Hey, I am looking for tips on how to make a stable stable over clock. From my understanding, i need to have my cpu and ram running at compatible speeds ind order for the pc to boot. I have a DFI Mobo and my CPU is an AMD Opteron 144. My CPU Frequency is 315, ldt.fsb ratio is 3.0x
ltd bus is 16 16
cpu/fxb fq ration is 9.0x
and all my cpu volts are at 1.55 (max on my mother board)
For the life of me, i cant get my memory to run stable... i am expirementing with my voltages from 2.7-3.0. I dont know what i should set my Dram Frequency to.. someone told me it should b e a 1-1 ratio... making it 200mhz. My command per clock is enabled. And i am honestly not sure about everything else.
Any help would he highly apreciated.
thank you
ltd bus is 16 16
thank you
