1 - 20 of 1596 Posts
Welcome to The *Official* ASRock X79 Discussion & Owners Club!
:D
Calling all owners!!!
I didn't see a thread for us owners, so here it is.
:drool:
I'll be adding and updating information regularly.
Owners sign up in the second Post!
Post up your CPU-Zs, overclocks, benchmarks, specs, questions, info, help, advice, or anything else to help show off your system and share your experiences with your ASRock X79 Motherboard.
Enjoy!
Our Club includes The ASRock's X79 Fatal1ty Champion, Fatal1ty Professional, Extreme11, Extreme9, Extreme7, Extreme6/GB, Extreme6, Extreme4, Extreme4-M, & Extreme3 Motherboards.
:yessir:
_______
Fatal1ty X79 Champion
In Progress
_______
Fatal1ty X79 Professional
_______
X79 Extreme11
In Progress
_______
X79 Extreme9
27FEB12 - Hardware Canucks
14FEB12 - Hardware Secrets
13FEB12 - Legit Reviews
09FEB12 - Hardware
09FEB12 - HardOCP
24JAN12 - AnandTech
05JAN12 - The SSD Review
04JAN12 - KitGuru
23DEC11 - TweakTown
16DEC11 - eTeknix
_______
X79 Extreme7
In Progress
_______
X79 Extreme6/GB
_______
X79 Extreme6
04MAR12 - OCDrift
_______
X79 Extreme4
13FEB12 - Motherboards
23JAN12 - Hexus
12JAN12 - HardOCP
11JAN12 - Bit-Tech
09JAN12 - LenzFire
16DEC11 - TweakTown
09DEC11 - AnandTech
30NOV11 - OCaholic
23NOV11 - eTeknix
_______
X79 Extreme4-M
11JAN12 - KitGuru
11JAN12 - OCaholic
05JAN12 - Overclockers
23DEC11 - PureOC
20DEC11 - TweakTown
16DEC11 - Bit-Tech
09DEC11 - AnandTech
25NOV11 - Vortez
_______
X79 Extreme3
In Progress
_______
_______
_______
Please copy this in to your signature to show your support and help fellow owners find their way here. Thank you.
[URL=http://www.overclock.net/t/1224285/the-official-asrock-x79-discussion-owners-club][B][I]The *Official* ASRock X79 Discussion & Owners Club[/I][/B][/URL]
_______
Special thanks to coolhandluke41 for this banner!
Special thanks to Cylas for the X79 Extreme11 & Fatal1ty X79 Champion Pictures!
To all of the "nay sayers", "fanboys", and "haters", ASRock Slides into 3rd Place in Channel Motherboard Market Share!
That's correct. What exactly does that mean, you ask? They are ahead of Biostar, ECS (Elitegroup), EVGA, Foxconn, Intel, JETWAY, MSI, and ZOTAC, among others.
Before you decide your old attitude about ASRock is legit, you may want to reevaluate it.
Well, hello there...
Originally Posted by rctrucker View Post
I signed up!
I wish I had waited for Jon's version of the board to come out
EDIT: I forgot to say first.
Awesome, welcome! I'm looking forward to see what the higher end boards are capable of.
The Extreme11 will be out soon as well.
Originally Posted by Stiltz85 View Post
Sure, I'll sign up. I have an Extreme4-M.
Welcome aboard!
If you would click the sign up sheet and add your details, that would be great!
Gotcha, Just skimmed through my first time and missed it.
I appreciate it.
Let me start by saying this is not an issue that involves a Raid boot/windows drive.
Last night I spent a few hours trying to get my 2 500gb western digital drives in raid0 (Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s)
I am booting from an OCZ Agility 3 SSD, in the 6gbs SATA port 0 without any issues there, but when I went back to bios after installing win 7 ult 64bit and all of my motherboard drivers.
In the bios I changed the SATA function to RAID after plugging my 2 WD 500's into the 3gbs (ports _0 and _1). Reboot, and hit CTRL+I to open the configuration utility, set both drives to raid0, and created one logical drive.
Boot to windows, and windows says that it can not find my raid controller driver. At the same time, my CD/DVD-R drive is not recognized by windows 7 either.
I have installed all of the Win7 updates, tried to manually point windows to the marvel raid drivers found here.
I tried to use different sata ports like M4 + M5, while setting those to raid, but when I attempt that, I cant even enter the Raid config utility during startup.
I caved at about 1am this morning and set up a Raid0 stripe through windows 7
. (which is last resort because I haven't herd of them being very stable at all)
Anything I'm not thinking of to try? Anyone else had this issue?
2.23 Installing Windows® 7 / 7 64-bit / VistaTM / VistaTM 64-bit With
RAID Functions
If you want to install Windows® 7 / 7 64-bit / VistaTM / VistaTM 64-bit OS on Intel®
SATA2 / SATA3 ports with RAID functions, please follow below steps.
STEP 1: Set up UEFI.
A. Enter UEFI SETUP UTILITY Advanced screen Storage Confi guration.
B. Set the option "SATA Mode" to [RAID] for Intel® SATA2 / SATA3 ports.
Set the option "Marvell SATA3 Bootable" to [Yes] for Marvell SATA3 ports.
STEP 2: Use "RAID Installation Guide" to set RAID confi guration.
Before you start to confi gure the RAID function, you need to check the installation
guide in the Support CD for proper confi guration. Please refer to the document in
the Support CD, "Guide to SATA Hard Disks Installation and RAID Confi guration",
which is located in the folder at the following path:
.. \ RAID Installation Guide
STEP 3: Install Windows® 7 / 7 64-bit / VistaTM / VistaTM 64-bit OS on your
system. The optical drive should be installed on an non Intel® SATA2
/ SATA3 port.
Insert the Windows® 7 / 7 64-bit / VistaTM / VistaTM 64-bit optical disk into the optical
drive to boot your system, and follow the instruction to install OS on your system.
When you see "Where do you want to install Windows?" page, please insert our
Support CD to your system, and click the "Load Driver" button to load Intel® RAID
drivers. Intel® RAID drivers are located in the following path of our Support CD:
32 bit: ..\i386\Win7_Vista_Intel_v3.0.0.1112
64-bit: ..\AMD64\Win7-64_Vista64_Intel_v3.0.0.1112
After that, please insert Windows® 7 / 7 64-bit / VistaTM / VistaTM 64-bit optical disk
into the optical drive again to continue the OS installation.
That's from page 63 of the manual. It seems you can't setup that kind of RAID, unless you're doing it during a Win7 install. Also, your optical drive can't be connected to any SATA2 or 3 port. I've also read this somewhere else. Seems strange, but that's how it worked elsewhere as well. Hope this helped.
Discussion Starter · #9 ·
I was actually able to accomplish this when I replaced my 2 500gb HDDs and got 2 1TB drives (steal off ebay for $100 new).
I installed the hard drives into the M2/M3 ports (my SSD on the M0 port), I then booted into the bios and enabled raid for the M2/M3 AND also enabled bootable raid controller for these drives.
When booting I hit "m" to setup the raid through marvell, booted to windows and formatted the drives. Boot times were slow because of how long it would take to start both of the bootable drivers(this happens before the bios even starts.
So I went back into the bios and disabled the bootable M2/M3, for my raid. I cannot boot from this raid, which I don't need because of the SSD, but I can use it in windows, and will retain it if I format windows.
:D
I'm glad you got it worked out. Good buy there.
Makes much more sense now. I'm glad you posted the working results to help the next person out.
Bump for more owners!
Diggity bump!
Add me to the list! Just received my Extreme 6/GB and Intel 3820!!!!!!!!!!!!!!! So excited!
Now I just need my new case to arrive to start a buildlog!
Subed. May be getting one of these in the near future with a i7 3820.
As great as Ivy Bridge is I just don't feel like moving from one dead socket (775) into another dead end socket (1155).
I thought the Ivy Bridge was avail for the 2011 socket?
Ivy Bridge - E is and that won't be out till at earliest the end of the year. Whatever comes after Ivy is going to be on a new socket, 1150 I think.
I wouldn't expect too many people to jump into this thread too fast, ASRock is not the most "in demand" manufacturer. Not to mention the price of X79 builds, the crowd is thin but give it time.
There's plenty of folks here on OCN that can afford many builds and see ASRock as the newest up and coming board to use. I have faith.
It seems like they are doing well, they pack a lot of goodies in for the price.
Ain't that the truth.
Welcome! Awesome to have you!
It's self sign up on the second post.
It'll be nice to see another ASRock build log!
The LGA1366 is dead too, but still kickin' in many builds.
It'd be nice to see another owner soon.
Don't let the socket problem get ya down. They always die every few years.
This is OCN!
Buy it like it's hot!
lol
This is OCN!
lol
After seeing the 3770k overclocked benchmarks I've pretty much made my decision. I should be ordering in the next month or two. I'll be sure to take lots of pics.
An Extreme 6/GB + 3820 are looking extremely appealing.
