
c. One double side on DIMM1 + 2 single side on DIMM2 + DIMM3.
d. Don't suggest DIMM1 + DIMM3 use double side module because the driving on memory is unstable.
now i should mention that my ram stick is also silver and then fades to copper on top just above one of the rams at the bottom of the stick, is this something i should be concerned about
