1 - 12 of 12 Posts
I see alot of people suggesting to turn it off when OCing.
I understand that it drops benchmark scores by a litte, but as Cool N quiet doesn't affect my performance. At least I don't think it does. CPU throttles to 3.8ghz the moment games/video encoding begins.
So why do you yall suggest turning it off?
· Premium Member
Instability reasons. And it causes a performance loss. That split second that it takes for it to bump back up to max speed, can be noticed.
· Premium Member
I use to run it enabled 24/7. No problems at all even at 4.4GHz+ overclocks.
· Premium Member
Most suggest turning off to find max stable
I personally run Speedstepping (Intel's version) on both my cpus and have been happy with the performance
· Premium Member
For the reason you stated above. Issues with Cool N Quiet have been resolved with the PII CPUs. You can have it on without any worries.
Discussion Starter · #6 ·
Really? It bumps up to 3.8 ghz as soon as the game is booting. I understand that would effect benchmark scores, but it in the real world.......really?
Also, I guess stability is a good excuse.
I disabled cool and quiet because I honestly couldn't watch hd video with it enabled. The processor would always downclock and the framerate watching any hd video was just plain terible. So, I would say it can cause problems in that sense too as it would go to idle clocks when it coulsnt handle it. However, I think my chip was downclocking a litle too much to be honest. It went down to 800mhz.
I actually made a thread asking about this a long time ago and the general consensus was that if it didn't cause stability issues then use it. Personally I love it and don't notice a difference in speed or responsiveness.
· Premium Member
... and especially with the Thubans.
My 955 doesn't like CPU/NB @ 2600+ with CnQ enabled, but 1090 has no problem at all above that speed
· Riding on the edge
I haven't heard a good reason TO disable it, but I have seen (like you said) those that say it must be lol. I always run with it on and know of no reason it has to be disabled. Maybe it's an e-peen thing or something. If that's the case maybe they should just speed up there mouse so it feels even faster yet.
It's never been an issue for me and I don't buy into the common reason of "it causes instability" as all my OC's are 24 hr prime, 200 passes of LinX and ITB on highest setting stable.
· Premium Member
No need to disable it, period
I run my OC (sig) with CnQ
You probably did not have proper GPU acceleration enabled or GPU accelerated software
@ xd
I was watching video on mtv.com which is the only place it ocured, so posibly bad coding on their part. It didn't happen anywhere else.
1 - 12 of 12 Posts
