www.fractal-design.com
The concept of Fractal Design is to provide products with an extraordinary level of design, without compromising the important factors of quality, functionality and pricing. Today's computer has evolved into playing a central role in most homes, creating a demand for appealing design of the computer itself and its accessories. Our main product areas are computer enclosures, power supplies and related accessories.
All Fractal Design products have been carefully designed and tested in our Swedish headquarters. The well-known elements of Scandinavian design can be found throughout all of our product lines; a minimalistic, elegant and simple design, embracing the motto of 'less is more'.
Year over year, the Fractal Design brand continues to grow and we pride ourselves on honestly listening to our partners and customers. All feedback is carefully considered and new revisions of products as well as new product line launches are a direct response to the demand and feedback received from the market.
Arc Series
The Arc Series of cases creates a niche of its own through an unparalleled combination of stellar performance and optimized cooling and airflow coupled with Scandinavian style and elegance. Offered in two tower sizes - mini and midi - keeping a performance-driven system cool has never been easier.
Arc Midi R2
The Arc Midi R2 is developed with high-performance computer systems in mind. Featuring three high performance Silent Series R2 fans and ample water cooling options, the Arc Midi R2 layout maximizes airflow throughout the case and keeps even the most demanding systems at cool temperatures. Designed to house even the thickest radiators in both the top and front panels without extensive modifications, the Arc Midi R2 offers all this within a mid size case.
The chassis comes complete with a stylish window side panel, fan controller, easy to clean dust filters, high level of workmanship, flexible hard drive mounting system and plenty of space for cable routing.
Key Features:
Specifications:
Cooling System:
Front Interface:
Key Features:
- Designed with high airflow in mind while consistently holding a minimalistic, sleek look and feel
- Featuring a window side panel to show off your set up in style
- Extensive water cooling support, designed to support thick radiators in the front and top positions
- Three Silent Series R2 fans with integrated fan controller included
- HDD cages are now split 5 + 3 and are both rotatable and removable for maximum configuration and airflow
- Support for up to 8 hard drive bays with accommodation for an additional 2 x 2,5" inch drives behind the motherboard
- Easy installation and configuration with ample cable routing space making it simple for everyone to make a very tidy looking computer build
- Removable fan filters for easy dust maintenance and washing
Specifications:
- ATX, Micro ATX, Mini ITX motherboard compatibility
- 2 - 5.25" bays
- 8 - 3.5" HDD trays - all compatible with SSDs
- 2 - 2.5" additional SSD positions behind the mothboard plate
- 7 + 1 expansion slots
- 7 - Fan positions (3 Silent Series R2 fans included)
- Filtered fan slots in front, top and bottom
- CPU coolers up to 180 mm tall
- PSU compatibility: ATX PSUs up to 170 mm deep when using the bottom fan location; when not using this fan location longer PSUs (up to 270 mm deep) can be used
- Graphics card compatibility: Graphics cards up to 290mm in length with the top HDD cage installed - With the top cage removed, graphics cards up to 430mm in length may be installed
- 26 mm of space for cable routing behind the motherboard plate
- Thick rubber grommets on all holes on the motherboard plate
- Colors available: Black
- Case dimensions (WxHxD): 230 x 460 x 515mm
- Net weight: 10.7kg
- Package dimensions (WxHxD): 320 x 610 x 560mm
- Package weight: 12kg
Cooling System:
- Front: 2 - 120/140mm fans (included is one hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Rear: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Top: 3 - 120/140mm fans (included is one hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Bottom: 1 - 120/140mm fan (not included)
- Fan controller: 1 - Integrated fan controller for up to 3 fans (included)
- Water cooling compatibility:
- Front - 240 mm radiators (thick and slim) when HDD cages are repositioned or removed
- Top - 240 mm radiators (thick and slim)
- Bottom - 120mm radiators
- Rear - 120mm radiators
Front Interface:
- 2 - USB 3.0
- Audio in/out
- Power button with LED (blue)
- HDD activity LED (red)
- Reset button
- Fan controller
More information, photos, and reviews can be found here:
http://www.fractal-design.com/home/product/cases/arc-series/arc-midi-r2
Arc Mini R2
The Arc Mini R2 micro ATX case combines excellent cooling potential and build configurability in a compact, minimalistic and elegant chassis design.
For a case of this size, it offers unmatched possibilities for water cooling components. And with room for up to six 3.5" drives plus an additional two 2.5" drives hidden behind the motherboard plate, you can build a well-cooled PC with ample storage space.
The Arc Mini R2 is built to last and is filled with smart features such as dust filters, fan controller, space for tidy cable routing, three case fans included and a window side panel.
Key Features:
Specifications:
Cooling System:
Front Interface:
Key Features:
- A compact micro ATX case designed for exceptional airflow and cooling
- Superior water cooling support for its size, accommodating multiple thick 240mm radiators or even a 360mm radiator for an uncompromised cool system build
- Three Silent Series R2 fans included, giving you excellent cooling straight out of the box! 4 additional fan positions are available
- Featuring an integrated three-speed fan controller and USB 3.0 on the front panel for easy access
- Multiple easy-to-clean dust filters designed into the case to help maintain a dust free interior
- Great storage capacity for a mini chassis, with up to six 3.5" drives and two additional 2.5" drives
- Innovative SSD position mounting, using brackets to allow for easy access once your system is completely built
- Featuring a large stylish window side panel to show off your set up in style
- Designed with ample space for easy, tidy cable routing and an overall a neat build
Specifications:
- Micro ATX, Mini ITX motherboard compatibility
- 2 - 5.25" bays
- 6 - 3.5" HDD trays - all compatible with SSDs
- 2 - 2.5" dedicated SSD positions behind the motherboard plate
- 4 + 1 expansion slots
- CPU coolers up to 165 mm tall
- PSU compatibility: ATX PSUs up to 170 mm deep when using the bottom fan location; when not using this fan location longer PSUs (up to 220 mm deep) can be used
- Graphics card compatibility: Graphics cards up to 260mm in length with the top HDD cage installed - With the top cage removed, graphics cards up to 400mm in length may be installed
- 20 mm of space for cable routing behind the motherboard plate
- Window side panel included
- Case dimensions (WxHxD): 210 x 405 x 484mm
- Net weight: 9kg
- Package dimensions (WxHxD): 280 x 475 x 565mm
- Package weight: 10kg
Cooling System:
- Front: 2 - 120mm fans (included is one hydraulic bearing 120mm Silent Series R2 fan, 1200 RPM speed)
- Rear: 1 - 120mm fan (included is a hydraulic bearing 120mm Silent Series R2 fan, 1200 RPM speed)
- Top: 2 - 120/140mm fans (included is one hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed) 1 - 120mm fan (not included)
- Bottom: 1 - 120mm fan (not included)
- Fan controller: 1 - integrated fan controller for up to 3 fans (included)
- Front - 240mm radiator (thick and slim) when HDD cages are removed, radiator cannot exceed 275mm in total length with the ODD bay in place.
- Top - 240mm or 360mm radiators (thick and slim); the use of 360mm radiators requires removal of the ODD cage.
Front Interface:
- 2 - USB 3.0
- Audio in/out
- Reset button
- Fan controller
http://www.fractal-design.com/home/product/cases/arc-series/arc-mini-r2
Core Series
The Core Series of cases sits on the foundation of 'less is more'. Offering uncompromised value and optimized building solutions fused with simplistic Scandinavian design makes the Core series of cases a perfect match for budget savvy and enthusiasts alike.
The Core family of cases have always been centered around providing the core features and performance of Fractal Design's case lineage at an aggressive price point. Core has undergone an evolution thanks in part to the valuable feedback from our customers.
The new x3 Series of the Core Family of cases are liquid cooling ready, featuring superb airflow and an innovative vertical drive mounting system. Able to support up to six drives, the unique design of the vertical hard drive bracket ensures that it will not restrict optimum airflow. For added versatility the drive bracket is fully removable, allowing the end user incredible flexibility for mounting liquid cooling radiators up to 280mm in size.
The new x5 Series of the Core Family of cases are liquid cooling ready and combine the power of great airflow with a highly versatile hard drive mounting system. Easily-removable sturdy steel drive trays can support either 3.5" HDDs or 2.5" SSDs and reside inside a relocate-able and fully removable drive cage. This versatility allows the end user the flexibility to custom tailor their case to accommodate the cooling solution they desire without the need to sacrifice storage space. Additional key enthusiast grade features include an integrated fan controller and dual front panel USB 3.0 ports.
Core 500
The Core 500 is the perfect PC case for those looking for a small, compact chassis that lets you build your computer without compromising on component selection.
The case comes with one Silent Series R3 140mm fan which offers great cooling from the get go. For those who wish to expand their cooling ability there is room for an additional two 140 mm fans, water cooling radiators up to 280mm or air coolers up to 170 mm in height.
Additionally, with minimal compromise, the Core 500 can fit one ODD bay, three 3.5"drives and three 2.5" drives, allowing you to use every last square millimeter of this compact, 19.5 liter case.
Key Features:
Specifications:
Cooling System:
Front Interface:
Key Features:
- Brushed aluminum-look front panel with a sleek, three-dimensional textured finish
- Very compact case with a volume of only 19.5 liters
- Extremely good water cooling support for its size, supporting radiators up to 280mm long
- Smart drive bay placement allows you to fit up to three 3.5"drives, three 2.5" and one 5.25" drive simultaneously
- Supports Mini-ITX motherboards, ATX power supplies and graphics cards up to 310mm in length
- Supports tall CPU cooler towers, up to 170mm in height
- Featuring a Fractal Design Silent Series R3 140mm rear exhaust fan for great cooling
- Big magnetic filters for the side and top air intake together with a PSU filter ensures a dust free interior
Specifications:
- Mini ITX, Mini DTX motherboard compatibility; NOTE: motherboards with SATA ports that are angled 90 degrees may conflict with installation in the case.
- 2 expansion slots
- 3 - 3.5" HDD positions
- 3 - 2.5" dedicated SSD/HDD unit positions
- 1 - 5.25" bay (removable)
- CPU coolers up to 170mm in height
- ATX PSUs, up to 170mm in length (non modular PSUs); ATX PSUs, up to 160mm in length (modular PSUs)
- Graphics cards up to 310 mm in length (note: graphics cards longer than 170 mm will not fit with PSUs that exceed 170 mm)
- Colours available: Black
- Case volume: 19.5 liters
- Case dimensions (WxHxD): 250 x 203 x 367 mm
- Case dimensions - with feet/screws/protrusions: 250 x 213 x 380 mm
- Net weight: 4.4 kg
- Package dimensions (WxHxD): 285 x 335 x 450 mm
- Package weight: 5.3 kg
Cooling System:
- Rear: 1 - 120/140 mm fan (included is 1 Fractal Design Silent Series R3 fan, 1000 RPM speed)
- Top: 2 - 120/140 mm fan (not included)
- Water cooling compatibility (note: not compatible with AIO water cooler units that feature the pump on the radiator):
- Top - 280, 240, 140 and 120 mm radiators. (Thickness limitation of 100 mm for both radiator + fan) (240 and 280 mm radiators require removal of the ODD bay) (280mm radiator can be maximum 325mm in length)
- Rear - 120 mm radiator (not compatible with the rear 3.5" HDD position)
- Dust filters: Magnetic filters on side and top panel, PSU filter
Front Interface:
- 2 USB 3.0
- Audio in/out
- Power button with LED (white)
- HDD activity LED (white)
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-500
Core 1000 USB 3.0
The Fractal Design Core Series offers a unique combination of design, cooling performance and value.
The Core 1000 USB 3.0 brings forth many features usually only seen in more expensive and larger cases. It supports long graphics cards up to 350mm in length as a result of the innovative, vertical HDD mounting bracket. The front panel is easily removable and pre-fitted with fan filters to ensure a dust free interior.
The sleek black interior is contrasted with white expansion slots while all HDD mountings are fitted with anti-vibration silicone grommets for optimal silence.
Key Features:
Specifications:
Cooling System:
Front Interface:
Key Features:
- Simple yet elegant mesh front panel allowing for increased airflow through the case
- Optimized for performance in a compact, micro-ATX form factor with multiple cooling options
- NEW: 1 x USB 3.0 with internal connector, 1 x USB 2.0
- One Silent Series R2 fan included: 1 x 120mm in front
- A total of 3 fan slots (1 x 120mm in front, 1 x 92mm in rear, 1 x 120mm in side panel)
- Innovative HDD positioning which mounts the HDD or SSDs vertically on the mounting bracket with anti-vibration silicone grommets
- Supports long graphics cards up to 350mm in length
- Supports various combinations of drive sets ups: 3 x 2.5" SSD, 2 x 3.5" HDD or 1 x 2.5" SSD + 1 x 3.5" HDD
- Dust filter for front fan position
Specifications:
- mATX, Mini ITX, DTX motherboard compatibility
- Drive bay capacity: 2 - 3.5" HDD or 3 - 2.5" SSD or 1 - 3.5" HDD + 1 - 2.5" SSD
- 2 - ODD slots
- 1 - FDD slot, using convertor in ODD slot (convertor included)
- 4 expansion slots with sleek white painted brackets
- Supports graphic card up to 350mm in length with one HDD mounted
- Supports graphic card up to 210mm in length with two/three HDD mounted
- Supports CPU coolers up to148mm in height
- Supports full size ATX PSU, maximum length about 185 mm if an optical drive is mounted
- Case dimensions (WxHxD): 175 x 355 x 420mm
- Net weight: 4.1 kg
- Package dimensions (WxHxD): 225 x 415 x 475mm
- Package weight: 5 kg
Cooling System:
- Front: 1 - 120mm fan (included is a hydraulic bearing 120mm Silent Series R2 fan, 1200 RPM speed)
- Rear: 1 - 92mm fan (not included)
- Side: 1 - 120mm fan (not included)
Front Interface:
- 1 - USB 3.0 with internal connector
- 1 - USB 2.0
- 1 - 3.5mm audio in (mic)
- 1 - 3.5mm audio out (headphone)
- HDD LED
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-1000-usb-30
Core 1100
Despite its extremely small outer dimensions, the Core 1100 mATX case provides everything you need. The stylish, Scandinavian exterior design is matched by the fully painted interior, complete with the signature white details of Fractal Design. The case is optimized for airflow with a straight cooling path, and comes equipped with a pre-installed 120mm fan. The front panel is equipped with dust filters. An innovative vertical hard drive bracket can fit either two 3.5" drives, three 2.5" drives, or one drive of each size. Both the 3.5" drive slots come with silicone vibration dampening grommets.
Key Features:
Key Features:
- An extremely compact micro ATX case, designed for exceptional airflow and cooling
- One Fractal Design 120mm fan included
- Easy access I/O on front panel, with audio and both USB 3.0 and USB 2.0 ports
- Front panel dust filters and closed top and bottom panels help maintaining a dust free interior
- Innovative vertical HDD bracket, which can hold two 3.5" drives or three 2.5" drives, or one drive of each size
- Vibration-dampened mounting for both 3.5" drive slots
- Fully painted interior, with Fractal Design signature white details
- Mini ITX, Micro ATX motherboard compatibility
- 2 - 5.25" bays
- 2 - 3.5" HDD positions OR 3 - 2.5" drive positions, OR 1 - 2.5" drive position, OR 1 - 3.5" drive position
- 4 expansion slots
- Supports Graphics cards up to 350mm in length may be installed. One or more 3.5" hard drives may interfere with side-mounted power connectors on graphics cards longer than 170 mm
- Support cooling system: 3 Fan positions (1 fan included)
- CPU coolers up to 148 mm in height
- ATX PSUs, up to 185mm if a typical-length optical drive is mounted
- Available in Black
- Case dimensions (WxHxD):175 x 358 x 410 mm
- Net weight: 3.8 kg
- Package dimensions (WxHxD): 235 x 485 x 420 mm
- Package weight: 4.6 kg
- Front: 1 - 120mm fans (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed)
- Side: 1 -120mm fan (not included)
- 1 USB 3.0 and 1 USB 2.0
- Audio in/out
http://www.fractal-design.com/home/product/cases/core-series/core-1100
Core 1300
The Core 1300 is the extremely compact micro ATX Mini Tower of the x3 Series Designed for exceptional airflow and cooling. The case is equipped with two pre-installed Silent Series LT 120mm fans and can support both 280mm and 240mm water cooling radiators. An innovative vertical hard drive bracket can fit a total of four drives - two 3.5" drives and two 2.5" drives. An additional 2.5" SSD mounting is available behind the power supply position. A beautiful build is easy to achieve with the black/white contrasted interior and well-designed cable routing capabilities. All at an attractive price point.
Key Features:
An extremely compact micro ATX case with bottom-mounted PSU, designed for exceptional airflow and cooling
Superior water cooling support for its size, supporting up to two 240mm radiators
Featuring a 120mm rear exhaust fan for exceptional cooling
Supports tall CPU cooler towers, up to about 162mm in height
Total 7 fan slots with two 120mm fans included
Extruded motherboard plate allowing space for additional cable routing; 18.5mm around the motherboard and 13.5mm directly behind it
Innovative vertical HDD bracket, which simultaneously holds two 3.5" drives and two 2.5" drives
One additional SSD position behind the PSU area with easy installation and access
Specifications:
Key Features:
Specifications:
- 2 - 5.25" bays (maximum 185mm in length)
- 3 - 2.5" dedicated SSD unit position
- 4 expansion slots
- Graphics cards up to 380mm in length may be installed. One or more 3.5" hard drives may interfere with side-mounted power connectors on graphics cards longer than 200 mm
- Support cooling system: 7 Fan positions (2 fans included)
- Filtered fan slots in front and bottom
- CPU coolers up to 162 mm in height
- Supports ATX PSUs up to 205/185 mm with a bottom 120/140mm fan; When not using any bottom fan location longer PSUs can be used
- 13.5-18.5 mm of space for cable routing behind the motherboard plate
- Case dimensions (WxHxD): 195 x 370 x 450mm
- Case dimensions with feet/protrusions/screws: 195 x 384 x 460mm
- Net weight: 4.6 kg
- Package dimensions (WxHxD): 270 x 547 x 432mm
- Package weight: 5.7 kg
- Front: 2 - 120mm fans (included is 1 Fractal Design Silent Series LT 120mm 1200 RPM speed) or 1 - 140mm fan (not included, two positions available)
- Rear: 1 - 120mm fan (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed)
- Top: 2 - 120/140mm fan (not included)
- Bottom: 1 - 120mm fan (not included, two positions available) or 1 - 140mm fan (not included)
- Side: 1 -140mm fan (not included)
- Front : Slim 240mm radiator (with lower ODD slot unused)
- Top : Slim 240mm radiator (with upper ODD slot occupied by a device no longer than 150mm and with no components on the upper 23 mm on the motherboard that are taller than 34mm)
- Rear : 120 mm radiator
- 1 USB 3.0 + 1 USB 2.0
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-1300
Core 1500
The Core 1500 is the extremely compact micro ATX Mini Tower of the x5 Series. It's a a small footprint case, that does not compromise on key features. It boasts a clean, modern exterior coupled with class-leading compatibility and cooling, all at an attractive price point. The Core 1500 comes equipped with two pre-installed 120mm fans, a built-in three-speed fan controller as well as support for up to two 240mm water cooling radiators for excellent cooling potential.
Up to four 3.5" or 2.5" hard drives can be fitted in the vibration dampened hard drive trays with an additional dedicated SSD mounting placed behind the power supply position. A beautiful build is easy to achieve with the black/white contrasted interior and well-designed cable routing capabilities.
Key Features:
Front - Slim 240mm radiator (with lower HDD cage moved, upper HDD cage removed and lower ODD slot unused)
Top - Slim 240mm radiator (with upper ODD slot occupied by a device no longer than 150mm and with no components on the upper 23 mm on the motherboard that are taller than 34mm)
Front Interface:
Key Features:
- An extremely compact micro ATX case with bottom-mounted PSU, designed for exceptional airflow and cooling
- Superior water cooling support for its size, supporting up to two 240mm radiators
- Featuring a 120mm rear exhaust fan for exceptional cooling
- Supports tall CPU cooler towers, up to about 162mm in height
- Total 7 fan slots with two 120mm fans included
- Extruded motherboard plate allowing space for additional cable routing; 18.5mm around the motherboard and 13.5mm directly behind it
- Four vibration dampening hard drive trays for up to four 3.5" HDDs, all compatible with 2.5" drives
- HDD trays split into two cages and strategically positioned with a large space in between to support all long graphics cards up to a maximum length of 380mm, with all hard drive trays in plac
- One additional SSD position behind the PSU area with easy installation and access
- 4 - 3.5" HDD trays - all compatible with SSDs
- 1 - 2.5" dedicated SSD unit position
- 4 expansion slots
- Supports graphic card up to 380mm without any HDD removal
- Integrated fan controller on backside
- Supports ATX PSUs up to 155 mm deep when using the primary bottom fan location; when not using this fan location longer PSUs can be used
- Case dimensions (WxHxD):195 x 370 x 450mm
- Net weight: 5.2 kg
- Package weight: 6.3kg
- Front: 2 - 120mm fans (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed) OR 1 - 140mm fan (not included), placed near ODD cage OR 1 - 140mm fan (not included), placed near case bottom
- Bottom: 1 - 120mm fan (not included, PSU length limits apply) OR 1 - 120mm fan (not included, requires removal of lower HDD cage) OR 1 - 140mm fan (not included, requires removal of lower HDD cage
- 1 - integrated fan controller on the backside for up to 3 fans
Front Interface:
- 2 - USB 3.0
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-1500
Core 2300
The Core 2300 is the compact ATX Mid Tower of the x3 Series that combines a clean, modern exterior design with great cooling and component compatibility. It comes with two pre-installed fans, and great radiator support for its size The case is equipped with two pre-installed 120mm fans and can support both 280mm and 240mm water cooling radiators. An innovative vertical hard drive bracket can fit a total of six drives - three 3.5" drives and three 2.5" drives. An additional 2.5" SSD mounting is available behind the power supply position. A beautiful build is easy to achieve with the black/white contrasted interior and well-designed cable routing capabilities.
Key Features:
Key Features:
- A compact full-ATX case with bottom-mounted PSU, designed for exceptional airflow and cooling
- Superior water cooling support for its size, supporting one 240/280mm radiator in the front and a 240mm radiator in the top
- Featuring a 120mm rear exhaust fan for great cooling
- Supports tall CPU cooler towers, up to 162mm in height
- Innovative vertical HDD bracket, which simultaneously holds three 3.5" drives and three 2.5" drives
- Mini ITX, Micro ATX ATX motherboard compatibility
- 4 - 2.5" dedicated SSD unit position
- 7 expansion slots
- Graphics cards up to 380mm in length may be instaled. One or more 3.5" hard drives may interfere with side-mounted power connectors on graphics cards longer than 200 mm
- Supports ATX PSUs up to 205/185 mm with a bottom 120/140mm fan. When not using any bottom fan location longer PSUs can be used
- Extra cable routing holes for usage with mATX motherboards
- Case dimensions (WxHxD):195 x 431 x 450mm
- Package dimensions (WxHxD): 270 x 547 x 492mm
- Package weight: 6.4 kg
- Front: 2 - 120/140mm fans (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed)
- Bottom: 1 - 120mm fan (not included) or 1 - 140mm fan (not included, bottom HDD position must be empty)
- Front - 240mm radiator, up to 30mm thickness
- Front - 240mm radiator, any thickness, push/pull supported (secondary mounting position, three fastening screws per fan only)
- Front -Slim 280mm radiator: 15mm fan spacing required for full fastening, radiators with 20mm fan spacing can be used with only the top half fastened to the case (lower ODD slot may need to be unused depending on tube end chamber size)
- Top - Slim 240mm radiator (with upper ODD slot occupied by a device no longer than 150mm and with no components on the upper 23 mm on the motherboard that are taller than 34mm)
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-2300
Core 2500
The Core 2500 is the compact ATX Mid Tower of the x5 Series combines a clean, modern exterior design with great cooling and component compatibility. The case is equipped with two pre-installed 120mm fans, a built-in fan controller as well as support for a 280mm and 240mm water cooling radiators. Two hard drive cages hold up to four 3.5" or 2.5" hard drives on vibration dampened sturdy steel trays. An additional dedicated SSD mounting is available behind the power supply position. A beautiful build is easy to achieve with the black/white contrasted interior and well-designed cable routing capabilities.
Key Features:
Key Features:
- A compact ATX Mid Tower case with bottom-mounted PSU, designed for exceptional airflow and cooling
- Supports tall CPU cooler towers, up to circa 162mm in height
- HDD trays split into two cages and strategically positioned with a large space in between to support all long graphics cards up to a maximum length of 380mm, with all hard drive trays in place
- 7 expansion slots
- Net weight: 5.7 kg
- Package weight: 6.9kg
- Bottom: 1 - 120mm fan (not included, PSU length limits apply) OR 1 - 120mm fan (not included, requires removal of lower HDD cage) OR 1 - 140mm fan (not included, requires removal of lower HDD cage)
- Front - 240mm radiator, up to 45mm in thickness (with lower HDD cage repositioned in case, upper HDD cage removed)
- Front - 240mm radiator, any thickness, push/pull supported (with both lower and upper HDD cages removed)
- Front -Slim 280mm radiator: 15mm fan spacing required for full fastening, radiators with 20mm fan spacing can be used with only the top half fastened to the case (with lower HDD cage repositioned in case, upper HDD cage removed, lower ODD slot may need to be unused depending on tube end chamber size)
- 2 - USB 3.0
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-2500
Core 3300
The Core 3300 is the Wide-body ATX Mid Tower of the x3 Series. It offers many benefits typically only seen in significantly more expensive cases, such as great cable management, multiple radiator support, and superior ease of use. It comes with two pre-installed 140mm fans, and can support up to two 240mm radiators or both a 240mm and a 280mm radiator. An innovative vertical hard drive bracket can fit a total of six drives - three 3.5" drives and three 2.5" drives. In addition, two additional SSD drive can be placed behind the motherboard tray. A beautiful build is easy to achieve with the black/white contrasted interior and well-designed cable routing capabilities.
Key Features:
Key Features:
- A Wide Body mid tower case with bottom-mounted PSU, designed for exceptional airflow and cooling.
- Superior water cooling support, supporting one 240/280mm radiator in the front and a 240mm radiator in the top
- Featuring a 140mm rear exhaust fan for optimal cooling
- Total 7 fan slots with two Silent Series R2 140mm fans included
- Smart cable management with 22mm of space behind the motherboard plate for clean installations
- Supports extremely tall tower CPU coolers, up to 185mm in height
- Two additional SSD positions behind the motherboard plate
- ATX, E-ATX (up to 295 mm wide) Micro ATX, Mini ITX motherboard compatibility
- 2 drive bays of 5,25"
- 3 bays 3.5"- all compatible with SSDs
- 2 -2.5" dedicated SSD unit position
- 7 expansion slots
- Support Graphics cards up to 430mm. One or more 3.5" hard drives may interfere with side-mounted power connectors on graphics cards longer than 255 mm
- Support cooling system: 7 - Fan positions (2 Silent Series R2 fans included)
- CPU coolers up to 185 mm in height
- ATX PSUs up to 170 mm deep when using the bottom fan location for a 140mm fan; when not using this fan location longer PSUs can be used
- 22 mm of space for cable routing behind the motherboard plate
- Case dimensions (WxHxD):233 x 451 x 517mm
- Net weight: 7.8 kg
- Package dimensions (WxHxD): 322 x 625 x 540mm
- Package weight: 9.3 kg
- Front: 2 - 120/140mm fans (included is 1 hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Rear: 1 - 120/140mm fan (included is 1 hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Bottom: 1 - 120/140mm fan (not included, PSU length limits apply)
- Side: 1 - 120/140mm fan (not included)
- Front -30mm thick 240 or 280mm radiator: 15mm fan spacing required for full fastening, radiators with 20mm fan spacing can be used with only the top half fastened to the case. (radiators of any thickness may be used if all 3.5" positions are empty)
- Top - 30mm thick 240mm radiator (with no components on the upper 11 mm on the motherboard that are taller than 38mm)
- Top - 30mm thick 280mm radiator with slim fans
- Rear - 120/140 mm radiator
- 2 - USB 3.0
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-3300
Core 3500
Fractal Design Core 3500 is a wide body mid tower ATX case, High-performance features include superior liquid cooling potential with support for up to two 240mm radiators or a 280mm radiator.
Now featuring the option to have your Core 3500 case with a large fully transparent window allowing you to display your setup in style.
Key Features:
Key Features:
- A remarkably spacious midi tower case with bottom-mounted PSU, designed for exceptional airflow and cooling.
- A large, tinted, acrylic side panel window to show off your build
- Total 6 fan slots with three Silent Series R2 140mm fans included
- Motherboard plate with 22mm of cable routing space behind it, for effortless clean installations
- Supports extremely tall tower CPU coolers, up to 180mm in height
- Supports extremely long graphics cards up to a maximum length of 430mm in the top four slots, and cards up to 295mm in length in the bottom three slots
- ATX, E-ATX (up to 295 mm wide), Micro ATX, Mini ITX motherboard compatibility
- 4 bays 3.5"- all compatible with SSDs
- 7 expansion slots
- Graphics cards up to 430mm in length may be installed in the upper four slots
- With HDD cage in primary position, cards up to 295mm can be installed in bottom three slots
- With HDD cage in the secondary position graphics cards up to 260mm are supported in the bottom three slots
- Support cooling system: 6 - Fan positions (3 Silent Series R2 fans included)
- CPU coolers up to 180 mm in height
- ATX PSUs up to 170 mm deep when using the primary bottom fan location for a 140mm fan; when not using this fan location longer PSUs can be used
- Including a large 270 x 290mm tinted window
- Case dimensions (WxHxD):233 x 465 x 517mm
- Net weight: 8.6 kg
- Package weight: 10.1kg
- Top: 2 - 120/140mm fan(included is 1 hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Front -Slim 240 or 280mm radiator. 15mm fan spacing required for full fastening, radiators with 20mm fan spacing fan be used with only the top half fastened to the case. (with lower HDD cage moved to secondary position)
- Front - Thick 240 or 280mm radiators supported with HDD cage in alternate position or completely removed. Motherboards larger than mATX are not fully supported with HDD cage in the tertiary position.
- Top - Slim 240mm radiator (with no components on the upper 11 mm on the motherboard that are taller than 38mm)
- Top - Slim 280mm radiator with slim fans
- 2 - USB 3.0
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/core-series/core-3500-window
Define Series
The Define Series of cases focuses on delivering the perfect balance between silent and minimalistic Scandinavian design. The understated look and feel allows for a natural fit into your home or office while never compromising on quality, performance or configurability.
Define Mini
The Define series is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity.
As the name implies, Define Mini is the smaller sibling of the acclaimed and award winning Define R4 case. Being a micro ATX version of Define R4, it offers a number of interesting functions with a very stylish appearance. It's a case focused on low noise level, without neglecting other important features such as cooling, expandability and ease of use. The Define Mini excels in including a lot of features in a small size!
The patent pending feature ModuVent™, in which you can choose whether to have fan slots in side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones.
The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of six hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it.
Key Features:
Key Features:
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 6 white painted HDD-trays, with silicone mounting
- A total of 6 fan slots (2x120mm in front, 1x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120mm in bottom)
- Two 120mm Fractal Design fans included
- Fan controller for 3 fans included
- Upper HDD cage is removable and rotatable
- USB3 support in the front panel
- Excellent cable routing and cable routing covers
- Supports graphic cards with lengths up to circa 400mm when upper HDD bay is removed
- Extra, vertically mounted expansion slot, suitable for fan controllers or non-input expansion cards
- 6x 3.5 inch HDD trays, compatible with SSD
- 2x 5.25 inch bays, with 1x 5.25>3.5 inch converter included
- On top of front panel: 2x USB2, 1x USB3 and Audio I/O
- Removable filter below PSU (No PSU included)
- M/B compatibility: Mini ITX and Micro ATX
- 4+1 expansion slots with sleek white painted brackets
- Supports graphic cards with lengths up to ca 260mm when removable HDD-bay is in place
- Supports graphic cards with lengths up to ca 400mm when HDD-bay is removed
- Supports CPU coolers with height of ca 160mm
- Supports PSUs with a depth of maximum circa 170mm, when using bottom 120/140mm fan location. When not using the bottom 120mm fan location, the case supports also longer PSUs, typically 200-220mm.
- Case size (WxHxD): 210 x 395 x 490mm
- Net weight: 9.50 kg
- 1 rear Fractal Design 120mm @ 1200rpm (included)
- 1 front Fractal Design 120mm @ 1200rpm (included)
- 1 front 120mm fan (optional)
- 1 top 120/140mm fan (optional)
- 1 bottom 120mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
http://www.fractal-design.com/home/product/cases/define-series/define-mini
Define Nano S
The Define Nano S is an ITX case that features compatibility with high end, full-size components, superior sound dampening, and an ATX-like layout.
The case includes two Dynamic Series fans with both bottom and front intakes protected by easy-to-clean, removable dust filters.
With its mounting capabilities for simultaneous radiators and unobstructed airflow path, the Define Nano S can cool enthusiast-level components.
Equipped with Fractal Design's signature ModuVent™ technology on the top vents and sound dampening throughout, the Define Nano S can run a powerful system quietly, a hallmark of the Define series.
Key Features:
Key Features:
- A Define Series ITX case designed for silent computing with sound dampening and ModuVent™ technology
- User-friendly construction with superior cable management and compatibility for full-size components
- Flexible storage options with room for up to 4 drives
- Accommodates a variety of radiator sizes and includes brackets for reservoir and pump mounting
- Features two Dynamic Series fans - 1 GP-12 and 1 GP-14 - with an adapter included for motherboards with limited fan headers
- Featuring an open interior allowing an unobstructed airflow path from the front of the case to the rear exhaust
- Easy-to-clean filters on the top and bottom, spanning the PSU position, with the bottom filter ejecting from the front for easy-access.
- ITX motherboard compatibility
- 2 expansion slots
- 2 - 3.5" HDD/2.5" SSD positions; 2 - 2.5" dedicated SSD unit positions (fits SSDs up to 13mm thick)
- 6 - Fan positions (1 Fractal Design Dynamic GP14 140mm fan + 1 Fractal Design Dynamic GP-12 120mm fan included)
- Filtered fan slots in the front and bottom (ejects from the front of the case)
- CPU coolers up to 162mm in height
- CPU coolers up to 160mm in height (Windowed)
- ATX PSUs up to 160mm deep (shorter PSUs recommended for easier cable management)
- Graphics cards up to 315mm in length with front fans mounted (Cards wider than the dual slot bracket are not recommended)
- 17 - 35mm of space for cable routing behind the motherboard plate
- Velcro straps included for easy cable management
- Both side panels and rear HDD/SSD brackets feature smart captive thumbscrews
- Dense sound dampening material on front, left and right side panels
- ModuVent™ on top of case for further silent computing or additional ventilation
- Case dimensions (WxHxD): 203 x 330 x 400mm
- Case dimensions - with feet/protrusions/screws: 203 x 344 x 412mm
- Net weight: 5 kg
- Net weight: 4.6 kg (Windowed)
- Case volume: 26.80 litres
- Package dimensions (WxHxD): 275 x 485 x 420mm
- Package weight: 6.2 kg
- Package weight: 5.8 kg
- Front: 2 - 120/140 mm fans (included is 1 Fractal Design Dynamic GP14 fan, 1000 RPM speed)
- Rear: 1 - 120 mm fan (included is 1 Fractal Design Dynamic GP12 fan, 1200 RPM speed)
- Bottom: 1 - 120 mm fan (not included)
- Dust filters: Bottom and front intakes
- Front - 120/240mm, 140/280mm (max width 147, length 312; some radiators extend beyond the screw holes)
- Top - 120/240mm (max component height on motherboard 35mm. Big heatsinks on RAM or power regulators around CPU could conflict with this restriction)
- Bottom - 120mm (max thickness & length: 85mm x 160mm)
- Rear - 120mm (max width 125mm; some radiators extend beyond the screwholes)
- Pre-drilled holes on multi-bracket, supports many DDC and D5 variants (see manual for detailed measurements)
- Adjustable mounting brackets allow for almost any rectangular mounting screw pattern. Maximum distance between the mounting bracket screw positions: 270mm height / 80mm width.
- 2 USB 3.0
- Audio in/out
- HDD activity LED (blue)
- Reset button
http://www.fractal-design.com/home/product/cases/define-series/define-nano-s
http://www.fractal-design.com/home/product/cases/define-series/define-nano-s-window
Define R4
The Fractal Design Define R4 is the midi tower in the Define Series of computer cases offering minimalistic and stunning Scandinavian design fused with maximum sound reduction, configurability and functionality.
The Define R4 side and front door panels are fitted with dense, sound-absorbing material making it a benchmark for noise reduction. Moreover, the Define R4 accommodates up to 8 HDDs, all modern graphics card sizes, and multiple ventilation options - including two standard Silent Series R2 hydraulic bearing fans - to keep internal components at optimal temperatures.
For ultimate functionality, the Define R4 features a front interface with USB 3.0 and an integrated three-speed fan controller behind the front panel door.
Key Features:
Key Features:
- High density noise-reducing material for an optimal silent case - To achieve a high level of noise reduction, material with mass should be incorporated which is what we strive to achieve with the dense bitumen used on the side panels
- High density noise-reducing material lining acrylic window (Windowed)
- Patent pending ModuVent™ design allowing the user to choose between optimal silence or maximum airflow
- Top HDD cage (5 trays total) can be rotated 90 degrees or removed for additional airflow or to accommodate long graphic cards up to 430mm in length
- Three-speed fan controller is strategically integrated in the front panel and supports up to 3 fans
- Two Silent Series R2 fans included, featuring hydraulic bearings contributing to a longer life expectancy - Silent Series R2 retail fans will now come standard in all cases
- Wider case body that allows for improved cable routing behind the motherboard - now 26mm wide
- New tool-less front fan holder makes switching front fans a breeze
- Two SSDs can be mounted on the back of the motherboard plate in addition to the 8 slots in the HDD trays, for a total of 10 SSD positions available
- 2 - 5.25" bays
- 8 - 3.5" HDD trays - all compatible with SSDs, 2 - 2.5" extra SSD positions
- 3 - ModuVent™ plates - two in the top and one in the side
- 2 - ModuVent™ plates - two in the top and one in the side (Windowed)
- 7 - fan positions (2 Silent Series R2 fans included)
- 6 - fan positions (2 Silent Series R2 fans included) (Windowed)
- CPU coolers up to 170mm tall (when no fan is installed in the side panel)
- ATX PSUs up to 170mm deep when using the bottom fan location, when not using this fan location longer PSUs (up to 270mm deep) can be used
- Graphics cards up to 295mm in length with the top HDD cage installed
- 26mm of space for cable routing behind the motherboard plate
- Colours available: Black Pearl, Titanium Grey, Arctic White
- Case dimensions (WxHxD): 232 x 464 x 523mm
- Package dimensions (WxHxD): 320 x 535 x 610mm
- Net weight: 12.3 kg
- Front: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed); 1 - 120x140mm fan (not included)
- Top: 2 - 120/140mm fans (not included) - positions also support some models of 240 radiators, depending on configuration
- Side: 1 - 120/140mm fan (not included) (Non-windowed)
- 2 - USB 3.0, 2 - USB 2.0
- Audio I/O
- Power button with LED (red)
- Reset button
- Fan controller (behind door)
http://www.fractal-design.com/home/product/cases/define-series/define-r4-arctic-white
http://www.fractal-design.com/home/product/cases/define-series/define-r4-arctic-white-window
http://www.fractal-design.com/home/product/cases/define-series/define-r4-black-pearl
http://www.fractal-design.com/home/product/cases/define-series/define-r4-black-pearl-window
http://www.fractal-design.com/home/product/cases/define-series/define-r4-titanium-grey
http://www.fractal-design.com/home/product/cases/define-series/define-r4-titanium-grey-window
Define R5
The Fractal Design Define R5 is the next evolution in the widely popular Define Series. Packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction.
The Define R5 case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, ModuVent™ fan vent covers and finely tuned Dynamic Series fans.
The Define R5 was designed with configurability in mind, accommodating up to 8 hard drives and all modern graphics card. Should you wish to expand your system with water cooling components or more fans the layout can easily be configured to meet your demand.
Key Features:
Key Features:
- Optimally designed for silent computing with high density noise-reducing material throughout the case for maximum sound absorption, while not compromising on airflow and cooling capabilities.
- Extensive water cooling support for a case of this size; housing radiators up to 420mm in the top and 360mm in the front.
- Equipped with new tool-less ModuVent™ fan slot covers allowing the user to install more fans if desired or keep fan slots covered to maximize sound absorption.
- Including two Fractal Design Dynamic GP14 140mm fans developed for superlative airflow while still maintaining low noise levels.
- Including two all-black Fractal Design Dynamic GP14 140mm fans developed for superlative airflow while still maintaining low noise levels. (Blackout Edition)
- Maintaining a dust-free interior with the help of dust filters that cover front and bottom air intakes that are easy to access from the front on the case.
- Newly configured front door with dual side mounting to better fit your work space
- Highlighting 2 dedicated SSD mounts cleanly placed behind the motherboard tray that feature innovative new brackets delivering a tool-free installation and removal
- The HDD cage system holds up to eight 3.5" or 2.5" drives and is more adaptable than ever, allowing the user to modify the case layout according to personal preference with more places to relocate the cages
- The ODD cage can easily be removed to gain additional interior space; the area can be freed up to allow for increased airflow, to provide a new place for HDD cage mounting or to make more room for water cooling components.
- Sturdy metal HDD trays provide excellent dampening features for the hard drives while providing better airflow through the cage with an updated, more open design
- The new and innovative Quick Release System on the left side of the case provides secure mounting of the left side panel, yet grants quick and easy access to the system.
- Three-speed fan controller is strategically integrated in the front panel and supports up to 3 fans.
- Define R5 model is available with window side panel
- 7 expansion slots
- 2 - 5.25" bays (removable)
- 8 - 3.5" HDD positions (can also accommodate 2.5" units); 2 - 2.5" dedicated SSD unit positions
- 4 - ModuVent™ plates - three in the top and one in the side
- 9 - fan positions (2 Fractal Design Dynamic GP14 140mm fans included)
- 9 - fan positions (2 all-black Fractal Design Dynamic GP14 140mm fans included) (Blackout Edition)
- 8 - fan positions (2 Fractal Design Dynamic GP14 140mm fans included) (Windowed)
- 8 - fan positions (2 all-black Fractal Design Dynamic GP14 140mm fans included) (Windowed Blackout Edition)
- CPU coolers up to 180mm in height
- ATX PSUs up to 190/170 mm with a bottom 120/140mm fan installed; when not using any bottom fan location longer PSUs up to 300mm can be used
- Graphics cards up to 310 mm in length with the top HDD cage installed; with the top cage removed, graphics cards up to 440 mm in length may be installed
- 20 - 35 mm of space for cable routing behind the motherboard plate
- Front door can switch opening direction via dual mounting system
- Left side panel features Quick Release System for easy access and provides a secure closure of side panel
- Right side panel features smart captive thumbscrews so no thumbscrews are lost
- Colours available: Black, Titanium (black case, titanium front panel), White
- Case dimensions (WxHxD): 232 x 451 x 521mm
- Case dimensions - with feet/screws/protrusions: 232 x 462 x 531mm
- Net weight: 10.7 kg
- Package dimensions (WxHxD): 327 x 615 x 540mm
- Package weight: 12.5 kg
- Rear: 1 - 120/140 mm fan (included is 1 Fractal Design Dynamic GP14 fan, 1000 RPM speed)
- Front: 2 - 120/140 mm fans (included is 1 all-black Fractal Design Dynamic GP14 fan, 1000 RPM speed) (Blackout Edition)
- Rear: 1 - 120/140 mm fan (included is 1 all-black Fractal Design Dynamic GP14 fan, 1000 RPM speed) (Blackout Edition)
- Top: 3 - 120/140 mm fan (not included)
- Bottom: 2 - 120/140 mm fan (not included)
- Side: 1 - 120/140 mm fan (not included)
- Fan controller: 3 step fan controller for up to 3 fans
- Front - 360, 280, 240, 140 and 120 mm radiators of all thicknesses (requires removal of drive bays)
- Top - 420, 360, 280, 240, 140 and 120 mm radiators. (A thickness limitation of 55mm for both radiator + fan applies on 420, 280 and 140 mm radiators) (420 and 360 mm radiators require removal of the ODD bay)
- Bottom - 120 or 240 mm radiator (Use of radiators in the bottom position limits the PSU length to 165 mm)
- Rear - 120 or 140 mm radiator
- 2 USB 3.0 + 2 USB 2.0
- Audio in/out
- Power button with LED (white) (Blackout Edition)
- HDD activity LED (white) (Blackout Edition)
- Reset button
http://www.fractal-design.com/home/product/cases/define-series/define-r5-black
http://www.fractal-design.com/home/product/cases/define-series/define-r5-black-window
http://www.fractal-design.com/home/product/cases/define-series/define-r5-blackout-edition
http://www.fractal-design.com/home/product/cases/define-series/define-r5-blackout-edition-window
http://www.fractal-design.com/home/product/cases/define-series/define-r5-titanium
http://www.fractal-design.com/home/product/cases/define-series/define-r5-titanium-window
http://www.fractal-design.com/home/product/cases/define-series/define-r5-white
http://www.fractal-design.com/home/product/cases/define-series/define-r5-white-window
Define S
The Fractal Design Define S lends the appearance, sound dampening technology, and support for a wide variety of components from the widely popular Define Series, while introducing a new, innovative internal layout. The Define S case is packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction.
The modernized internal layout of the Define S omits the optical drive bays, instead focusing on a clear straight airflow path and uncompromising water cooling support.
The Define S case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, multiple ModuVent™ fan vent covers and finely tuned Dynamic Series fans.
Key Features:
Key Features:
- Optimally designed for silent computing, while not compromising on airflow and cooling capabilities
- Innovative internal layout, providing a perfectly straight airflow path to the CPU heatsink for air cooling set ups or extensive radiator mounting possibilities for water cooling set ups
- Including smart reservoir brackets; featuring drill-free reservoir mounting on the front of the motherboard tray and pre-drilled pump mounting holes on the bottom panel
- Equipped with ModuVent™ fan slot covers providing the option of additional cooling or maximum sound absorption
- Maintaining a dust-free interior with dust filters that cover the front and bottom air intakes
- Introducing newly designed hard drive trays placed vertically behind the front partition of the motherboard tray; Three sturdy steel trays with vibration-dampening grommets allowing for installation of one 3.5" or 2.5" drive on each tray, without disrupting the airflow or interfering with the radiator mounting possibilities
- An additional 2 dedicated steel SSD trays cleanly placed behind the motherboard tray
- Long motherboard tray extending to the front panel contributing to an extremely clean build, hiding both hard drives and cables
- Define S model is also available with a large window on the side panel
- 7 expansion slots
- 3 - 3.5" HDD positions (can also accommodate 2.5" units); 2 - 2.5" dedicated SSD/HDD unit positions
- 9 - Fan positions (2 Fractal Design Dynamic GP14 140mm fans included); 8 fan positions on window model
- ATX PSUs up to 180/170 mm with a bottom 120/140mm fan installed; When not using any bottom fan location longer PSUs up to 300mm can be used
- Graphics cards up to 425 mm in length with front fans installed, without compromising HDD capacity; Graphics cards up to 450mm in length without front fans installed directly in line with the GPU
- With a front radiator, maximum graphics card length is reduced by the radiator thickness
- 20 - 40 mm of space for cable routing behind the motherboard plate
- Both side panels feature smart captive thumbscrews so no thumbscrews are lost
- Case dimensions (WxHxD): 233 x 451 x 520mm
- Case dimensions - with feet/screws/protrusions: 233 x 465 x 533mm
- Net weight: 9.1 kg
- Package dimensions (WxHxD): 322 x 615 x 535mm
- Package weight: 10.8 kg
- Front: 3 - 120/140 mm fans (included is 1 Fractal Design Dynamic GP14 fan, 1000 RPM speed)
- Top: 3 - 120/140 mm fan (not included) or 1 - 180 mm fan with 165mm hole spacing (not included)
- Bottom: 1 - 120/140 mm fan (not included)
- Bottom - 120 mm radiator (Use of radiators in the bottom position limits the PSU length to 165 mm)
- Pre-drilled holes on the bottom panel, supports many DDC and D5 variants
- Maximum distance between the mounting bracket screw positions: 350mm height / 80mm width
- 2 USB 3.0
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/define-series/define-s
http://www.fractal-design.com/home/product/cases/define-series/define-s-window
Define XL R2
Fractal Design builds on the success of its awarding-winning Define XL computer case with the Define XL R2. This updated chassis carries on the family tradition of providing superb cooling and ventilation capabilities with exceptional expandability, in a sleek and stylish Scandinavian form.
The Define XL R2, which includes Fractal Design's innovative ModuVent™ feature, has an updated internal layout that offers greater expandability, modularity and flexibility, including capacity for 9 PCI cards and two HDD cages that can be repositioned to provide more space for water cooling radiators.
Key Features:
Key Features:
- Patented ModuVent™ design allowing the user to choose between optimal silence or maximum airflow.
- With a new internal layout and additional PCI expansion slots, it can harbor the most powerful enthusiast systems.
- Both HDD cages can be removed or repositioned - Top HDD cage can be removed or repositioned for increased airflow whereas bottom HDD cage can be repositioned further into the case to allow for front radiator mount.
- The case can fit water cooling equipment in the front, top, rear and bottom without major modifications.
- Three Silent Series R2 fans are included, featuring hydraulic bearings which contribute to a longer life expectancy - Silent Series R2 retail fans now come standard in all cases
- ATX, Micro ATX, mini-ITX, E-ATX and XL-ATX motherboard compatibility
- 4 - 5.25" bays
- A total of 9 expansion slots
- 7 - Fan positions (3 fans included)
- CPU coolers up to 170 mm tall (when no fan is installed in the side panel)
- PSU compatibility: ATX PSUs up to 190 mm deep when using the bottom fan location; when not using this fan location longer PSUs (up to 345 mm deep) can be used
- Graphics card compatibility: Graphics cards up to 330mm in length with the top HDD cage installed - With the top cage removed, graphics cards up to 480mm in length may be installed
- Colors available: Black Pearl, Titanium Grey
- Case dimensions (WxHxD): 232 x 559 x 560mm
- Net weight: 16.4kg
- Package dimensions (WxHxD): 322 x 637 x 655mm
- Package weight: 19kg
- Front: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed); 1 - 120/140mm fan (not included)
- Top: 2 - 120/140mm fans (not included) - positions also support 240/280mm slim radiators
- Bottom: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
- Front - 240mm radiator when HDD cages are removed or repositioned
- Top - 240 and 280mm when using slim radiators
- Rear - 120 and 140mm radiators
- Audio in/out
- Reset button
http://www.fractal-design.com/home/product/cases/define-series/define-xl-r2-black-pearl
http://www.fractal-design.com/home/product/cases/define-series/define-xl-r2-titanium-grey
Node Series
The Node Series of cases offers a stylish way to integrate the computer into your home. With the flexibility to serve as an HTPC, fileserver or media and gaming station, the Node series delivers endless possibilities to combine design and entertainment.
Node 202
The Node 202 is the ultimate PC case for those looking for a beautifully designed, compact chassis that can house a capable gaming build.
This small footprint is an intelligently built unit where extreme detail was placed into the design phase to get every line and spec in perfect harmony. With both horizontal and vertical orientation possibilities, the Node 202 can be placed anywhere in the house. The sleek design makes it very attractive next to the TV in the living room or on your desk in the office.
The internal layout of the Node 202 keeps the hot components separate and has them all placed in proximity of free-flow air so the case will run cool despite not having any extra case fans.
Key Features:
Key Features:
- Featuring a sleek and elegant design that will fit in any space or room
- Extremely small footprint with a volume of only 10.2 liters
- A highly versatile case that can be set up both vertically and horizontally
- Supports Mini-ITX motherboards, SFX power supplies and graphics cards up to 310mm in length
- Provides a smart thermal interior design highlighting separate motherboard and graphics card chambers
- Strategically placed air filters for a dust free interior
- Mini ITX motherboard compatibility
- 2 - 2.5″ SSD unit positions
- 2 expansion slots
- 2 - 120mm optional fan positions in graphics card chamber
- CPU coolers up to 56 mm in height
- PSU compatibility: SFX PSUs up to 130mm long
- Graphics card compatibility: Maximum dimension of graphics card is 310x145x47mm (LxHxD)
- Can be placed both vertical and horizontal position
- 3 dust filters included (for CPU, GPU and PSU)
- Case volume: 10.2 litres
- Case dimensions - Horizontal (WxHxD): 377 x 82 x 330 mm
- Case dimensions - Horizontal, with feet/protrusions/screws (WxHxD): 377 x 88 x 332 mm
- Case dimensions - Vertical, with feet/protrusions/screws (WxHxD): 125 x 385 x 332 mm
- Net weight: 3.5 kg
- Package dimensions (WxHxD): 145 x 463 x 388 mm
- Package weight: 4.0kg
- Package weight: 5.2kg (With Integra SFX 450w PSU)
- 2 - USB 3.0
- Audio in/out
http://www.fractal-design.com/home/product/cases/node-series/node-202
http://www.fractal-design.com/home/product/cases/node-series/node-202-integra-sfx-450w-psu
Node 304
The Node 304 features a unique modular interior for outstanding configurability.
The Node 304 accommodates up to six hard drives. Unused mounting brackets can be removed to allow for long graphic cards, additional airflow or more space for organizing cables. Additionally, it is equipped with three hydraulic bearing fans, easy-to-clean air filters in all intakes and two front USB 3.0 ports.
Featuring hybrid functionality, the Node 304 case is ideally used as a cool-running file server, a stylish and quiet home theatre PC or a powerful gaming system highlighting minimalistic and stunning Scandinavian design and maximum functionality.
Key Features:
Key Features:
- Compact, modular interior
- Minimalistic design with an elegant aluminum front panel
- Unique new modular mounting system that accommodates up to 6 hard drives
- Accommodates tower CPU coolers and single-fan water cooling systems
- Filtered air intakes ensure a dust-free environment for internal components
- Three Silent Series R2 hydraulic bearing fans included
- Excellent cooling for all components
- Accommodates ATX power supplies
- Fan controller for all fans included
- USB 3.0 for fast file transfers
- 2 expansion slots
- 6 - supports either 3.5" or 2.5" HDD / SSD
- ATX PSUs, up to 160mm in length (To fit in combination with a long graphics card, PSUs with modular connectors on the back typically need to be shorter than 160 mm)
- Graphics cards, up to 310mm in length, when 2 HDD slots (1 HDD hanging bracket total) are removed (Graphics cards longer than 170 mm will conflict with PSUs longer than 160mm)
- Tower CPU coolers, up to 165 mm tall
- Case dimensions (W x H x D): 250 x 210 x 374 mm
- Case volume: 19.5 Liters
- Net weight: 4.9 kg
- Colors available: Black and White
- 2 - Front mounted 92mm Silent Series R2 hydraulic bearing fans, 1300 RPM speed (compatible with 80mm fans) - included
- 1 - Rear mounted 140mm Silent Series R2 hydraulic bearing fan, 1000 RPM speed (compatible with 120mm fans) - included
- Removable air filters for front fans and PSU
- Fan filter for graphics card
- 1 - fan controller for all 3 fans included
- 2 - USB 3.0
- 1 - 3.5mm audio in (microphone)
- HDD LED
http://www.fractal-design.com/home/product/cases/node-series/node-304-black
http://www.fractal-design.com/home/product/cases/node-series/node-304-white
Node 605
The Node 605 highlights a minimalistic, sleek Scandinavian appeal which is designed to integrate into your home theatre equipment.
Featuring a stunning exterior appearance accompanied by a modern, black interior with sound and vibration dampening materials, the Fractal Design Node 605 supports a full ATX motherboard as well as a graphics card up to 280mm in length.
Cleverly hidden behind the access panel on the solid 8mm thick aluminum front panel are two USB 3.0 ports, a FireWire port and a multi-format card reader for multiple formats.
Key Features:
Key Features:
- Solid aluminum front panel
- Supports full ATX motherboards
- Noise-dampening material
- 4 HDD/SSD slots
- Integrated card reader
- Two Silent Series R2 hydraulic bearing fans included
- Supports graphic cards up to 280mm in length (180mm with all hard drives in place)
- USB 3.0 and FireWire front connectors
- ATX, microATX, Mini ITX, DTX motherboard compatibility
- 7 expansion slots
- 4 - supports either 2.5" or 3.5" HDD / SSD
- 1x 12.7mm slim/slimline ODD (only supported with mATX or smaller motherboards)
- PSU compatibility: 180 mm (including any modular connectors) with both hard drive cages mounted or 190 mm (excluding cables and any modular connectors) with one hard drive cage mounted
- CPU cooler compatibility: Approx 125mm with side-mounted fans - For coolers with top-mounted fans, Fractal Design recommends that you add at least 30 mm clearance for decent airflow
- Case dimensions (W x H x D): 445 x 164 x 349 mm (excluding front panel - 440 x 162 x 341 mm)
- Net weight: 6.0 kg
- 5 fan slots total (3 - 120mm + 2 - 80mm)
- 2 - 120mm Silent Series R2 fans included
- Air filters for side fans and PSU
- Integrated three-channel fan controller (included)
- 180 mm with both hard drive cages mounted
- 255 mm with one hard drive cage mounted
- 290 mm in the top two ATX expansion card slots with two hard drive cages mounted
- 280 mm in the top four ATX expansion card slots with one hard drive cage mounted, containing one 3.5" HDD and one 2.5" SSD
- 2 - USB 3.0
- 1 - FireWire (IEEE 1394)
- 1 - card reader
- HDD LED
http://www.fractal-design.com/home/product/cases/node-series/node-605
Node 804
The Node 804 is a micro ATX chassis which focuses on cooling performance and maximum configurability, all packed in an interesting new form factor with Scandinavian elegant design.
The dual chamber layout separates hot running components from the cooler ones and allows for unrestricted airflow over the motherboard, processor and graphics card.
The case comes with three excellent 120mm fans but can be upgraded with several additional fans if needed.
Featuring plenty of options for placing water cooling components, tall heat sinks and hard drives.
The flexibility of this case really gives the users the possibility to create their optimal system build.
Key Features:
Key Features:
- Highly effective dual chamber case layout for best possible cooling.
- Minimalistic design with an elegant brushed aluminum front panel
- Unique hard drive mounting system, fitting up to 8 x 3.5″, 4 x 2.5" or up to 10 x 3.5", 2 x 2.5″ drives HDD/SSD
- Three Fractal Design Silent Series R2 fans included with the case and space for an additional 7 fans.
- Excellent water cooling support with space for up to 4 radiators simultaneously.
- All intakes feature removable dust filters providing a dust-free interior.
- Featuring a window side panel to show off your set up in style.
- Additional space in the front to mount a slim slot-in ODD, optical bay drive, and 2 x 2.5″ drives.
- Fan controller included.
- Five expansion slots that allows for multiple GPU setups.
- Micro ATX and Mini ITX motherboard compatibility
- 2 - 2.5" dedicated SSD unit positions
- 2 - Extra positions for either 3.5" or 2.5" drives
- 5 expansion slots
- 1 additional space in the front for a 12.7mm slim/slimline ODD
- 10 - Fan positions (3 x 120mm Silent Series R2 fans included)
- Filtered fan slots in front, top and bottom
- CPU coolers up to 160 mm in height
- PSU compatibility: ATX PSUs up to 260 mm deep
- Graphics card compatibility: Graphics cards up to 320mm in length. Graphics cards up to 290 mm in length may be installed if a fan is installed in the lower position in the front.
- Velcro strap for easy cable management
- Clear Window side panel included
- Case dimensions (WxHxD): 344 x 307 x 389 mm
- Net weight: 6 kg
- Package dimensions (WxHxD): 370 x 468 x 412 mm
- Package weight: 7.7kg
- Front: 4 - 120mm fans (included is one hydraulic bearing 120mm Silent Series R2 fan, 1000 RPM speed)
- Rear: 1 - 120/140mm fan (included is a hydraulic bearing 120mm Silent Series R2 fan, 1000 RPM speed)
- Rear: 1 - 120mm fan slots (included is 1 hydraulic bearing 120mm Silent Series R2 fan, 1000 RPM speed)
- Top: 4 - 120/140mm fans (not included)
- Fan controller: 1 - Integrated fan controller for up to 3 fans (included)
- Front (right chamber) - 240 mm radiator configurations up to 60 mm thick (with fans) and 278 mm tall are allowed.
- Front (left chamber) - 240 mm radiator configurations up to 60 mm thick (with fans) and 278 mm tall are allowed. Using a radiator in this position prevents the use of a fan in the top position just next to it.
- Top (right chamber) - 240/280 mm radiators up to 130mm thick (with fans) may be fitted if the HDD drive bays are taken out or placed elsewhere. No limitation to thickness.
- Top (left chamber) - 240 mm radiator configurations up to 130 mm thick (with fans) will fit. Radiators in this position limits the height of memory modules to 48 mm tall.
- *Maximum radiator configuration: 1x240mm,1x280mm and 2x120mm radiators simultaneously.
- 2 - USB 3.0
- Audio in/out
- Power button with LED (blue)
More information, photos, and reviews can be found here:
http://www.fractal-design.com/home/product/cases/node-series/node-804
Discontinued Cases
All discontinued cases can be found here:
http://www.fractal-design.com/home/product/cases/discontinued-products
