1 - 20 of 22 Posts
I TeK things...
Discussion Starter · #1 · (Edited)
5120x1440p. Let that sink in just a little bit. Not a familiar resolution is it? Well Samsung has one upped themselves from last year's model, the CHG90 49” 144hz Freesync 2 panel that fell short in terms of vertical resolution, ie 3840x1080p. Originally debuted at CES 2019, which I had the honor of seeing in person, the CRG9 is a monitor I immediately fell in love with. Again with it’s 5120x1440p resolution, a 120hz refresh rate with AMD’s Freesync 2, HDR1000, on a VA panel, what’s not to love?
So 49 inches is a lot to love right? Let’s start off with the elephant in the room, why on earth would anyone want a monitor this big? Well why do some people have to have a 100 inch 4k HDR television? One word, immersion. Effectively having the equivalent of two 27 inch 2560x1440p panels side by side, the CRG9 fully lets the user be immersed in whatever they are doing. Now again 49 inches is still a lot to love, I have an 80 inch desk that I made from a solid core door and this guy takes up it’s half for sure! So make sure you have a large desk for the CRG9, cause it’s gonna demand it. Now since the CRG9 is such a large monitor, the stand has to be equally large as well. The footprint is quite simple but effective, having a simple Y to carry packaged weight of 44 pounds! The stand can also be swapped out for a compatible 100x100mm VESA mount adapter if you so desire, just make sure that your monitor arm will support such a heavy beast. Moving back to the CRG9, the backside is mostly fantastic plastic, with a white LED ring where the stand attaches to the monitor itself. The stand also allows for tilt, swivel, as well as height adjustment, albeit don’t expect it to get very high, however this reduces neck fatigue by not having the strain on the neck to look up or at a slight angle. Also on the backside are the 2 Displayport 1.4a ports, a single HDMI 2.0 port, 2 USB 3.1 Gen 1 Type A, 2 USB 2.0 Type A, and a 3.5mm output jack. A slew of cables also are included which includes Power, DisplayPort, HDMI, and a USB 3.1 uplink. The port placement is a point of discontentment for me, having a vertical orientation instead of the easier to plug in horizontal orientation. Also included is a plastic connection cover, which is why the ports are vertical I would guess. I know this is a clean look that Samsung was going for, which is appreciated, but a vertical plug in is very difficult to plugin a cable. Also the CRG9 does not include any built in speakers, but when you spend $1500 on a monitor, do you really want to use the crappy built in ones anyways? Didn’t think so. Moving around to the bezel of the CRG9, is a very thin border, however, the chin, is about ¾ of an inch wide, with a small Samsung logo in the center.
Ok let’s talk gaming with the CRG9. Running a resolution of 5120x1440 on a VA type panel, is effectively 2 2560x1440p monitors, so this is very close to running at 4K resolution, it’s somewhere in the neighborhood of 7.4 million pixels compared to 8.3 million pixels of that of 4K. Now take into account the CRG9 is running at 120hz, not like traditional 4K monitors running at 60hz. Think about it, the CRG9 is running 44% more pixels than a 4K monitor does at 60hz. That’s pretty nuts. Now add in HDR1000 support, factory calibrated, and has DCI-P3 95% color space, making games feel more vibrant and authentic. AMD’s FreeSync 2 is also present in the CRG9, which aids with LFC or Low Framerate Compensation when coupled with a compatible AMD GPU, which currently I have a AMD Radeon RX Vega 64 on hand. Also present are several modes for FPS, RTS, RPG and other game modes. And yes you could “cheat” and enable the Virtual Aim Point for on screen crosshairs, but I really don’t condone it. Another feature is the ability to take in 2 signals at the same time, like streaming on one side of the CRG9 with your desktop, and stream/chat on the other side on your laptop. The only thing missing that last years CHG90 had was a KVM switch, which would have been helpful when running more than one system.
So what do I think of this 49 inch monster? Well it’s a pity that I can’t keep it, cause it would be staying on my desk for a LOOOONG time. It’s just you have ultrawide, and then you have this 32:9 beast . It’s just insane at how much you can see with the 1800R curvature. Remember you are gonna need a beefy GPU setup to keep this beast fed. I tested with an AMD Radeon RX Vega 64 I mentioned earlier, as well as with a Nvidia RTX 2080 Super. While running an Nvidia GPU on a FreeSync 2 display doesn’t allow you to take advantage of any adaptive sync technology, gaming at higher refresh rates isn't bad either. It’s just currently AMD doesn’t have the high end GPU market to really make this monitor shine to its full potential. Remember Nvidia just announced in January that Nvidia GPUs would start supporting FreeSync monitors, FreeSync 2 monitors however not so much.
Alright HDR and monitor Overclocking. Really it’s hard to have one with the other. With the CRG9 it’s a bit of a give and take. While at its native frequency of 120hz, the monitor recognizes itself on Windows 10 as 8 bit HDR with dithering, however if you lower the frequency down to 100hz, ohh I know thats a sin, but then you gain 10 bit HDR. BUUUUUT, if you are ok with 8 bit colors, I was able to crank this panel up to 144hz! Needless to say I am quite speechless. 120hz on a 5120x1440p panel is already quite high, so I really wasn’t expecting to see 144hz at all.
Now let's chat about pricing. Yeah I agree, $1500 is quite a bit to spend on a monitor, even these days. But when you compare to the 3 other monitors out currently, which are the Phillips 499P9H, the LG 49BL95C, and the Dell UD4919DW, all have a refresh rate of 60hz with no adaptive sync technology. All of those monitors are over $1200, so paying a $300 premium for double the refresh rate with Freesync 2, is what I consider not a bad premium to pay. It’s just getting up to that price category in the first place.
So to wrap things up, the Samsung CRG9 QLED 49” Ultra Wide Curved Gaming monitor is quite frankly, simply amazing. Gaming on the CRG9 is such an immersive experience that words can’t even describe the feelings. Even though the CRG9 does have it’s issues with port placement, it manages to receive the “Overclock Hottest Gear 2019” award. This award is a step above the normal 5 out of 5 flames. Samsung obviously listened to the community, made a couple of necessary improvements and hit it out of the park.
Alright guys, thanks for watching. If you haven’t liked and subscribed by now, you know what to do. I will see you all in the next one.
Bluedevil out.
Just another nerd
There seem to be a lot of end-user complaints about dead pixels with this model on Amazon and other outlets. Also, anyone buying this model should be well aware that 120 Hz is only supported in 8-bit color mode (16.8m colors). 10-bit is 100 Hz only.
I TeK things...
Yep I covered 8 and 10 bit colors in my review.
Super Moderator
Did you post this from your phone?
Just another nerd
It wasn't originally like that, the text was fine. He must have done an edit from his phone after he posted the original that caused the formatting issues.
I TeK things...
Discussion Starter · #7 · (Edited)
Exactly what it was. Fixing in a few.
*Fixed now. Thanks guys! :thumb:
Vermin Supreme 2020
if i could source it locally, thus easily return if dead pixels popped up, i'd be all over this.
My favorite all time setup was 3x 1080p/1440p, so squeezing near that into 50 inches, instead of 75-90 sounds epic.
When I had my 5970 I ran 1680x1050x3. Then I went to 2560x1440x3. When I went to better gpu's.
I now have a 3440x1440 monitor. I would love a 5120 x 1600 but 1440 will work. But I am going to wait one more gen though, I want HDMI 2.1 and go 144hz at 10 bit.
Skating Enthusiast
Dream monitor. Well, almost. I'd like a high PPI version (10240x2880) but I think it's going to be a while before that comes out :D
Why I had to watch those videos... Now I want this. But I must resist because I don't have a graphic card that can handle that resolution. VA is my yes monitor anyway. Currently I have Samsung C34H890 for gaming and movies.
Skating Enthusiast
It does look pretty cool and I bet it's sweet with racing games. Raise your hand if you immediately thought, I need 2 of these to STACK!
But..... man I dunno. I got a 43" 4K monitor locally (Microcenter, Acer ET430k $399) and it's just the most awesome thing. It's been 2 months now and sometimes I just stare at it in awe.....
My GTX 1070 couldn't cut the 4k mustard though, had to upgrade. I sold it and got a used 1080ti and it does pretty well...
Vermin Supreme 2020
I would'a jumped on this monitor over my 4K any day if it would'a been out.
I miss my old NV surround setup, & this resolution/size is pretty much that in one big screen.
luckily I've decided i'm on hold for all upgrades until late 2021, we'll see what kinda true ultra wide single panels exists then.
I've got to say this monitor is an absolute beast! I order mine directly from Samsung and it arrived two days later without any dead pixels. I did notice that my monitor is a second revision so maybe Samsung has made changes to the manufacturing process to help with the dead pixel issue.
I TeK things...
Discussion Starter · #18 ·
Great to hear. Yeah I am sad I had to send it back. 😞
Just another nerd
Overclocker
The biggest downfalls of these:
  • the distorting curve
  • slow smeary blacks VA
  • barely any movies are made beyond 21:9
Sadly LG makes the same mistakes and curves most if not all of their ultrawides.
And prices are inexplicably nuts for ultrawides. Might as well buy an OLED TV at 1500 USD/EUR, well you can get those now from a 1000 USD/EUR. Makes 1500 monitors fairly worthless.
http://www.displaywars.com/55-inch-d{3840x2160}-vs-49-inch-d{5120x1440}
Double the height for 55" 16:9 vs 49" 32:9. Of course pixel density is worse for the TV panels.
1 - 20 of 22 Posts
