1 - 1 of 1 Posts
Cooler Master Case Rep
Introduction
Inspired by Cooler Master’s former High AirFlow series, the MasterCase H500P has a revamped futuristic look with a structured bar design. Two 200mm fans adorn the front of the MasterCase H500P, providing optimal air flow to maintain ideal operating temperatures. Not just for function, the 200mm fans have been equipped with RGB lighting which can be controlled through RGB capable motherboards or an additional RGB controller. Furthermore, two extra 200mm fans can be installed on the top of the H500P.
A PSU shroud, CPU cut out cover, and additional cable covers take clean cable management to the next level. Users can assemble clean builds like a pro. Two additional PCI slots at the rear enable builders to show off one graphics card in the vertical position. All of this is seen through a light grey tinted tempered glass side panel, ideal for showcasing your build with (RGB) lighting.
Pictures
Specifications
Reviews
1 - 1 of 1 Posts
