I see how popular this case is getting, so I decided to make a club. I plan on buying mine later on, but I wont add myself until then
BitFenix Prodigy Owner's Club
The most flexible Mini-ITX case ever
How to enter
just post with the following
ADD ME (bold included, so I do not have to worry about missing one)
Picture of your case/build (this rule will be suspended for preorders, since it isn't out yet)
Color (if preordered, or painted)
In code spoilders: your OCN name with your profile linked and (optional) the name of your build with your build log linked
Example
ADD ME!
[INSERT IMAGE HERE]
Please use spoilers when quoting pictures
Images
Specs
Materials:Steel, Plastic
Colors (Int/Ext): Black/Black, White/White
Dimensions (WxHxD):250 x 404 x 359mm
Internal Dimensions (WxHxD):250 x 310 x 340 = 26.35 liters
Motherboard Sizes:Mini-ITX
5.25" Drive Bays:1 (removable)
3.5" Drive Bays:5 (3 + 2 modular)
2.5" Drive Bays:9 (5 + 2 + 1 +1 )
Cooling Front:120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
Cooling Rear:120mm x 1 (included) or 140mm x 1(optional)
Cooling Top:120mm x 2 (optional)
PCI Slots:2
I/O:USB 3.0 x 2, HD Audio
S2 ATX (bottom, multi direction)
Extras:FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Powersupply fitting guide:
It's been brought to my attention that it is a tedious process to figure out if your PSU, will fit in this case.
So, here is a quickie field guide on ATX psu specification.
The third dimension is the problem with the case, as the PSU cage is only 160mm deep, or 6.23 inches for you imperial folks.
The way dimensions are displayed changes depending on the author of whatever content you are looking at, so, lets take YumYums's PSU that was asked about, the OCZ ZX 850. (note that it is linked if you wish to follow along.
First dimension we can note under details is: 3.39 inches, which is rather close to 3.4, so within tolerance. The next is 5.91 which, again, really close to 6 inches, so the last measurement must be the depth, which is 6.89 inches, which is over 6.23 inches by a small margin. Yums could probably fit this PSU in his case, but remember, the depth does not account for the space needed for fitting wires into the case as well. I personally account 15mm for wires in my cases, but your mileage may vary.
I hope this helps people, and also, if you are unsure, feel free to ask. It is better to ask any annoying question, than spend more money than you need to.
Bitfenix Prodigy Web Page
http://www.bitfenix.com/global/en/products/chassis/prodigy
Reviews
Linus Tech Tips
Time To Live Customs
Owner's List
Feel free to show us progress and share your build log in-post whenever you make progress
Take the Sig!
http://www.overclock.net/content/type/61/id/1149263/
BitFenix Prodigy Owner's Club http://www.overclock.net/content/type/61/id/1149264/
How to enter
Example
ADD ME!
[INSERT IMAGE HERE]
[URL=http://www.overclock.net/u/241812/phillyd]phillyd[/URL] - [URL=http://www.overclock.net/t/1266808]SwitchBox[/URL]
Images
Specs
PCI Slots:2
So, the back of the unit (where the IEC connector attaches too) should be 6 inches by 3.4 inches, within a tolerance (a tolerance is a deviation off of a standardized dimension that will still allow universal function, but not conform exactly to spec)Originally Posted by WikiPedia Article on ATX/EPS Power Supply Standards
Physical characteristics
ATX power supplies generally have the dimensions of 6 × 3.4 × 5.5 (inches) and in metric 150 mm × 86 mm × 140/180/200 mm and share a common mounting layout of four screws arranged on the back side of the unit.
Reviews
Linus Tech Tips
Owner's List
Black
Harshboy
Subcutaneous
longroadtrip - Yin & Yang
explodingorca - Prodigy Extreme
zzzz
Kokin - Kurisu
SortOfGrim
borandi
mwayne5
albear01
digitalm3
CreeperK1d
Semiregular - The Voyager
Duhstin
TheV - Chubby
nerdalertdk
MightyMission
CattleCorn - Cattleprod
Gunderman456 - Pleasure & Angst
a51alias
Paul McC
K4RIMIN4L
Qrchak
ayen46
Jaacckk
MrKay
BuToNz
GrimNights
Venlaw
Ferling
Bratman
phillyd - Pride and Prodigy
BKinn
CSCoder4ever
madrex26
Dmanstasiu - Feed the Dada
fjordiales
handmadeandroid
G18 x UK
Iceco
audioholic
omrheadshoto
xNovax
RandomHer0
barebackbadger
Pestilaence
sivoloc
Neo_182-Quorra Bloodscream
zephead99
Lazy Dog
Chinksicle
ElectroDani - Project Steellow
Tribalnius - SD-HTPC-01
Anoxy - Beemo
Plankton4906
KoolKoney
urbanfreestyle
esberelia
Trilas
nostrata
funnybutrandom
Mechanisation
Emissary of Pain
boy005
infernoRS
TheBigE
theDARKW0LF
mshaddix
AntiStupid
Wera
Dr Slaughter
ensteinfrank
PCSarge
huzzLEE
HavocInferno
Assyle
Homeronte
xr1st1anos
Drifbau5
Latezen
JebusChytrus
plankersz
Daggi
tasdefleja
Seban
Aquillian
vieuxchnock - prodigy-g1-killer
mistermenphis22
vtecless
underdog1799
sascha1102
Equil0x
White
randomnerd865
Dilyn
seg//fault - Build Log
benstark
N10248
SecretLibrarian
Father Fuzzy
vAro
johnnyw
Zerosleep
motokill36
SherwoodForest
jackofhearts495 - Not Quite White
fireisdangerous
Zero383 - Liquid Prodigy
Lizard-Brain - Chinook
SalisburySteak
snackman
kebab
rlstoppler
radarjam - Snow Radar
mcdogi - my bitfenix prodigy build
ElevenEleven
darkwarr
RidicUlust
itsamemario666
Vowels
bdenpaka
Nizzzlle
Alfaa
Sassanou
PanicHunter
tokbachok
XxSkulTorzXx
Tacdise
saber101
EpicPie
adamski07 - MATX, SLI, Watercooled and more!
golfergolfer - Not "Just" Another Prodigy Mod
bobbavet - The "Silent but Deadly" Prodigy
dizzledon
Soulbrandt
MrMacheesemo
SonofJor-El - Fortress of Solitude
blazed_1
Fateman
Sixt
C A M C
basumba01
Yakikuze
Chicklet - Hello Kitty Prodigy
Dmz96 - Aura's Blaze
gogosto
renrenderla
ArtX38 - Prodigy Mirror
chrislegend - Frost
euf0ria
usop8290
jerson25
rocktim
RyReZar
majaboll
babis
saxovtsmike
sivoloc
kyle1970 - Dashie
kimbernator
xxlawman87zz
Jakestax
AusH20BF
cr4p
ChloesDad
gogosto
JaYJoe84
kevin25
ICJI
Beno619
saxovtsmike
bobsaget
adriangb
DrWit
Thedankcrow
timerwin63
Drerex
cdnGhost
bclk
JayKthnx
ccRicers
kamikazemonkey
dudeyouresocool
M4ng03z - Blue Jay
Rakuun
Red
kabeza
MrSharkington
Gup133
kylelols
Orange
Scorpion49
TeamBlue
w3rw01f
LaughterJones
Skrumpi
g00gle88
Crabdude
ejic
SirClx
Green
Sasquatchiii
TommyMoore
MikeTheTiger
doubleyouare
http://www.overclock.net/u/396440/epicsniperz23[/URL] - http://www.overclock.net/t/1471845/build-log-orion-mk-1-green-bitfenix-prodigy[/URL]
Modded (color only)
CharleyBwoy (orange) - Clementine
Michalius (black and baby blue)
SniperTeamTango - Project Michelle (UltraViolet Purple)
CTrak - Mrs. T's Prodigy - (Tiffany Blue)
Harshboy
Subcutaneous
zzzz
Kokin - Kurisu
SortOfGrim
borandi
mwayne5
albear01
digitalm3
CreeperK1d
Duhstin
TheV - Chubby
nerdalertdk
MightyMission
a51alias
Paul McC
K4RIMIN4L
Qrchak
ayen46
Jaacckk
MrKay
BuToNz
GrimNights
Venlaw
Ferling
Bratman
BKinn
CSCoder4ever
madrex26
fjordiales
handmadeandroid
G18 x UK
Iceco
audioholic
omrheadshoto
xNovax
RandomHer0
barebackbadger
Pestilaence
sivoloc
zephead99
Lazy Dog
Chinksicle
Anoxy - Beemo
Plankton4906
KoolKoney
urbanfreestyle
esberelia
Trilas
nostrata
funnybutrandom
Mechanisation
Emissary of Pain
boy005
infernoRS
TheBigE
theDARKW0LF
mshaddix
AntiStupid
Wera
Dr Slaughter
ensteinfrank
PCSarge
huzzLEE
HavocInferno
Assyle
Homeronte
xr1st1anos
Drifbau5
Latezen
JebusChytrus
plankersz
Daggi
tasdefleja
Seban
Aquillian
mistermenphis22
vtecless
underdog1799
sascha1102
Equil0x
White
randomnerd865
Dilyn
benstark
N10248
SecretLibrarian
Father Fuzzy
vAro
johnnyw
Zerosleep
motokill36
SherwoodForest
fireisdangerous
SalisburySteak
snackman
kebab
rlstoppler
ElevenEleven
darkwarr
RidicUlust
itsamemario666
Vowels
bdenpaka
Nizzzlle
Alfaa
Sassanou
PanicHunter
tokbachok
XxSkulTorzXx
Tacdise
saber101
EpicPie
dizzledon
Soulbrandt
MrMacheesemo
blazed_1
Fateman
Sixt
C A M C
basumba01
Yakikuze
gogosto
renrenderla
chrislegend - Frost
euf0ria
usop8290
jerson25
rocktim
RyReZar
majaboll
babis
saxovtsmike
sivoloc
kyle1970 - Dashie
kimbernator
xxlawman87zz
Jakestax
AusH20BF
cr4p
ChloesDad
gogosto
JaYJoe84
kevin25
ICJI
Beno619
saxovtsmike
bobsaget
adriangb
DrWit
Thedankcrow
timerwin63
Drerex
cdnGhost
bclk
JayKthnx
ccRicers
kamikazemonkey
dudeyouresocool
M4ng03z - Blue Jay
Rakuun
Red
kabeza
MrSharkington
Gup133
kylelols
Orange
Scorpion49
TeamBlue
w3rw01f
LaughterJones
Skrumpi
g00gle88
Crabdude
ejic
SirClx
Green
Sasquatchiii
TommyMoore
MikeTheTiger
doubleyouare
Modded (color only)
Take the Sig!
[URL=http://www.overclock.net/t/1279693/bitfenix-prodigy-owners-club][I]BitFenix[/I] [B]Prodigy[/B] [I]Owner's Club[/I][/URL]
