I am planning on purchasing the ASRock "K8 COMBO-Z"
(http://www.newegg.com/app/viewProduc...157-035&depa=1
I have read the few reviews and do not try to persuade me not to buy this mobo as it is my final choice.
Ok to my question. If I purchase DDR 433, 466, or 500, Can I set the memory speed down to the supported DDR 400 specifications and have the board be stable? I am going to overclock the Sempron 3100+ I am purchasing so I want memory headroom... I think the anwer is yes but I am not sure.
plz answer. (obviously I will be using single channel memory)
Also... I can't seem to find a memory support list anywhere... though i was planning on going Mushkin.. it would help to be sure.
my plans 1. Buy this Motherboard with a sempron 3100+ and fast memory with headroom.
2. overclock when I think its slow
3. upgrade to a socket 939 when the price perfermance ratio is reasonable.
