The 4750G wasn't much better and the 8MB cache helped to really cripple it with Firefox. Stopped using it when it started to choke on 250+ loaded pages.The 5700G I hope is not locked down like the PRO 4650G was. You could not increase PPT/TDC/EDC from stock values making it really gimped in performance overall.
(4650G had horrible Manual OC clocks as well, trash silicon)
lol what is this firefox benchmark? Would love to give it a tryThe 4750G wasn't much better and the 8MB cache helped to really cripple it with Firefox. Stopped using it when it started to choke on 250+ loaded pages.
Hoping the 5700G will cope with the latest Firefox juggernaut. That app alone really helps to cripple most CPUs except for the 10900K which can handle up to 460+ webpages loaded into memory.
At this stage, just need something that stays working for days without collapsing.
Try loading 460+ webpages within Firefox then watch how the system slows down to a CRAWL.lol what is this firefox benchmark? Would love to give it a try
That’s like the whole internet.Try loading 460+ webpages within Firefox then watch how the system slows down to a CRAWL.
whole pr0n siteTry loading 460+ webpages
I would love to read this but it is unfortunately not in a language I understand.![]()
AMD Ryzen 5 5600G en Ryzen 7 5700G Review - Eindelijk moderne Ryzens met igpu
Met de Ryzen 5 5600G en Ryzen 7 5700G heeft AMD eindelijk weer een aanbod van desktop-processors met een geïntegreerde gpu. Bekijk onze uitgebreide benchmarks!tweakers.net
There are a few ways to turn it in a language you understand.I would love to read this but it is unfortunately not in a language I understand.
My Ryzen 7 5700G has arrived.
I see it says "Unlocked" on the BOX, should be unrestricted to use with PBO unlike the PRO variants you could get prior generation.
100-000000263
EF 2126SUS
XXXXXXXXXXXXXXXXXX
DIFFUSED IN TAIWAN
MADE IN CHINA
Week 26 2021.
EDIT:
It is unlocked.
ALL PBO settings are in the AMD_OVERCLOCKING section of the BIOS.
All the ones that one needs for PBO to work properly.
A PRO 4650G was missing all these.
Short answer, YES.interesting to see how it goes.
in this review, 锐龙7 5700G/锐龙5 5600G首发评测:性能飞升、功耗更惊喜
It mentioned 5700G PBO tops out at 100w, 83c with cheap T612 tower cooler and all cores 4.65Ghz
5600G PBO tops out at 73W, 77c with the same T612 tower cooler and all cores 4.45Ghz.
I wonder if you can manually push PBO to a higher TDP and the autoOC +200
