OCN Water Cooling Club And Picture Gallery
12667675 Views 112115 Replies 4567 Participants Last post by  storm-chaser
Purpose:
I want this thread to exist for 2 purposes. The first purpose is so that we can all enjoy the sheer beauty and power of water cooling. The second purpose is so that people who have never used water can come here for inspiration to make the switch and for advice and ideas on what kind of parts and setups they want for themselves.
Mature discussion of parts and watercooling theory is welcome,if the post you wish to make is of a technical nature then please use the search to see if you question has already been answered or start a thread. The post rate is very fast and questions can get swallowed up and not seen,dont be offended if your question is not answered immediately.
Rules:
To join this club simply post pics of your COMPLETE rig in THIS THREAD and I will add you to the list. The rules are not strict, ANY form of liquid cooling is good; that includes users of products like the Corsair H50. Feel free to post multiple builds and have multiple posts, I will add them next to your original post in the list. Even builds you no longer have are acceptable, just so long as they were built by you.
Dont double post and keep quoted pics (except one) spoilered,this keeps this thread tidy.
Sig Tag:
[CODE][URL=http://www.overclock.net/t/584302/ocn-water-cooling-club-and-picture-gallery/0_20]OCN Water Cooling Club[/URL]
[/CODE]
Reactions: 5
111001 - 111020 of 112116 Posts
How do you like those UpHere fans? My Riings are starting to get noisy...
Have you considered Fractal Design Primas? If you get the AL120s, PWM variant, they have good static pressure, and good sound characteristics. And the RGB is daisy chain, so you can run the lights off the motherboard without needing extra control boxes and software, outside of mobo RGB software of course. Just don't accidentally get the 3-pin non-PWM version, static pressure drops from 2.7mm/H20 down to 1.3 on those.
Good to know (those are new to me), but they look like there would be a large amount of leakage around the round frame. It would be going on a pair of 3x 140 rads...
And, OOF that price...
The first sets I purchased a year (maybe two) are decent. They are not very loud and seem to do a good job. I am by no means a noise expert and my wife calls me deaf all the time.
Now the last set I purchased a few months back (the ones on the vertical rad), and those are extremely loud compared to the original batch.
Yeah, that sounds about right. Great cheap fans quality level goes to heck when they get popular.
I got a bunch of Phanteks PH-F140MP v2 fans for use with 2 x 420mm HWLabs radiators... so far I'm very pleased with their sound profile. I have pretty sensitive hearing and I can only start to here them around 800 or 850 RPM. I've been very pleased with them... after I get my case built and all the stuff mounted I'll give an update too.
Nice! Those and the Artic P14's have always been on the list, I think simple and industrial will go with most cases.
Hardware:
Ryzen 9 5950X
ASUS ROG Crosshair Viii Dark Hero
Nvidia RTX 3900 FE
G.Skill 64 GB Trident Z Royal DDR4-3600MHz CL14-15-15-35
Seasonic TX-1000
Western Digital SN850 1TB
Sabrent Rocket 4 Plus 2TB
Crucial MX500 SSD 2TB
Western Digital 10TB WD100EMAZ
10 x Noctua NF-A12x25 PWM fans
Audio:
DAC/AMP RME ADI-2 DAC
Beyerdynamic DT-990 Edition 250 Ohm
Watercooling:
TechN CPU waterblock
EKWB EK-Quantum Vector FE RTX 3090
1 x Watercool Heatkiller Rad 360-S
2 x Watercool Heatkiller Rad 360-L
Aquacomputer D5 Next pump
Aquacomputer High Flow Next
Aquacomputer Leakshield
Aquacomputer ULTITUBE D5 150 PRO reservoir
Aquacomputer DP Ultra water
Bykski fittings
Barrow and Bykski copper tubes
Automotive design Automotive lighting Wheel Motor vehicle Automotive tire
Drum Membranophone Musical instrument Light Idiophone
Automotive design Idiophone Computer hardware Electronic instrument Audio equipment
Computer Computer cooling Personal computer Computer hardware Electric fan
Automotive tire Tire Entertainment Automotive design Vehicle
Automotive lighting Automotive design Personal computer Automotive exterior Gas
Automotive lighting Automotive design Entertainment Font Motor vehicle
Light Automotive lighting Lighting Automotive design Red
Automotive tail & brake light Automotive lighting Motor vehicle Automotive design Font
Automotive lighting Automotive design Entertainment Automotive exterior Electronic instrument
Product Entertainment Audio equipment Automotive lighting Gadget
Automotive lighting Light Automotive design Entertainment Visual effect lighting
Personal computer Computer Computer cooling Computer hardware Electrical wiring
Automotive design Membranophone Automotive tire Electronic instrument Automotive lighting
Membranophone Drum Idiophone Musical instrument Drumhead
Liquid Automotive lighting Drinkware Barware Font
Automotive lighting Automotive tail & brake light Automotive design Rectangle Font
Automotive lighting Light Automotive tire Red Entertainment
Font Display device Gadget Audio equipment Electronic device
Font Visual effect lighting Electronic signage Display device Signage
Reactions: 5
I currently have it disassembled, here is a pic of it. Have the pump res combo behind the motherboard tray.
Going to test drive a 5900X, going to push the snot out of it. If this cooling system can handle a 600-700 watt 9980X it can handle a 5900X.
Wow, you will have to post your temps. I have 5900x, it takes some definite tuning as it will take all the power you can give it with power limits and all that
Not a custom loop or half as nice as some of Tue builds here but its mine and I enjoy it
Sent from my SM-A217F using Tapatalk
Reactions: 2
Will do, I am just waiting on the damn AM4 brackets so I can use the Heatkiller IV Pro block. I might get impatient and just put in the swiftech block I have in the closet since it has the AM4 brackets.
That is all I need to get this build going.
2518249
2518250
I just went ahead and installed the swiftech block and am not happy with the temp. With just XMP enabled (don't have time to tuned the memory at the moment, on X299 I had it at 4000 CL15-15-15) and PBO turned on during CB20 my cores settle at 4.450 all core giving me a 8700 score. CCD 0 is maxes out at 71 and ccd 1 74. Going to tweak further, going to see how far I can push the cores with a manual oc at 1.35 vcore.
2518317
2518318
Ryzen 5900x
Crosshair VIII hero
Trident Z Neo 32gb 3600 cl16
Strix RTX3080
Soundblaster AE-5
Corsair AX1200i
Samsung 970 evo+ 1tb x2, 870 evo 1tb x2
EK blocks, res/pump
EK PE360 rads
Lian Li O11D XL
Lian Li SL120 fans
Reactions: 5
I like having some window to see the coolant / bubble situation, but that's beautiful!
I just finished my Desk PC build . I cut out the front panel to install 8x 120mm fan +added Demciflex filters ( by default it was restrictive mesh panel and only 6x120mm fan)
For now only one 360*30 x-flow rad for CPU ,but water temps are alarming ( Idle 34C in 29C room , and 45C water in game ) . The reason is : VGA(3080) dumping 340W heat and the radiator fans are working with hot air. I ordered now a second rad to the other side , where it can draw fresh air from the front fans . VGA block and 2nd pump is a fortune, so i will water the card in a half year .
Automotive design Interior design Table Gadget Flooring
Furniture Table Personal computer Wood Audio equipment
Reactions: 3
o11xl side & v3000 side dual d5 distro
this awesome quality
good stuff
Reactions: 2
Reactions: 4
good stuff
Do you have the link for that distoplate?
bought it through a online platform here.
his store..
Check out this shop on Shopee! wvmech: Shopee Malaysia | Free Shipping Across Malaysia
pretty reputable
side distroplates can be used in any big size cases .. v3000 is superb but let
@owikh84 post his rig soon.
Step 1. 3800X, X570 GPC, Alphacool.
Step 2. Phobya
Step 3. 5800X, X570 Unify, RTX 2070, TechN AM4
Step 4.
Forgot pictures of new Heatkiller Tube DDC 3.2
Step 5. Current iteration, external Supernova
Hardware AMD Ryzen 7 5800X @ 4798.88 MHz - CPU-Z VALIDATOR
  • Love
Reactions: 5
