whats your choice for 990fx
1 - 20 of 10186 Posts
8th gen...
Motherboards:
ASUS Sabertooth 990FX
ASUS Sabertooth 990FX R2
ASUS Sabertooth 990FX/GEN 3 R2
Requirements to gain Verified status:
Must have a Cpu-z validation matching your OCN username
follow all OCN rulles
and please stay relativly on topic*
* If it portains to your motherboard, overclock, system in general, or a question about a previous post or a question about the motherboard in general its ok, but just to make a point this thread isnt where you tell everybody what your dog had for lunch today:D
Click here to add yourself to the owners list
https://docs.google.com/spreadsheet/pub?key=0AuRCaZr2OwCTdFhCTFQ4WUxhd2pRbjJPSklaeURiZXc&output=html&widget=true
Important notes:
There is a clear sticker over the south bridge heat sync that may be unseen but its there be sure to remove it as it holds in heat!!!
Windows 8 drivers for Sabertooth R1:
JMicron Controller Driver:
ftp://driver.jmicron.com.tw/SATA_Controller/Windows/JMB36X_WinDrv_R1.17.65_WHQL.zip
ASmedia USB 3 Driver:
https://www.box.com/s/vnb9zxaip364nnb6qlcq
Cooks Info On ECC vs non ECC ram:
http://www.overclock.net/amd-motherboards/1035333-official-asus-sabertooth-990fx-owners-club-100.html#post15370182
ASUS Drivers, utilities and docks can be downloaded here:http://www.asus.com/Motherboards/AMD_AM3Plus/SABERTOOTH_990FX/#download
The first AMD motherboard... to enable SLI on an AMD chip-set...
Thanks to the easy to understand UEFI Bios, the easy to spot problem lights, the mem ok button, the built in thermal sensors and user controllable 6 fan headers, this board is not only expensive, its great for overclocking!! All these features flow perfectly together and thanks to the ease of this bord (and a little help from OCN member bradford1040) I went from a beginner overclocker to an intermediate overclocker almost literally over nite!!
I have never been one to get too impressed by a motherboard in the past however I'm willing to comfortably say I'm impressed, dollar for dollar this was an excellent purchase that i believe I'll be satisfied with for a good long time, if you feel the same way and own this board join the club, we would be glad to have you.
http://valid.canardpc.com/show_oc.php?id=1965113
sig codes
[CENTER][URL="http://www.overclock.net/amd-motherboards/1035333-asus-sabertooth-990fx-fan-club.html"]:rambo:[FONT=System][B][COLOR=DarkGreen]The OFFICIAL[/COLOR][COLOR=DarkRed]AMD [/COLOR][COLOR=olive] Sabertooth Owners Club  [/COLOR][/B][/FONT]:rambo:[/URL][/CENTER]
AMD Saber Tooth owners club
[URL="http://www.overclock.net/amd-motherboards/1035333-asus-sabertooth-990fx-fan-club.html"][CENTER]:sozo:[FONT=System][B] AMD  Saber  Tooth  owners club    [/B][/FONT]:sozo:[/CENTER][/URL]
[CENTER][URL="http://www.overclock.net/amd-motherboards/1035333-asus-sabertooth-990fx-fan-club.html"]:rambo:[FONT=System][B]AMD 990FX SaberTooth Owners Club[/B][/FONT]:rambo:[/URL][/CENTER]
Reactions: Nocturnal91
I installed my Sabertooth today using all the same components in my sig. The new BIOS is nice but I'm not used to it so I haven't tried overclocking yet. I noticed the Hard disk score in Windows experience index went from 7.3 to 7.6 since I installed this board.
oh yea...... ADD ME
8th gen...
oh yea...... ADD ME
in the bios there is a feature in the overclocking section of the advanced bios that will scan and apply an automatic overclock... from there you should be able to raise to 4ghz+ without even touching the voltage... adding you to members list:)
8th gen...
nice to see a few people joining so soon:)
Originally Posted by Bradford1040;13802633
do me a fav. after you get up and running tell me how well over the CH:IV it does, and also what hold down is that? does not look like a h70?
I will when I get my case back and put back together. I am going to be running the 955 BE, the only thing that will be diffrent from my CH-IV will be the memory, I have 4 gig's in my CH-IV, my Sabertooth will have 8 gig's, I screwed up yesterday when I bought what I thought was 2 sticks of ram, (wrong!) I bought 1 stick of 4 gig's so I had to go buy another 4 gig stick today.
That cooler mount is the XIGMATEK Crossbow Ack Ati775 Mounting Kit for AMD, I did have to find some longer screws (3x25mm) for it though to fit the A-70 cooler, the ones in the kit were too short.
8th gen...
Discussion Starter · #14 ·
Originally Posted by Bradford1040;13803066
I liked that video, I felt as if I made the right choice now, I was thinking I jumped the gun but other than the LAN and 4 way sli the TUF is about the same as ROG in terms of potential OC'ing and in fact mite even be better as far as longevity
thats the way I see it, but I dont understand why the back of my saber box says nvidia quad gpu sli on it
8th gen...
Discussion Starter · #16 ·
Originally Posted by Bradford1040;13803802
dual gpu cards
must be, im also wondering how tey could get that rog 4 way addon for sli to fit in a chasis, the mounting brackets for the pcie cards wouldnt line up
8th gen...
Discussion Starter · #17 ·
8th gen...
Discussion Starter · #19 ·
Originally Posted by capitaltpt;13806705
So the Sabertooth has been deactivated at Newegg......something we should be concerned about?
not to my knowledge ... maybe newegg was just losing money on them and has to crunch some numbers or something... they where offering overnite shiping on them for dirt cheap
either that or nvidia/ati/asus could be having a fight over why the saber currently doesnt support sli at release without a workarround... i dunno
