3.80 beta is out: ASRock X570 Taichi
This is the results of me running CB20, you can see the max temp i hit 84C, im using a Krakenn X60 aio.Sorry about that, regarding the testing I should have specified the "Twitter" link I first gave about not having enough context.
Regarding the Kit Guru test, I believe the 82 pertains to stock settings so no PBO and such activated. Have you tried the 5800x stock? If I remember correctly you do have it with the PBO2/Curve optimizer. The bios situation for x570 in general seems super beta at the moment. I'm happy with my performance though my chip(5900x) is not as saturated as the 5800x which may help. My experience with stock is cooler by at least 3-5c while the curve optimizer adds about 5c into the mix.
I do think using the test is fine since you are checking for stability though the temps may be high. It may be best to inquire from other 5800x users in the forum, reddit, etc. to see how others are faring with similar set-up.
Haha, they definitely picked the right crowd. I feel we need more transparency from Asrock to verify bios settings /changes.On another note, i was watching a video on PBO2 last night, and caught a comment from AMD Rob i had never heard before. It seems we who own Taichi X570 and a few other companys motherboards are selected by AMD to have early access to bios updates, agessa versions, etc. Our boards and the companies we deal with are hand selected. Kind of cool that they know we bought our boards with this ideal in mind, that we love to play with them, and jump on the leading edge to test these things out. I saw 3.8 was released, and of course, i have an itch now to test it out.
I think they picked the right crowd lol
Temps wer maxed out on multi, on single is hovers around 50ish, which is a good sign for pbo2, stock settings, only my ram was touched for the making of this benchmark, no cpu's were harmed lolHaha, they definitely picked the right crowd. I feel we need more transparency from Asrock to verify bios settings /changes.
Regarding your CB20 run, is that a stock configuration or did you adjust pbo/PBO2 or OC? Was that temp during multi or single?
Sent from my SM-N986U1 using Tapatalk
Still playing around with 3.67 so haven't hopped on that yet lolAnyone tried the latest bios 3.80 for Taichi x570 ? Please someone gives some feedback , i will not be home for several days and cannot test myself. I have already gave my feedback on the older Bios. Please post your findings with this new 3.80 Bios , thank in advance.
Kind Regards: Chispy
I’m in the middle of a render so i can’t try it yet. I see it’s still AGESA 1.1.0.0 and not 1.1.8.0 which is supposed to launch PBO2, though.Anyone tried the latest bios 3.80 for Taichi x570 ? Please someone gives some feedback , i will not be home for several days and cannot test myself. I have already gave my feedback on the older Bios. Please post your findings with this new 3.80 Bios , thank in advance.
Ya i saw that too, i was hoping its a typo. Well, i went to have a look and this is what it says "Update AMD AGESA ComboAM4v2 1.1.0.0 Patch D ", so i guess it isnt PBO2 yet. Im going to install it tomorrow and play around in there, ill report back.I’m in the middle of a render so i can’t try it yet. I see it’s still AGESA 1.1.0.0 and not 1.1.8.0 which is supposed to launch PBO2, though.
I thought curve optimizer was pbo2? LolYa i saw that too, i was hoping its a typo. Well, i went to have a look and this is what it says "Update AMD AGESA ComboAM4v2 1.1.0.0 Patch D ", so i guess it isnt PBO2 yet. Im going to install it tomorrow and play around in there, ill report back.
Which chip are you using? 5900x here, I've played around with curve and certain cores, top 2 in ccd1 hit 4950 here and thereTested the Bios, it runs very smooth for me. Curve Optimizer or pbo2 doesnt work for me. It just boosts up to 4,6 max . We need to wait for newer Agesa I think. IF is still 1900. Everything above that will just not boot anymore. But other than that it works as good or better than the 3.61 one. Im sticking with my 4,725 allcore overclock at 1,3v for now. Hopefully the 1900 IF wall breaks soon. I think my cpu can handle 2000 or even higher.
Hope that helped you guys. In my opinion you should just wait for the agesa 1.0.8.0
Im using also a 5900x.Which chip are you using? 5900x here, I've played around with curve and certain cores, top 2 in ccd1 hit 4950 here and there
I watched a good video from Rob at AMD the other might about using PBO2 and curve optimizer, i made a copy of this slide "tips and tricks".Which chip are you using? 5900x here, I've played around with curve and certain cores, top 2 in ccd1 hit 4950 here and there
To be clear on my side, not necessarily all the cores go up for Multi-Threaded task. They'll hit 4300-4400 for all core then only the top 2-3 cores will hit 4900+ for Single Core. All I can say is the scores below are better than stock. Stock I would get 7900-8100 Multi and Single from 600-612.Im using also a 5900x.
But its not working properly yet. I cant see several cores go all the way up.
From my experience adding to boost override didn't really do anything for me so left it 0. Regarding scalar, just left it at auto for stability sake.I watched a good video from Rob at AMD the other might about using PBO2 and curve optimizer, i made a copy of this slide "tips and tricks".
This is the recomended starting point for your settings when using it. I feel this is very important to get it to work the way it is intended to work.
When i saw you BIOS settings, it poped out at me when i saw your "max boost clock overide" setting.
Btw, how did you come to choosing negative and -15 on one ccx and -20 on the other ccx? Were these just random attempts, or chosen for a reason, thanks for any info.
I also think AMD AGESA ComboAM4v2 1.1.0.0 Patch D is 1.8.0.0 minus maybe a few other bios tweeks not related, because why would it have been incorporated into the bios if not functional, and AMD has said, you cannot use PBO2 unless 1.8.0.0 is installed. Also jumping up to naming it 3.80 from 3.67, tells me this is a viable release,
I tested AGESA 1.1.0.0 on AQUA and found no artificial limit with FCLK, my 5950X does 2100 no sweat with easy volts. I will try and test soon with TAICHI and confirm if the fabric has some sort of artificial limit.Tested the Bios, it runs very smooth for me. Curve Optimizer or pbo2 doesnt work for me. It just boosts up to 4,6 max . We need to wait for newer Agesa I think. IF is still 1900. Everything above that will just not boot anymore. But other than that it works as good or better than the 3.61 one. Im sticking with my 4,725 allcore overclock at 1,3v for now. Hopefully the 1900 IF wall breaks soon. I think my cpu can handle 2000 or even higher.
Same issue with Taichi here with Bios 3.80, good board overall, IF 1900 OK, IF > 1900 wouldn't run with my 5600X... hope ASRock could figured it out soonI tested AGESA 1.1.0.0 on AQUA and found no artificial limit with FCLK, my 5950X does 2100 no sweat with easy volts. I will try and test soon with TAICHI and confirm if the fabric has some sort of artificial limit.
