Purpose:
"I want this thread to exist so we can all shear the beauty and power of most overlooked component in the rig which is" the memory,show what we use on daily bases and bench-marking, help others to make the right decision when buying RAM ..and since some of us can't stop buying/blowing more money on ram a place to show what we roll
Rules:
If you have more than 2 sets of RAM (DDR2/DDR3/DDR4) ;
-post pics of your memory sets
- make, model number
- your favorite bench and 24/7 RAM
if you willing to go extra mile;
-post the picture of bare module (heatsink off)
-post your Maxxmem,Super PI,Aida benchmarks
http://ramlist.i4memory.com/ddr3/
http://www.hardwareluxx.de/community/f13/g-skill-ddr3-ic-sammelthread-924433.html#l
http://i4memory.com/f94/ddr3-ic-list-submissions-8426/
http://www.ocaholic.ch/forum/index.php?page=Thread&threadID=4202
http://occlub.ru/forum/showthread.php?t=861
http://forums.xtremelabs.org/viewtopic.php?f=15&t=408&start=20
http://www.xtremesystems.org/forums/showthread.php?285767-DDR3-IC-thread
DDR4
Great read on DD4
http://www.legitreviews.com/ddr4-memory-scaling-intel-z170-finding-the-best-ddr4-memory-kit-speed_170340/3
G.Skill SN#
3300=Micron SS
3400 =Hynix SS MFR
3500=Samsung SS
A500=Samsung SS D-Die (earlier batches) or E-die
2x8 kits made in Dec.could be DS E-Die or mixed
Corsair Ver. #
ver5.29 =Hynix SS
ver4.23 =Samsung
ver3.20 = Micron
ihog6hog
http://www.overclock.net/t/1268061/ocn-ram-addict-club-gallery/6810#post_24570150
Lot Sep = E-Die
Lot Aug = D-Die
Lot Sep = E-Die
Lot Aug = D-Die
DDR3
DDR3
This are the new serials on Gskill memory some were changed and some are still the same (this is not 100% accurate)
0140 = Micron
0000 = Test sample
0240 = Hynix
0260 = ?
AB40 = Hynix
0340 = Samsung
0360 = Samsung
0640 = Elpida non-Hyper
0650 = Elpida (seen on blue PCB Tridents)
0660 = Elpida non-Hyper
0690 = Elpida Hyper
1200 = PSC
1240 = Nanya
1400 = Hynix(CFRds)
1500= HCH9 Samsung
2500=Samsung (new SN#)-HYKO
0401= PSC
1040 = PSC (see below)
ddr3-ram-myths-enlightened
http://overclocking.guide/ddr3-ram-myths-enlightened/
Single sided MFR vs. double sided CFR
Haswell
credit goes to all who contributed
0140 = Micron
0000 = Test sample
0240 = Hynix
0260 = ?
AB40 = Hynix
0340 = Samsung
0360 = Samsung
0690 = Elpida Hyper
1200 = PSC
1240 = Nanya
1400 = Hynix(CFRds)
1500= HCH9 Samsung
0401= PSC
Corsair DDR3 IC InquiryFor example, the following are Hypers:
1600 6-6-6, 1600 6-6-5
1866 7-8-7, 1866 7-7-7, 1866 7-7-6
2000 8-8-8, 2000 8-8-7, 2000 7-8-7, 2000 7-7-7, 2000 7-7-6
2133 8-8-8
2200 8-8-8
2250 8-8-8, 2250 9-9-9 (some)
2300 9-9-9 (some)
Haswell
http://www.xtremesystems.org/forums/showthread.php?286315-SuperPi32m-5GHz-amp-4GHz-Haswell-All-Out-Challenge!&p=5201542&viewfull=1#post5201542Also a few other things to keep in mind for first time memory subzero
* Dont worry too much about CPU on subzero it probably is not required in most circumstances, CPU on air/water should be fine for tight legacy ICs subzero, I can train/bench 2700 6-9-6 with CPU on water no problems
* Get a baseline on air that you know works but is on the edge, when you mount all your gear subzero make sure that baseline is good, this will save you alot of time
* When you are pulling down you will often need to retrain memory, sometimes around 0 degrees, sometimes around -30, but expect some not exacts as you are pulling down, going into bios and changing 1 memory timing will force retrain
* Use mrc disable when you have your settings locked in, disable mrc re-train on boards that support it, this will give you longer more reliable subzero sessions, more time benching, less troubleshooting
* Watch how much grease you have around your ram slots, if you are having issues, clean the ram with circuit board cleaner
* If you want to train CAS6 TWRRD_DR must be 5 or looser; I may be possible to train cas6 with TWRRD_DR 4, but so far I have not been able to do it
