OCZ or Cooler Master?
769 Views 12 Replies 11 Participants Last post by  FREELINE57
Hey. I'm going to get a Q6600 in a few days, but my old PSU is probably not going to handle it, so I'm looking at getting a new one. I was looking at these two since they're not so expensive
http://www.newegg.com/Product/Produc...82E16817171014
http://www.newegg.com/Product/Produc...82E16817341010
Btw, i'm not going to buy from newegg, just saying.
Which one of these is better? I don't think i'm going to run SLI in the future, though I will probably upgrade my GPU to a GTX285 in the future.
1 - 13 of 13 Posts
OCZ over CM. But I think corsair makes a better power supply then OCZ does.
I used to have a coolermaster 600watt extreme psu and I had no problems with my e7200 and sli 9800gt's. I probably think the ocz is better and I have heard the "extreme" coolermaster are crap, but my old on was just fine!
Corsair.
Originally Posted by the master chief
neither, this.
+1
Originally Posted by The Master Chief
neither, this.
Too bad it isn't modular though.
Doesn't OCZ use the same internals as PC P&C?
Nope. They bought PC P&C but have only integrated their design features into very high end PSUs, as far as I'm aware.
Thanks a lot for your answers.
I think i'm gonna go with the 650tx, or even 550vx.
The corsair 650tx would be a very good investment. Reliable, quiet, good stable power without droop.
1 - 13 of 13 Posts
