Well to start i will give you two specs of two different RAMS.
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Gold GX XTC Series - CL 2-3-3-8
OCZ 2GB (2 x 1GB) PC4000 Dual Channel Gold GX XTC Series - CL 3-4-3-8
I have the PC4000 version, which runs at a higher speed, but worse latency, i have just noticed that my MSI Neo2 Platinum only lets the RAM go to 200Mhz, it does not let you select a divider just lets you select 133, 166 and 200Mhz.
Well PC4000 ram can run at 250Mhz but i only can have it at 200Mhz which is the PC3200 speed.
But if i ran the PC3200 vs PC4000, wouldnt the PC3200 get better benchmark results than the PC4000 because of the lower latency.
If so what should i do, can i lower the latency to match the PC3200.
