21 - 40 of 17618 Posts
I said I wouldn't post stage 3... but here it is. Probably a few things I could do to make it better, but it's not like there's a window to show it off anyway.
Originally Posted by nagle3092 View Post
Looking good so far, I recently just emailed NCIX to see if they are going to carry the Arctic White R3 but I'm still waiting on a response.
At least NCIX is kinda-ish close to alaska. Could be worse.
Can anyone with this case measure the front area where the two fans sit? I wanted to see if I can fit a 240 radiator into that spot. I will be removing the HDD trays and putting my watercooling parts in that spot.
Appreciate it.
Hi, I'm new on this forum I hope i will like it! I just wqanted to post couple of pic of my Fractal Design RIG. The Spec are un my description.
Thought I'd share my Fractal build with you. Can't see much of it around here, as I guess it's not that common in USA.
Case: Fractal Design R3 Black Pearl
The rest is on my sig. Btw: My OS SSD is stored on top of the CDrom, and my storage HDD is in the second 5,25 inch bay. Why not?
This R3 is really tempting. I have built three rigs onto that case at my workplace this week and really love it. Cable management is top class. Maybe I trade my Antec 300 to this
Senior Member
If only I had a Fractal Design.
They take feedback from users which is a big plus for such a company.
And their cases follow my golden rule, sleek and anti-flashy.
Originally Posted by ehpexs View Post
I'm just about the pull the trigger on an R3 + 620 watt Seasonic combo deal. Which color is better the silver or titanium front?
I like the titanium better than silver. The titanium is a bit darker and I like that.
Nice looking units.
How is the front intake air? On the old P181/2 there were some issues with poor intake unles you modded the grills and opened the front door. Only sorted that out on the P183, which is a real pity.
Thoughts?
The front panel door pretty much restricts air flow to the fans. There is very little space between the door and front bezel. I don't see a lot dust on the doors for the front fans. However, when I do open to doors the fans filters are covered in dust. The fans seem to pull air from the side and bottom vents on the front bezel. There is about a 1/2 inch space between the fan filter and the doors. You can actually see the fans and filters through the side vents.
Originally Posted by SupahSpankeh View Post
Nice looking units.
Thoughts?
I didnt get to test it yet. I'm still waiting for a RMA replacement of my XFX HD5870 XT, which didnt function as it should. I had to downclock it from the "small frabric overclock" to normal 5870 speeds, and I guess future overclocking wouldn't be really optimal either
The HD-587A-ZNE9 chip is probably a bad one, as I can't find it in any webshops.
I'll do some testing once I have the GFX card though! I'm expecting worse temperatures compared to the HAF932 I had before. But on the plus-side: With the R3, you can install dual top fans, side fan and a bottom fan for better airflow, and all intakes are filtered.
Yes! I will buy this R3 beauty tomorrow from my workplace!
At 59€ (normally 99€, I get everything on the purchase price). I though adding a one or two 140mm slip stream 500 or 800rpm on the top because my CPU cooler is mounted on sideways.
