VerticalScope caused a need for a completely new/fresh overhaul so it is now even more so a work in progress and unfortunately will likely progress much slower than the last one.
OCN High Contrast Theme is a variation of TFL Replica's "OCN Dusk Theme" in which I modified his code to bring in some bright colors to contrast with the dark backgrounds.
Stylish Theme: OCN High Contrast
The following spoiler contains the original post when OCN was using a different host, I wanted to keep it around, but hidden.
***This post will be updated over time, for now I leave you with the basics.***
***Note: If you installed the Beta before I made this thread, please go and update or replace what you have currently as a few things have changed, and also be sure to add the Javascript edits (Greasemonkey/Tampermonkey add-on) which weren't available earlier.***
OCN High Contrast Theme is a variation of Jiiks' "OCN Dark Theme" in which I modified his code to bring in some bright colors to contrast with the dark backgrounds and have a few extra features added in that aren't found elsewhere.
So first off, thank you Jiiks, without you this wouldn't exist!
It is still in what I would consider a Beta stage as not everything has been looked at and tweaked yet, but will be done so hopefully soon. Once I feel every page has had a chance to be touched, I can then release the first official version.
For now it is around 90% complete and most of your regular pages should get the full theme feel.
The steps needed to run this theme are as follows:
If Using Firefox
I am not a Chrome user so if it breaks or has trouble in the future let me know and I will see if anything special needs to be done there as well.
If Using Chrome
If Using Internet Explorer or Edge
Let me know if you have any troubles with the installs and I appreciate feedback and suggestions either in this thread or via PM.
If Using Firefox
- Install the Stylish add-on, HERE
- Install the Greasemonkey add-on, HERE
- Restart Firefox (if prompted to)
- Install OCN High Contrast Theme (Stylish Portion), HERE
- Install OCN High Contrast Theme (Greasemonkey Portion), HERE
- Refresh your OCN page
I recently got updated to the latest Firefox (55) and all my extensions stopped working and say "Legacy".
This then caused OCN to revert back to default and look horrible as well as started getting redirect errors and other strange things I've never experienced before.
I am not sure if the extensions will make an updated version to work better or no longer say Legacy, but I was able to Enable them anyway (kind of override it I guess) and upon restarting Firefox things are back to how they were.
If Using Chrome
- Install the Tampermonkey add-on, HERE
- Restart Chrome (if prompted to)
- Install OCN High Contrast Theme (Tampermonkey Portion), HERE
- Download Firefox (IE/Edge are garbage), OR
- Download Chrome (IE/Edge are garbage), THEN
- Refer to appropriate steps above based on your newly chosen browser
