You should never have those on auto when overclocking RAM. Auto typically runs them way too hot, often 1.3v or more for 3200MHz RAM when 1.15v or so is usually stable. At your frequency VCCIO and VCCSA could be much higher. You should set them manually to the lowest stable voltage as one of...
www.overclock.net
^ If you take a look at that specific post and a few posts down, it seems that apparently, in order to break the barrier, I have to set an atrociously high IMC voltage.
So as you say, perhaps it's really just that my IO/SA is too low (1.23V/1.25V respectively)
What is the point of high frequency RAM then, if they need to run at high IO/SA voltages that can potentially kill the CPU? That truly baffles me.
Anyway, what are those settings you told me to adjust? I've never seen them before.
I can't touch my RTLs or IOLs pretty much at all, or I risk potentially failed POSTs. My motherboard already tightens them as low as they can go, and the minimums fluctuate every so often.
Perhaps I'll leave IO/SA on Auto
just to see how much it requires for the system to POST.
