1 - 20 of 165 Posts
This will be a place for all of use who have fallen in love with OCN and have taken OCN love to the next stage that we have implemented the OCN flame logo into our builds and mods. For sure We are not the first ones to use the OCN flame in our builds but would like to make a club that all of us can join under one roof and share experience with making and implementing the OCN flame logo in our builds
How to join:
Print, cut, 3D print, spray on,stick, just use a OCN flame logo in any form in your build and post a picture of the OCN flame logo on your build and the name of your mod, and a link to a build log if you have it bellow and you will be added top the club.
For any one that want's to join and dose not have a logo on the mod at the time, or the logo is under construction, you will be added to the club and given a week's time to post a picture with the intent of making the OCN logo or a sketch up 3D model or in best case the finished thing.
Signature:
[URL=http://www.overclock.net/t/1540681/ocn-4-life-club]:clock: [b]OCN 4 Life Club[/b]:clock:[/URL]
Members
Member counter:
12
out of 30 till the start of the LOTM Competition (Logo Of The Month)
https://docs.google.com/spreadsheets/d/1_enDO_a0rNZ5vGknlRX5tbz3lhtSn8CcNheXdJ1RH8I/pubhtml?widget=true&headers=false
Discussion Starter · #2 ·
Let me kick things of with my interpretation of the OCN logo use, it is still under constructions but its getting there, it will be a part of my custom water cooling loop an water will flow around the logo on its way back to the radiator. For more details you can see my build log: http://www.overclock.net/t/1536880/build-log-raised-from-the-dead
It is an honor to post and be a part of the OCN 4 Life Club. I added the OCN flame logo to the side of my current build (Dark Side) case mod. I took a Jpeg of the flame logo online and printed it to the scale I needed. I used that copy to make a template that I could use to cut out of 6mm acrylic. After I had it cut, filed and polished I wrapped it in carbon fiber film. Its final resting place is mounted on the side panel; just in front of the 92mm fan. White Led strips were added to the fan in order to backlight the OCN Flame.
The First Few Stages of The OCN Flame:
There are a lot of reason I added the OCN flame logo to my build. Up until about 4 months ago I had been away from the custom PC market for quite sometime. Getting back into case modding, the OCN members welcomed me and have helped out tons when needed. OCN is a great site with awesome members. You can now start to see why I've added a bit of OverClock to my build. This club is a place where we can share our OCN related mods as well as our appreciation for everything this site has done for us.
OCN's Finished Mount:
((Dark Side Case Mod Build Log)Dark Side Case Mod Build Log)
· AMD s939 LVL 99+
I'll join this club!
YEARS ago, I had a custom laser etched flame design made for my Antec 902 side window. AMD logo embedded in flames, with a hidden OCN logo within. Not too many have noticed.
SwishaMane's Back-up Beauty - HTPC
http://www.overclock.net/lists/display/view/id/3243963
The pics are incredibly old, but the spec list is up-to-date. Oldschool AMD s939 setup, 8GB DDR1, GTX260, M4 SSD, the works. Most badass HTPC a man can have.
Maybe I'll get some up-to-date pics soon.
Welcome to the club! Your our first non-founder member
to tell the truth I also did not see the OCN logo at first
If you take some more snaps of the updated PC, pls post them, would love to see them
Originally Posted by GrimDoctor View Post
Fantastic idea guys! Reserving this spot! Working on it right now!
I'm glad to see you here Grim!! I'm excited to see what you come up with. Also welcome SwishaMane. I like how you've implemented the flame in your acrylic. I'm glad to see that both of you are joining the club.
Discussion Starter · #8 ·
Will add you in, just tell me also the name of your rig so i can add that as well and if you have any pic of the OCN logo in construction,
mine is also under construction, but today will be the first water test
cant wait to come home and try it out
Originally Posted by X-PREDATOR View Post
This ua so awsome..are there any other requirements to be added here..im working on a build/casemod project..still in rhe works..and i think.i just found another design to add to the list..check my sig link for the thread..ill add a ocn logo once im able..itll make an awsome edition...
Im not sure what link you meant as there are 3 build links bellow, pls tell me what is the correct one, so i can add the correct one to the list.
As we are a newly established club not be so strict at the begging and we will give you two and every one who want's to join and still dose not have the OCN logo on there mod, a weeks time to post a picture with a plan how it will look like, maybe a 3d model in sketch up, or any sort of prof that you are going in the right direction
Think a weeks time is enough to make at least a picture showing the intent of your design
I'll have something to show soon now that I have some more time to work on it...ah Saturdays
Discussion Starter · #12 ·
The gluing of the acrylic was successful and the logo water loop is done, have tested it out that it dose not leak. It did get a "crack" but that seems to be from the acetone, and the cracks are on the inside, but think that will not be a problem
This is where it will be mounted at the end
Hooked up the the pump and my home made reservoir
It ended up being quite useful, just need to mount a valve for easy draining
And filled up with water, the pump running and no leaks
Discussion Starter · #13 ·
Great man, can wait to see it
My Saturday just started it 01:07 here, burning the midnight oil
Hi.my project is the case mod: old school to new...i was just asking...nothing definite..
Im a bit un mobile at the moment..had a op on monday..so i dont use any pc at the moment..using mobile..
If i did do a design..it would be a small one painted somewere on the case..im not a fan of disco lighted pcs or bigg stickers or signs plstered all over...
Discussion Starter · #16 ·
Ok no problem, will add you in and when you get back on your feet, post a pic so we can see how your planing to do it. No mater the size is the logo that counts
Yes why not..look at some pics in my thread..i did upload a pic of a spider template i made for painting with..judt a quick testrun..came out not to badly..
So either a black spider with a white flame logo or white spider with black logo..if this sounds stupidly cupid.you can have my posts deleted in this thread and ill just do smyhing else instead..
I think it could come out cool if done right. It'll be neat to see what you come up with.
1 - 20 of 165 Posts
