OCZ Freeze or AC MX-2? which one is better?
525 Views 12 Replies 7 Participants Last post by  Purple
hey guys getting new thermal paste just wondering which one i should buy. i have AS5 right now and need lower temps.
Also switching out the Xigmatek S-1283 for a lapped TRUE from crazypc.com with a Ultra Kaze 3000rpm fan.
1 - 13 of 13 Posts
AS5 somehow works better on the Xigmatek than any other paste...
OCZ Freeze, in general, is the better thermal paste... so you can give it a go, though I've heard AS5 performs better than OCZ Freeze with Xigmatek coolers
i'm using ac mx-2 right now, i get about 1-2c lower than AS5. I haven't tried OCZ freeze yet tho.
Originally Posted by corey407woc View Post
is ocz freeze better than ac-mx2?
Through many online reviews, yes... both AS5 and OCZ Freeze are better than MX2
do you think the paste would bring my temps down even more if i switch the xigmatek for a lapped TRUE and add the ultra kaze 3000 fan
Of those choices I would pick ocz freeze.
Personally I use as5 or shin etsu.
definitely... a lapped true with an ultra kaze will dramatically lower your temps.. I'm estimating at least 8C + another 2C with OCZ Freeze... I have the TRUE with a 2000 RPM Ultra Kaze, and it performs very well... with a 3000 RPM Ultra Kaze, you won't have to worry about overheating
wow that is amazing i think i will do that then cause i have a 1.200 vid q6600 that i need to crank to 3.6 and i cant with current setup cause temps anyone want to buy a pretty much brand new xig haha
With Q6600 being 10c lower then what it was before due to wrong reading of tj.max i think xigmateck is more then enough. My Quad get 63c load with OCZ freeze and Kaze 3000. With the new reading its is 53C load.
The TJmax was set wrong. I think it is supposed to be 95*C?
btw your avatar somehow looks disgusting to me
Should be 90 for Q6600 G0 according to this chart.
http://www.xtremesystems.org/forums/...postcount=2400
1 - 13 of 13 Posts
