So it's about time I look into this and see what's available for me. I will soon be joining the military in a couple of months and also travel quite a bit, South Korea, Hong Kong, macao, next might be Shanghai or Germany etc who knows. I currently have the HTC one m7att and really have no problems with it save for a couple of things I didn't forsee needing. Back is not removable, and also doesn't work other than in the U.S.
So with that being said, please lens me a helping hand OCN!
What is your maximum budget?
500 USD
What country are you in?
South Korea, U.S. Possibly other locations
What will be the uses of this phone?
Communications, 1080p media playback, plenty of music is very likely. Email, lots of Internet.
Do you have brand loyalty or care which brands we select for you?
Not at all, however the cheaper the better.
What screen size do you require?
4.7 - 5.7 (6 is pushing it, but if circumstance requires then ok)
What screen resolution do you require?
1080x1920
Are you looking to buy NEW or would refurbished/recertified/used be okay?
Preferably new
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet)
As close to 4000mah as possible
What operating system do you need?
Kitkat, ability to upgrade to 5.0 is nice but not required.
Is there a certain style of phone you want? (aluminum, black, gaming, etc.)
Needs to have removable battery to access the back, aluminum would be nice but access is needed more.
How much storage do you need?
32gb is fine, more or expandable is welcome
Do you need any special hardware?
Dual SIM is a requirement. Expandable storage would be nice.
Is there anything else we need to know?
Needs to be at least quad core snap dragon 600 in performance or greater.
Essentially I'm fine with the specifications I have with my own m7, however I need a phone with removable back and battery as well as dual SIM.
If at all possible expandable storage would be nice.
Don't care what vendor it comes from, be it Korean/Chinese or otherwise
Thanks in advance guys!
500 USD
1080x1920
Preferably new
