41 - 60 of 154 Posts
Rig Advisor
Water-cooler
Output is up! Time for a small break on the main rig for gaming.
2462211
OC...D
Reactions: NBrock
OC...D
Water-cooler
So what does the 3090 do? I have a 3090FTW3 getting here next week...
I have an FE. Depending on WU I have seen 5.5mil for some of the typical "garbage" WUs but the majority of the WUs I get are estimated at 7-8.5. Stock boost clocks BTW...just maxed power slider and fans set to 75%.
The only WU I saved the info for was Project 17418 (0, 487, 47) with a TPF of 26 seconds for an estimated 8235295.74 PPD. I'll try and save more for the PPD Database.
Reactions: Jpmboy
Water-cooler
Once blocks for the FE hit...shunt mod is in my future.
OC...D
Oh that's just sick! 😲 I'll plug the FTW3 in once it gets here, but I think I'll be running air cooled for awhile.
OC...D
Rolling start?
Just notice this thread a day before this starts lol. Do I have to do anything? I keep reading about a passkey. I didn't enter one, I just put in the team number when I started folding.
Not new to Overclock.net
Firing up.
Rig Advisor
Just make sure you sign up for the FaT on the 1st post.
OC...D
eh, starting to get "server did not assign work" in the FAH log. :(
2462471
Rig Advisor
OC...D
a WU eventually downloaded. I'll check the log in a few hours...
I <3 narcissists
I can't see it from where I am (work), but I am pretty sure my machine at home doesn't have a WU going based on my hourly stats..
Rig Advisor
Yep, pretty low.
Been around...
Still not showing up on the spreadsheet. I "signed up" again. Hopefully things will start appearing.
I <3 narcissists
Just another reminder that I need to get the remote thing set up. The wait time to check for another work unit is probably really high since it increases each time it cycles around.
Can anyone recommend a good remote desktop software that doesn't require a monthly subscription? I'm not sure if Win10 home has a feature like that built in.
I don't think that means it isn't tracking your stats, I think that's how it always is.
