I just got my K7N2 Delta2-LSR mobo.
sofar it seams like a great board but Im having a problem. I can oc using core center with np, but when I use the same settings in bios my pc eather wont post at all, or it is unstable.
so far the highest I have tryed to go in bios is 175 fsb with the ram timings it adjust's them to, and what the ram timings are at when using core center to oc(1:1/ 2.0,3,3,7)checked using cpuz
from my understanding hardware oc should be more stable than software oc, but Im getting the exact oppisite.
my comps is
above mobo with what would appear to be the b40 bios(11.4 if Im remembering correctly, possably my prob? Ive read some people have problems manual oc'ing with that bios version)
AMD Athlon xp 3000+
512mb PC2700 non eec, unbuffered Samsung ram
to test stability of my system Im running PCMark04 if it runs ok then I use SiSoft Sandra 's burn in wizard to run both cpu and memory benchmarks 10 times, then run prime95 for several hrs.
using core center to oc I can run all tests np, but when using bios to oc I never make it past PCMark04.
can any one tell me what I should try? or am I stuck using core center untill the next bios update?
my comps is
AMD Athlon xp 3000+
