110981 - 111000 of 111015 Posts
11900K - M12F - Strix 3090oc
Here is my setup with my brand new 11900K + Z590 Apex.
Pretty darn happy with the setup which I have planned for a few months now.
  • Intel i9 11900K CPU with EK Quantum Magnitude Block
  • MSI Gaming X Trio 3090 with EK Quantum Vector Block + EKWB Backplate Nickel + Thermalright 13.8W/mk High Performance Thermal Pads (450W Suprim X Flash)
  • Asus ROG Apex M13A Z590 M/B 0903 BIOS
  • Klevv Bolt XR 3600Mhz C18 O/C 5066Mhz C20 + EK Monarch Heatspreaders + Thermal Grizzly Minuspad 8W/mk High Performance Thermal Pads + EK Monarch x4 Nickel Waterblock
  • Asus Thor 1200W PSU
  • Western Digital 1TB SN850 Gen4 M.2 NVME
  • Silver Surfer 18AWG Custom Cables
  • Link-Up Gen4 PCIE Cable (Vertical)
  • EKWB Radiators + Vardar X3M 120mm Fans + Fittings + Cryofuel + Red Dye Pack
2517359
2517360
2517361
2517362
2517363
2517364
2517365
2517366
2517367
  • Love
Reactions: morph.
Singularity Spectre case is $$$$$$ nice work.
Reactions: satinghostrider
Yeah great team they have and a pleasure to work with them from down under mate.
Awesome cases they have too.
Won't lie I nearly got it but I wanted expandability for a 3rd 360 rad which I just done heh.
Yeah these cases are not really for big expansion and I'm happy with the thermals this far. I'm actually going to swap out my RGB Fans for the new Gentle Typhoons to get rid of all the RGB wires. These are also better static pressure fans. 3 radiators is next level mate!!
Yea with the new gen cpus/gpus the amount of TDP/Heat output I had allow for the 3rd rad :D
  • Love
Unfortunatley
The only type and asthetic style I like for PCs are
Designed and built using medical waste, necular waste,
The entire PC and room infected with pernermantly non curable fast and slow death type virusus
Then the built like trash and got smashed to death non stop every day
Just finished with my 3 360mm rad loop. All three rads are dedicated to my lovely little heat monster that is my 9980XE. I also ran all tubes on the back of the motherboard tray. Really love this look, at first glance you can't even tell I have a 360mm rad let alone 3.
How is this possible!
Old to Overclock.net
I currently have it disassembled, here is a pic of it. Have the pump res combo behind the motherboard tray.
2518022
Going to test drive a 5900X, going to push the snot out of it. If this cooling system can handle a 600-700 watt 9980X it can handle a 5900X.
Reactions: dwolvin
