Last Updated: November 21, 2020
AMD Radeon® RX 6800 XT
RX 6800 ⠀⠀ Owner's Club
→ RX 6800 XT Owner's Club⠀
RX 6900 XT Owner's Club
SPECS (Click Spoiler)
Rich (BB code):
Architecture RDNA2
Chip Navi 21 XT
Transistors 26,800 million
Die Size 536 mm²
Manufacturing Process 7nm
Stream Processors 4608
TMUs 288
ROPs 128
Compute Units 72
Ray Accelerators 72
Core Clock 2015 MHz
Boost Clock 2250 MHz
Memory 16GB GDDR6
Memory Bus 256-bit
Memory Clock 2000 MHz / 16000 MHz
Memory Bandwidth 512 GB/s
External Power Supply 8 + 8 Pin
TDP 300W
DirectX 12.2 Ultimate
OpenGL 4.6
OpenCL -
Vulkan 1.2
Interface PCIe 4.0 x16
Connectors 1x HDMI 2.1, 2x DisplayPort 1.4a, 1x USB-C with DisplayPort 1.4a
Dimensions (LxWxH) 267 x 120 x 50 mm (2.5-Slot)
Price $649 US
Release Date November 18, 2020
Rich (BB code):
RX 6900 XT | Navi 21 XTX | 7nm | 536mm² | 26.8 BT | 5120 SPs | 320 TMUs | 128 ROPs | 80 CUs | 2250 MHz | 16GB | 2048MB x 8 | GDDR6 | 256-bit | 512 GB/s | 300W
RX 6800 XT | Navi 21 XT | 7nm | 536mm² | 26.8 BT | 4608 SPs | 288 TMUs | 128 ROPs | 72 CUs | 2250 MHz | 16GB | 2048MB x 8 | GDDR6 | 256-bit | 512 GB/s | 300W
RX 6800 | Navi 21 XL | 7nm | 536mm² | 26.8 BT | 3840 SPs | 240 TMUs | 96 ROPs | 60 CUs | 2105 MHz | 16GB | 2048MB x 8 | GDDR6 | 256-bit | 512 GB/s | 250W
RX 5700 XT | Navi 10 XTX | 7nm | 251mm² | 10.3 BT | 2560 SPs | 160 TMUs | 64 ROPs | 40 CUs | 1980 MHz | 8GB | 1024MB x 8 | GDDR6 | 256-bit | 448 GB/s | 235W
RX 5700 XT | Navi 10 XT | 7nm | 251mm² | 10.3 BT | 2560 SPs | 160 TMUs | 64 ROPs | 40 CUs | 1905 MHz | 8GB | 1024MB x 8 | GDDR6 | 256-bit | 448 GB/s | 225W
RX 5700 | Navi 10 XL | 7nm | 251mm² | 10.3 BT | 2304 SPs | 144 TMUs | 64 ROPs | 36 CUs | 1725 MHz | 8GB | 1024MB x 8 | GDDR6 | 256-bit | 448 GB/s | 180W
RX 5600 XT | Navi 10 XLE | 7nm | 251mm² | 10.3 BT | 2304 SPs | 144 TMUs | 64 ROPs | 36 CUs | 1560 MHz | 6GB | 1024MB x 6 | GDDR6 | 192-bit | 288 GB/s | 150W
RX 5600 | Navi 10 XE | 7nm | 251mm² | 10.3 BT | 2048 SPs | 128 TMUs | 64 ROPs | 32 CUs | 1560 MHz | 6GB | 1024MB x 6 | GDDR6 | 192-bit | 288 GB/s | 150W
The RX 6800, RX 6800 XT and RX 6900 XT share the same PCB design. The AMD Reference PCB (2x8-pin) has room for 6 power stages on the left and 10 power stages on the right, with ? of them allocated for memory. This means that the RX 6900 XT reference PCB has a maximum of ?? power stages for the GPU.
AMDMSRP | Model | Length | Slot | Fan | HDMI | BIOS | Power | Stages | Power Limit | Boost | PCB | PWM | EAN | PN |
$649 | Reference | 267mm | 2.5 | 3 | 1 | 1 | 2x8-Pin | 16 | 300 W | 2250 MHz | Reference |
ASROCK
Phantom D OC | 330mm | 2.8 | 3 | 1 | 1 | 3x8-Pin | Custom | |||||||
Taichi X OC | 330mm | 2.8 | 3 | 1 | 2 | 3x8-Pin | Custom |
ASUS
TUF OC | 2.6 | 3 | 2 | 2x8-Pin | 90YV0FM0-M0NA0 | |||||||||
Strix OC | 2.8 | 3 | 2 | 2x8-Pin | ||||||||||
Strix LC | 2 | Hybrid | 2 | 2x8-Pin | 90YV0FL0-M0NM00 |
GIGABYTE
Gaming | 3 | GV-R68XTGAMING-16GD | ||||||||||||
Gaming OC | 3 | GV-R68XTGAMING OC-16GD | ||||||||||||
AORUS Master | 3 | GV-R68XTAORUS M-16GC |
MSI
Gaming X Trio | 3 | 1 | 1 | 2x8-Pin |
POWERCOLOR
Red Devil | 3 | 2 |
SAPPHIRE
Pulse | 313mm | 2.7 | 3 | 1 | 2 | 2x8-Pin | Custom | 11304-03-20G | ||||||
Nitro+ OC | 310mm | 2.8 | 3 | 1 | 2 | 2x8-Pin | Custom | 11304-02-20G | ||||||
Nitro+ OC SE | 310mm | 2.8 | 3 | 1 | 2 | 2x8-Pin | Custom | 11304-01-20G |
XFX
Merc 319 |
TECHPOWERUP | GPU-Z
TechPowerUp GPU-Z
OVERCLOCKING | TOOLS
AMD Adrenalin
ASRock Tweak
ASUS GPU Tweak II
Gigabyte AORUS Engine
MSI Afterburner
PowerColor (Non Available)
SAPPHIRE TriXX
XFX (Non Available)
QUESTIONS | FAQ
TechPowerUp GPU-Z
AMD Adrenalin
ASRock Tweak
ASUS GPU Tweak II
MSI Afterburner
SAPPHIRE TriXX
XFX (Non Available)
QUESTIONS | FAQ
Question: ...
Answer: ...
