Hello all, and welcome to the ATI 1GHz club. For those of you who do not know what this is about, look in my sig. You will see I am running 1030c on my ATI card
well, this thread is for those who are 1000c or any ATI card.
Anyone who is running 1GHz on their ATI core clock is welcome!
You do not need to run FurMark or OCCT to be in this club, just 1000c stable enough to play games.
IF YOU WANT IN THE CLUB, YOU MUST BE ABLE TO AT LEAST RUN 3DMARK VANTAGE OR 3DMARK 06 WITH YOUR CARD @ 1000 CORE OR HIGHER AND COMPLETE IT! YOU ALSO HAVE TO HAVE A VALIDATION FROM GPU-Z! MY RULES ARE FLEXIBLE!
FOR THOSE OF YOU SEEKING NOTABILITY, YOU MUST BE ABLE TO DO:
1.Be able to pass at least 20 (1 minute idle, 15 minute test, 4 minute cool down) minutes of OCCT GPU with 8 shader complexity, full screen 1024x768 w/ error checking on with NO ERRORS!
Or run FurMark for 900 seconds (15 minutes) without any kind of artifacts! ~ This rule applies to those with a bolded title! Otherwise your just added to the thread!
2. Must have a GPU-z validation
3. MUST HAVE A SCREEN SHOT OF YOUR STRESS TEST (FurMark, Kombuster, OCCT GPU, etc...) IF YOU WANT TO BE ENTERED IN WITH ELITE (15 minutes of Furmakr or Kombuster, or 20 Minutes of OCCT GPU, etc...) OR VIP (30 minutes of Furmark, Kombuster, or 35 minutes of OCCT etc...). You know something like this
4. If you are willing to run 30 minutes of FurMark or OCCT (8 shader complexity) or more (1800+ seconds), I will put your name in red for full stability no matter what! ~
This is the highest stability you can get with a card. I will PM you for with an individual badge to put in your sig for this + rep.
5. If you do not like using FurMark to stress your GPU, run Crysis 10 times and watch it for any sign of instability. Same goes for FarCry 2 and what not.
MUST BE MAX RES YOUR MONITOR SUPPORTS AND HAVE AT LEAST 4AA!!! SETTINGS MUST BE SET TO THE MAX!
6. You can also use
[email protected], but I find this rather unreliable. But if you can run 1hours @ said OC with the view
OPEN then you are stable.
7. You may also us GPUtool but you have to have at least 30 mintues of stress testing.
8.
EXCEPTION RULE - If you do not feel comfortable running FurMark or any like program, please prove to me your card is 100% stable and will give you VIP status.
9.
YOU DO NOT HAVE TO RUN FURMARK TO BE IN THE CLUB! AS LONG AS YOU CAN PROVE YOU CAN PLAY GAMES AND SUCH ON YOUR OC, YOU ARE IN!
EX: Run Crysis Benchmark 20-30 times.
10: WHEN THE MSI HD5870 LIGHTNING COMES OUT, AND YOU HAVE ONE, YOU HAVE TO IMPRESS ME WITH THE CARD TO GET INTO THIS CLUB! THEN IF YOU CAN, PROVE YOUR STABLE!
11. If you want in the club, but you have questions and concerns, PM me. I am very lax when it comes to the rules.
For those of you having issues getting to 1GHz core because of CCC, try this!
Originally Posted by Mastiffman
ENBLING UNOFFICIAL OVERCLOCKING in MSI AfterBurner
I attemped this and asked advice from some people and didn't really get a straight answer as to steps. So I indulged myself to figure it out.
I also wanted to inform those of you having issues enabling the "unofficial Overclocking" feature in the MSIafterburner Program for convenience of NOT having to use Both the AMD GPU Tool (to change the frequency) AND MSI Afterburner (Just for the voltage). And to try this Before Flashing the BIOS like some are attempting, when the issue really may only be taking the right steps to change the .cfg file and saving it properly...
Here are instructions on how to do so. Make sure that you follow step #4. Otherwise it won't work!
1.) Open the MSIAfterburner.cfg with Notepad
2.) Change the "enable unofficial overclocking" Value of 0 to 1.
3.) Select "File" and select "Save as".
4.) When the save window pops up select "All Files" in the "Save as type" box and save!
It wil ask you to confirm the "Overwrite of the file" Select "yes".
You are done and should be able to Use ONLY MSI Afterburner to overclock your ATI Series Card past the max CCC Frequency!
Have fun!!!
Please note: IF you can prove your OC is 100% stable any way (doesn't matter if you use OCCT, FurMark, or what) I will give you VIP status. Otherwise, welcome to the club!!!!!
Once I get Google Spreadsheet set up, I will put it in here
Please post using the following format (I will be lax on this)
OCN name
ATI card model/make
Core clock w/ percentage OC
Validation of stability (OCCT screen shot)
GPU-z screen shot or validation link.
My validation will be comign soon!
Okay, I saved a screenshot of furmark and it was at 2166s... :/ but I cannot find it. Here is the rest of my stuff:
Core %
Mem %
Will be organized by highest Core overclock!
Cut above all else:
Contagion - Sapphire 5770 V2 - 1130/1415 - 33%/18%
Validation
Mastiffman - Sapphire Vapor-X 5770 - 1.337v - 1106/1425 - 30%/18.75% -
Validated
Patch -
Reason why
HD 5xxx series
http://spreadsheets.google.com/pub?key=tC156WRMHWNl5nyOzZEJ4bg&w=500&h=500 Google Spreadsheet
HD 4xxx
http://spreadsheets.google.com/pub?key=tk4i-tNZIVx2DqIqI6YX9aQ&w=500&h=500 Google Spreadsheet
HD 3xxx (doubt this)
Patch - GOD AMONG GODS!
I will not post his scores here for they are too damn awesome. The only thing I will post here is a
link
HD2000
For those of you who want to advertise this thread, fell free to stick this in your thread!
[B] [URL=http://tinyurl.com/ybkybyt]~***Offical ATI 1000MHz Core Club***~[/URL] [/B]
VIP 1GHz Useres:
Official VIP Members of ATi 1GHz Core Club:
http://spreadsheets.google.com/pub?key=tcoNkW4vV4MyiwUXkoG5yPg&w=250&h=500 Google Spreadsheet
