110781 - 110800 of 110851 Posts
I can count to potato
I kinda like soft tube spaghetti builds. Recently added some spice (10850k) and redid the spaghetti on my spare PC. Single D5 pushes through this and a MO-RA3 mounted under the desk just fine.
2486314
2486317
WaterCooler & Overclocker
2486904
New here. Just built a b550/5800x setup. I had parts to water cool my reference 1080ti in the mail when my x79 board blew out, so made the upgrade to b550. Parts to water cool were intended for a more confined case, so have simply been adapted to this case. Got a cpu AIO for simplicity, and also because my gpu WC parts had still not arrived.
Just has 2 cheap copper 120mm rads, one up top, one on bottom. All rads are setup to push as exhaust. 3 case fans (one missing in photo) are setup as intake. Rads all using arctic pressure optimizes fans.
Gpu runs at 42 degrees, full tilt. Blower cooler used to have it at 84 full time. 5800x @ 5050mhz hovers around 52 degrees under normal gaming load
Reactions: dwolvin
View attachment 2486904 New here. Just built a b550/5800x setup. I had parts to water cool my reference 1080ti in the mail when my x79 board blew out, so made the upgrade to b550. Parts to water cool were intended for a more confined case, so have simply been adapted to this case. Got a cpu AIO for simplicity, and also because my gpu WC parts had still not arrived.
Reactions: Knoxx29
Professional Lurker
Yep. That "effect" is caused by a non-circular aperture. Here is a 14-point star created by a 7-bladed aperture:
2487205
Reactions: dwolvin
Knowledge is Success
This is my ghetto setup atm.
Rather then lose a radiator for the stupid AIO, I made it work. I think the tape job adds real class to it.
It’ll be cleaner once I get a block on it.
Which one from those in your Sig is your main Rig?
