What are the chances of one Buying this after reading the thread?
  • 25%
    Votes: 5 23.8%
  • 50%
    Votes: 8 38.1%
  • 75%
    Votes: 8 38.1%
  • 100%
    Votes: 0 0.0%
1 - 20 of 471 Posts
Ladies, One at a Time
Lowest price seen as of yet for monitor (8/16/16) 399.99$ USD
EDIT: 9/29/15
Cannot find Monitor "New" for less than 540.00$ Now on EBAY
Contrast Ratio: 1000:1
Aspect Ratio: 16:9
Brightness: 350 cd/m²
Model: 324K UHD(IRON TRIPOD)
Response Time: 6 ms
MPN: 324K UHD(IRON TRIPOD)
Plug Type: Korean C Type
Display Technology: LED
Voltage: Free volt(100-240V)
Max Resolution: 3840 x 2160
Input:
Model : 324K UHD(IRON TRIPOD)
Panel : AHVA (IPS-type)
Sruface Treatment : Anti-Glare 3H
Panel Size : 81.3Cm (32-type)
Screen size (physical) :708.4(H) X 398.5(V)
Aspect Ratio : 16: 9
Maximum resolution : 3840X2160 @60Hz
Response time : 6ms
Viewing angle : 178 (H) / 178 (V)
Brightness : 350cd / m²
Contrast Ratio : 1,000: 1
DCR : 5,000,000: 1
Pixel size : 0184 mm x 0.184 (per one triad)
Display colors : 1.07G Colors (8-bit+FRC)
Optimum resolution :
Displayport 3840 x 2160 @60Hz
HDMI 2.0 (3840 x 2160 @60Hz)
HDMI 1.4 x 2 (3840 x 2160 @30Hz)
RGB 1920X1080 @60Hz
Input Terminal : DP VER1.2, HDMI 2.0, HDMI 1.4X2, RGB, Audio IN/OUT, SPDIF, USB, DC
Speaker : 10 W x 10W
Power consumption : 49W (maximum), 35W (average), 25W (lowest)
Standby Power : 0.5W
Power supply equipment :
OUTPUT : 24V 2.5A DC
INPUT : 110-240V ~50/60Hz, 1.5A
Stand : 735 (w) x 490 (h) x 200 (d) mm
Without Stand : 737 (w) x 430 (h) x 52 (d) mm
When using the stand : 8.5kg
Without Stand : 7.6kg
Including packaging weight : 12.5kg
VESA specifications : 100x 100mm
CONSTRUCTION of UNIT
Assembly Time: 5-10min.
You have a Phillips Screwdiver for the stand. Stand is 3 Pieces. 2 Legs. The Main body that attaches to the Monitor.
Two above pictures by @ghabhaducha
Info @Bigdream on How to Get to English Settings for OSD Menu
As mentioned by another poster here on the board, setting up the remote for English is fairly straight forward.
1) On the remote, Press the MENU Button
2) From the left column, on the screen, scroll all the way to the last choice using the DOWN arrow button
3) Press OK
4) That will take you to the top of the middle column, the Korean equivalent of the word, Language
5) Press OK
6) Finally, that will jump you over the to third column
7) Highlight English and press OK
Default When Hooked up
Comparison shots Vs QNIX 2710 1440p 27" Monitor
Backlight Diffuser spacing Problem on QNIX UHD3216R
QNIX
Versus the
CROSSOVER
TCO
Going to Do a Review Soon!
Monitor is very sturdy with the Iron Tripod Base. Is Double Boxed upon Mailing to Buyer. Ordered From DreamSeller.
Waves on Steam (Running at 2160P) 120FPS Using a Single 980SC (Doesn't look like SLI is possible in this game)
Rise of the Tomb Raider
(High Preset Bench Mark Test Results)
61 FPS
With AA Set to Tri-linear (Off I guess) 60 FPS
Metal Gear Solid Online (2160p with Low Post Processing, All Set to Very High)
WITCHER 3 (Ultra, 2160P, Postprocessing Low. Hairworks on Geralt)
BF1 BETA 2160p On High Settings (Will Update after game is actually released and Ram Usage is Lower)
FIFA 2017
TCO
Finally an affordable 32"... oddly what I really want is matte though, the semi-glossy ain't cutting it for me (404k). Would also like to know about freesync support.
Hey, guys! This monitor looks pretty cool solution on AHVA... similar to BenQ BL3201PT.
Why there are no any info about it? Is that so bad?
Originally Posted by wildpig View Post
Ordered one. will let you know in a week
Oh, great!) Waiting for news.
My gtx 960 doesn't get here for 4 more days too . Hopefully with expedited international shipping both will be here right on time together. I've been using 2560x1600 since 2010 so I cant wait for the upgrade! Attempt were delayed by about 2 wk as I bought the LG 43UF6430 from BB without knowing about the rgbw pixel as well as buying the 970 without knowing that it does do x265 hardware acceleration. So had to return both and order appropriate hardwares...
So monitor is finally here. Unfortunately my gtx 960 is not here til tomorrow. So I can only test with my old gtx 480 for now...
Currently I can only get 3840 x2160 at 30hz. At elast that's the only highest resolution that gtx 480 would let me set after plugging this into a DP 1.2.
Here're pics
DSCN2693.JPG 735k .JPG file
DSCN2694.JPG 710k .JPG file
DSCN2695.JPG 758k .JPG file
DSCN2696.JPG 661k .JPG file
DSCN2697.JPG 702k .JPG file
DSCN2699.JPG 680k .JPG file
DSCN2700.JPG 732k .JPG file
DSCN2701.JPG 683k .JPG file
Running at full native res 2160p at 30hz, single pixel txt are razor sharp as to be expected in any monitor. I am getting a fair amount of mouse input lag. If if switch to 1440p at 60hz, mouse input lag goes away.
I was able to find 1 bright stuck pixel toward the lower outer left and another at lower outer right screen using a black background. If I am not looking for them, they are completely unnoticeable.... even on the black ground....
Will test HDMI 2.0 and true 2160p60hz once my gtx 960 gets here and installed.
The attached stand stump can be removed if needed. You also get some tilt up and down adjustment and that's all you can do for adjustment...
Any question for now?
Glad to hear you finally received your monitor)
Do you have the possibility to check input lag somehow when you get you GTX960.... in comparison with crt or some any low input lag monitor?
At 30 hz your frames happen every 33 ms, that alone is more than TFT's "class 2" input lag of 15-30 ms, so it may just be the effect of 30 hz.
How is the anti-glare coating? Graininess vs. reflections? Is you room brightly lit or darkened /bias lighting? Can you name other monitor models you can compare to?
Coating looks to me like matte when I shine a flashlight directly at it. No worse or better than my HP LP3065. My room is usually low lit..
Changing to 60hz and mouse input lag gone.
I have tested both the HDMI 2.0 and DP 1.2 at 4:4:4 at 4K 60hz. And they behave the same. Razor sharp single pixel text as expected.
DSCN2704.JPG 682k .JPG file
All in all it's acting just like my HP, which is a good thing.. as that's what anyone buying a monitor is expecting.
Btw this thing also have PIP using multiple inputs, if you are into that..
Any other question?
Just feel a little bumped that the GTX 960 driver doesn't support NVS 450 so I have to remove my nvs. I know I still have several ports left on the gtx but it's not the same. my nvs 450 allows for 4 more 2560x1600 monitors over 4 DP so that is a significant loss ;( .... The gtx 960 driver only support nvs 310, 315, 510, 810... There is no quadro driver package that support gtx 960 either ;(. when I had my gtx 480 running with nvs450, I also had to use an older driver package that supports both. Newer gtx 480 drivers also doesn't support nvs 450.... oh well.. ;(
Well good news for me, I find semi-gloss a bit annoying compared to matte.
Think AMH has a 32 inch 4K that is semi-gloss, so I had to ask...
Is the monitor stand fully tiltable?
There's a fair amount of tilt up/down available... A little stiff.
The OSD menu has a fair amount of adjustments (colors/brightness, etc) compared to HP 3065
The quality of construction is somewhat flimsy. There is some slight flexing to the lower bezel when you try to tilt. Not as well put together as HP 3065
hopefully the few tv that can truly work as monitors can go down to less than 500$ soon as well as more models avail...I don't mind getting an additional 40 in with smart tv....
I am glad to have found this monitor at a reasonable price...
DSCN2706.JPG 714k .JPG file
DSCN2707.JPG 738k .JPG file
OK, so in case someone confirm that this monitor has input lag around 20ms, I will take it as allaround monitor for coding, reading, games and films.
Can you try overclocking it and running a frame skip test here: http://www.testufo.com/#test=frameskipping
Given that it has HDMI and DP inputs, I'm not hopeful, but something higher than 60hz would be awesome.
How are the colors? Look like any other IPS display? Not washed out like a TN panel? How about black levels?
Sorry for all the questions...really debating this vs the Crossover 2795 QHD, which is only 27", 1440p, but also overclocks like a champ.
Might as well try OC but its very unlikely you will get anything out of 4K. Certainly nothing remotely in the range of 1440p.
I am away til sat. will test out that sync thing. will try to create custom res and refresh rate but it doesn't look too hopeful with OC...
Panel color is not washed out.
The easiest way to compare input lag - connect two monitors to same source in dublicate mode, run THIS and take photo of two monitors... and compare time on counter.
Better way to compare lag with CRT monitors because they have 0 input lag.
I do not want to seem annoying. So... just in case you possible to do this)
so you just connect the two monitors in duplicate and start the timer? what exposure time for camera? faster than 1/1000? I still do have a 21 inch crt and its heavy as heck to bring back out but we ll see. I can compare to the hp 3065...
Yep)
connect two monitors to one source;
setup them in repeat mode (two monitors shows same image);
open link;
start timer;
take photo with fast shutter.
And by the photo we can get how one monitor lags behind other.
Better to compare with crt, but 3065 also - ok, because input lag of 3065 ~20ms
Better to take this photo when you get 960, because of scaler and lag that depend of refresh rate.
And sorry again for bothering you with all that staff.
1 - 20 of 471 Posts
