You could say so, I guessCould not get tWTRL=6 to boot whatever settings i tried.
But i managed to lower tRAS by 1 to =22 -> tRC=34 -> tRFC=221
Is this the correct formula to calculate tRFC, do this look okai ?
Do you have a very bloaty windows install ? Everytime i see a screen with ~800mb used in the start of TestMem.. 800*32= is only 25.6 gigs.
When i start testmem with chrome with 20 tabs and lots of other programs open in background, i get something like ~912*32
How much stuff do you have running after windows restart ?
This is how my windows looks 2minutes after restart: (need 2mins to start everything in background)
View attachment 2527503 View attachment 2527505
Btw, i found SCL=4 to be faster then SCL=2 in dram calc bench.
SCL=2 gives lower read speed but higher write, but in the end SCL is faster.
Get 100% the same with asus bios also..
Very hard to test the differences at this point, but i think the fastest on my setup is:
tRDRDSD=4
tRDRDDD=2
tWRWRSD=6
tWRWRDD=4
Believes it gives a little higher write speed then 4/4/6/6
well, that was my knowledge based on what people said over on reddit (useless) but also that github overclocking guide. i guess it makes sense that if B-Die can run higher than "suggested" voltages then others can too.Hearing for the first time, that it's dangerous to run X voltage for Y test (for memory)
I daily 1.65v, it was a good sweetspot.
Can pick between 1.64-1.69v. Afterwards the ICs hardcrash
On Rev E till 1.72v before they hardcrash, but haven't notice any positives in running it beyond 1.66v
A0 PCB didn't like anything beyond 1.54v
It was dangerous to keep pushing it and lost memory channels
Then RTTs where remade/redesigned & i can daily higher voltage
But voltage ≠ Amperage arriving
Soo VDIMM ≠ Heat , not directly
1.65v set runs cooler to the touch than 1.51v at "old public RTTs"
Also as voltage helps , i see no reason not to run it
Couldn't extend so far beyond 1.69v. No RTT combination
Couldn't change RTT_WR to something stronger either.
EDIT:
All examples are stability oriented
XOC and Suicide-Runs (scores), are another topic
I don't participate in such![]()
Not to argue which config is better, I just wanna say the following:hence the reason I use 1usmus v3 config, as so far this is the only config that gives us an inkling on where we should be looking to change things to stop memory errors.
Very small margins.. Done at static allcore OCBest test for compare - corona benchmark.
WTRL=7
Running a sophia script slimmed windows@domdtxdissar have you cut down on Windows services as well?
I get error in 6 and 12 so those aren't related to your config I guessmongoled
Tm5 can detect only three kinds, but each timing separately.
Personally, the config 1usmus is enough for you.
You deserve it.
I don't think it's ego, just language barrier. Guy means the errors outside of what he listed are the same as the other configsWhy thanks for leaving your ego on the table....
And subsequently telling anyone who has not worked out your error codes as being stupid.
Maybe thats why you decided not to answer the question
Thank you anta777. How many cycles of this should we be running?My new config for tm5 - absolut.
For 6-core processors time in main section in config need to increase 1750%.![]()
absolutnew.cfg
bit.ly
@anta777TimeDrapery
I hope.
@anta777TimeDrapery
I hope.
For 8-12-16 cores 1250% is fine? Why only a diffrence for 6?For 6-core processors time in main section in config need to increase 1750%.
Just a quick question, should all DDs be 1 if we're using 4 sticks? And then all DD = SD? Just trying to figure out what else I can reduce hereOk, only primary timings and tRFC - 3 cycles test, another enough 1 cycle.
