1 - 5 of 5 Posts
Hey guys, I had a 2x1Gb OCZ Reaper 8500 @ 1111Mhz 2.1v, 2Gb wasn't enough ram so i bought 2x2Gb OCZ Reaper 8500 to team up with the one i already have.
The problem is they wont work both if clock is higher than 667mhz :\\
I've upped the voltage to 2.2v and changed the timings to 6-6-6-16 and even so they wont post :\\
Any ideas?
Thx 4 reading
Ive upgraded the BIOS, its the same thing. Both kits work but only if they're alone. Together they only work @667Mhz 5-5-5-16 2.2v. 2.1v won't post either.
edit: tried to 'OC' and it wont post beyond 730mhz, besides with the two kits it wont boot windows even at 667Mhz.
edit2: I been trying other things and i found out that 1 of the sticks is faulty. It will BSOD if ran over 667mhz. otherwise the 1x2gb kit works great @ 1066mhz with the 2gb stick that isn't faulty. I'll RMA it...
1 - 5 of 5 Posts
