OCZ Platinum VS. Gold series (pc2 6400)
604 Views 2 Replies 2 Participants Last post by  Aqualan
Is the OCZ ddr2 pc26400 platinum that much better than the gold series? The timing's are simular, heat spreader is a little better on Platinum. What do you guys think?
1 - 3 of 3 Posts
tighter timings are always better, and thats the difference between the two...
I just went to OCz's site and you are correct. 4 vs 5 timings. Newegg had the timings for gold in the 4's, or so I thought. Thanks
1 - 3 of 3 Posts
