17281 - 17300 of 17401 Posts
Hi, I use 3000mhz cl15 micron e die cheap ram and tweak this image. I just changed the main timings, I don't understand subtimings. "This value is too much" do you have any suggestions that you can say lower this? Sory for bad english. Or is there any tip you can give to lower latency in rocket lake? Like round trip latency and ppd.
2488098
10700K/XII Apex/2x16 3200C14 G.Skill Bdie/RTX 2080
Try Trrdl 6, trtp 6-8, tcwl 16, trdrd_sg 6-7, trdwr's all at 10-12, twrrd_sg/dg 30/26, twrwr_sg 6-7. This should be a nice boost, make sure to stress test :).
Apex is still Apex...
2488169
Reactions: owikh84 and bscool
tWR and tCWL are where the most profit will be. They are very high now. Try 16 for both first, then see if tWR can go even lower like 14 or 12. Also try tRAS = CAS + tRCD + 2.
EDIT: If I daily say, 4400C17 and I wanna try to push for a higher frequency such as 4600. At what point in the primary timings would it generally perform worse? I'm testing at 18-19-19 now and it doesn't seem to wanna go any lower as 18-18-18 already gives quite a lot of errors lol. Even at 1.60v DRAM.
i personally couldnt boot at 4400c17 or i had errors, i dont remember. I solved my errors in a very weird way - i had to set io/sa to 1.36/1.34. Only these two exact values work for me, i get errors if i go below or higher, very strange behavior and i spent like 10 hours in bios before realizing that. Cache is at 48, vcore 1.385 but i think it could go 1.38.
My tcwl is at 16 but for some reason ascock timing configurator shows wrong value. TWR from what ive heard should be equal or higher than CL and this is true, i lose like 1000mb of read/write when i set it at 12.
ill try TRAS, thanks a lot!
I'm in a similar boat. I was able to get great AIDA latency results and show improvements in r/w/c at 4133; but lowering tRFC on this kit to anything lower than 350ns (736) does not pass Karhu.
Reverting back to 4200; but lowering tFAW and tWR to guide levels (the github one) is proving stable.
However, I have been just throwing numbers in and testing, hoping to find a magic mix instead of taking the time to test each and every single little change to rule out things. RAM overclocking is proving way more time consuming that I had intended. So since 4200 even ratio and 16-16-16-38... I won't be breaking any records anywhere but it sure it a LOT faster in games and desktop use.
Rather stable than on the edge IMHO.
But @Cpfan1 my IO/SA are a lot lower. 1.24/1.26 respectively.
Turns out it was not my sa/io values but wrong timings in the past. It was actually TRAS (when being set below 41) for the most part that caused me getting errors, now turns out im also able to lower my io and up my sa as it "should" be.
In shadow of the tomb raider there is no difference between 320 and 280, you shouldnt be worried about this particular timing too much. B die is very voltage and temp sensitive as i just learned by myself, for "high" frequencies 1.54v is just the beginning for dram, same with SA of 1.37.
Man, so close. 1 single error in 2 hours of TM5 Anta777 Extreme...
4600 18-19-19-39-340-2T. 1.60v RAM 1.45v SA 1.35v IO, ODT 80-40-40 PPD0 DLLb 0.
I wonder if the error was temp related, it did fine the first 54 minutes then threw 1 single error at 54:20 but the RAM was at 44.8 and 45.5c for the DIMMs which might be on the edge of what B-Die likes..
I should probably re-enable my DLL just to be sure..
If you really want to fine tune your memory, let's start with 4000.
By the way, guys, how are you?
Thanks for this. What are voltages here?
1.5V vdimm? 1.25 IO 1.3V sa?
I’ve currently taken my 3200-15-15-35 2x16GB bdie to 4000c17-19-19-39 at 1.45V vdimm, 1.22V IO/SA with similar sub timings as yours, but my primary are way slower - any lower (17-18-38 for example) at my set voltages gives Kathy error.
I might try pushing voltage a little further, maybe 1.5V and especially increase IO/SA to get lower primary timings. I haven’t even messed with RTL either. Using M13H and just popped back in a 10900K.
Got a F4-4000C16D-32GTRGA kit (XMP 16-16-16-36 1.4V). I wanted to compare it with my current one, F4-4000C16D-32GTRGB (XMP 17-18-18-38 1.4V), hoping for better overclocking results with eventually less voltage.
From what I've seen so far it looks like it's much worse. I tested both at 4400 16-17-17-36 with identical tight timings: older kit can do it with 1.485V, new one requires at least 1.5V just to boot (less DRAM voltage causes code 69 bootloop) but it fails GSAT almost immediately. Upped voltage to 1.52V and it still fails after a few minutes. Voltage gap increases even more at 4533: older kit is 99% stable in every scenario (apart from some rare GSAT errors I am dealing with by adjusting Slopes) with 1.53V, newer needs 1.6V just to boot consistently, and of course fails GSAT immediately.
Am I doing something wrong with my testing methodology or can I assume that, contrary to my expectations, the newer kit is simply worse than the older?
@Salve1412 I have quite a few different dual rank b die(4266c17, 3600c14, 3200c14 etc) and recently got the Neo 4000c16 kit and it the best kit I have with limited testing using z490 Apex/11900k. [email protected] [email protected] boot/bench [email protected] I have not done any longer term stability test as I have a z590 Apex coming.
I would think the [email protected] kits should be some of the best but it is probably somewhat still to the ram lottery gods.
Alrighty, decided to tune my ram just a little more after reading some more of the recent discussion.
I have not messed with RTL/IOL yet, because when I did, it didn't boot lol. I had changed CHA/CHB Dimm1 Rank 1 values, but maybe that's not the right ones to mess with? so any suggestions would be great - I've added my BIOS pictures for it. M13H with 10900K.
Original XMP on the ram: 2x16GB Bdie DR [email protected]
Right now I'm at [email protected] with 1.225V/1.225V IO/SA set in BIOS.
17-17-38 had errors and 17-18-38 had erros, but only changing to 17-19-38 would pass any amount of karhu. 1.5V didn't seem to help in that timing either with some other various primaries. Probably due to it being a poor bin of Bdie DR in the first place. Oh well it was really cheap.
Thanks for all the info in the thread everyone! Please send some suggestions I can apply and test.
2488278
2488279
2488280
@aznguyen316
I'm at 4200 @ 16-16-16- with barely better results via AIDA than you. 40ns~ with 60K~ 62K~ and 58.5K~ but on MSI z490 board. I think you probably have better board that should be able to do more. I dunno.
How did you get that low of a latency.. it's a Hero not an Apex so not a 2 slot board, 4000C16 should by no means be faster then my 4400C17 latency wise, RTL/IO aren't far off from what I run at 4400C17 (66/66/6/6), only thing different is your much lower tRDWR at 10 where I need 15 for 4400C17. Even our tWR, tCWL and such is identical.. I'm not that far off at 36.3ns but still..
I'm going to try 4000 lol. Just see how much I can pull out of it.
What ODT Wr, Nom, Park are you using?
I used the following settings:
[2021/04/08 18:14:42]
Ai Overclock Tuner [XMP I]
XMP [XMP DDR4-3000 14-14-14-34-1.35V]
BCLK Frequency [100.0000]
PCIE Frequency [100.0000]
ASUS MultiCore Enhancement [Enabled – Remove All limits]
SVID Behavior [Best-Case Scenario]
AVX Instruction Core Ratio Negative Offset [User Specify]
AVX Instruction Core Ratio Negative Offset Value [0]
CPU Core Ratio [Sync All Cores]
ALL-Core Ratio Limit [50]
BCLK Frequency : DRAM Frequency Ratio [Auto]
DRAM Odd Ratio Mode [Enabled]
DRAM Frequency [DDR4-4000MHz]
Xtreme Tweaking [Disabled]
CPU SVID Support [Enabled]
Maximus Tweak [Mode 1]
DRAM CAS# Latency [16]
DRAM RAS# to CAS# Delay [16]
DRAM RAS# ACT Time [36]
DRAM Command Rate [2N]
DRAM RAS# to RAS# Delay L [6]
DRAM RAS# to RAS# Delay S [4]
DRAM REF Cycle Time [296]
DRAM REF Cycle Time 2 [Auto]
DRAM REF Cycle Time 4 [Auto]
DRAM Refresh Interval [65024]
DRAM WRITE Recovery Time [12]
DRAM READ to PRE Time [6]
DRAM FOUR ACT WIN Time [16]
DRAM WRITE to READ Delay [Auto]
DRAM WRITE to READ Delay L [6]
DRAM WRITE to READ Delay S [2]
DRAM CKE Minimum Pulse Width [0]
DRAM Write Latency [16]
ODT RTT WR (CHA) [80 DRAM Clock]
ODT RTT PARK (CHA) [40 DRAM Clock]
ODT RTT NOM (CHA) [0 DRAM Clock]
ODT RTT WR (CHB) [80 DRAM Clock]
ODT RTT PARK (CHB) [40 DRAM Clock]
ODT RTT NOM (CHB) [0 DRAM Clock]
ODT_READ_DURATION [Auto]
ODT_READ_DELAY [Auto]
ODT_WRITE_DURATION [Auto]
ODT_WRITE_DELAY [Auto]
Data Rising Slope [Auto]
Data Rising Slope Offset [Auto]
Cmd Rising Slope [Auto]
Cmd Rising Slope Offset [Auto]
Ctl Rising Slope [Auto]
Ctl Rising Slope Offset [Auto]
Clk Rising Slope [Auto]
Clk Rising Slope Offset [Auto]
Data Falling Slope [Auto]
Data Falling Slope Offset [Auto]
Cmd Falling Slope [Auto]
Cmd Falling Slope Offset [Auto]
Ctl Falling Slope [Auto]
Ctl Falling Slope Offset [Auto]
Clk Falling Slope [Auto]
Clk Falling Slope Offset [Auto]
DRAM RTL INIT value [67]
DRAM IOL INIT value(CHA) [4]
DRAM IOL INIT value(CHB) [4]
DRAM RTL (CHA DIMM0 Rank0) [0]
DRAM RTL (CHA DIMM0 Rank1) [0]
DRAM RTL (CHA DIMM1 Rank0) [61]
DRAM RTL (CHA DIMM1 Rank1) [61]
DRAM RTL (CHB DIMM0 Rank0) [0]
DRAM RTL (CHB DIMM0 Rank1) [0]
DRAM RTL (CHB DIMM1 Rank0) [62]
DRAM RTL (CHB DIMM1 Rank1) [62]
DRAM IOL (CHA DIMM0 Rank0) [0]
DRAM IOL (CHA DIMM0 Rank1) [0]
DRAM IOL (CHA DIMM1 Rank0) [7]
DRAM IOL (CHA DIMM1 Rank1) [7]
DRAM IOL (CHB DIMM0 Rank0) [0]
DRAM IOL (CHB DIMM0 Rank1) [0]
DRAM IOL (CHB DIMM1 Rank0) [7]
DRAM IOL (CHB DIMM1 Rank1) [7]
CHA IO_Latency_offset [21]
CHB IO_Latency_offset [21]
CHA RFR delay [14]
CHB RFR delay [14]
Early Command Training [Auto]
SenseAmp Offset Training [Enabled]
Early ReadMPR Timing Centering 2D [Enabled]
Read MPR Training [Enabled]
Receive Enable Training [Enabled]
Jedec Write Leveling [Enabled]
LPDDR4 Write DQ DQS Retraining [Enabled]
Early Write Time Centering 2D [Auto]
Early Read Time Centering 2D [Auto]
Write Timing Centering 1D [Enabled]
Write Voltage Centering 1D [Auto]
Read Timing Centering 1D [Auto]
Dimm ODT Training* [Auto]
DIMM RON Training* [Auto]
Write Drive Strength/Equalization 2D* [Auto]
Write Slew Rate Training* [Auto]
Read ODT Training* [Auto]
Read Equalization Training* [Auto]
Read Amplifier Training* [Auto]
Write Timing Centering 2D [Auto]
Read Timing Centering 2D [Auto]
Command Voltage Centering [Auto]
Write Voltage Centering 2D [Auto]
Read Voltage Centering 2D [Auto]
Late Command Training [Auto]
Round Trip Latency [Enabled]
Turn Around Timing Training [Disabled]
Rank Margin Tool [Enabled]
Rank Margin Tool Per Bit [Auto]
Margin Check Limit [Disabled]
Memory Test [Disabled]
DIMM SPD Alias Test [Auto]
Receive Enable Centering 1D [Auto]
Retrain Margin Check [Disabled]
Write Drive Strength Up/Dn independently [Disabled]
CMD Drive Strength and Tx Equalization [Auto]
CMD Slew Rate Training [Auto]
Command Normalization [Disabled]
Early DQ Write Drive Strength and Equalization Training [Disabled]
Read Voltage Centering 1D [Enabled]
Dimm ODT CA Training [Enabled]
DQ DFE Training [Disabled]
tRDRD_sg_Training [6]
tRDRD_sg_Runtime [6]
tRDRD_dg_Training [4]
tRDRD_dg_Runtime [4]
tRDWR_sg [10]
tRDWR_dg [10]
tWRWR_sg [6]
tWRWR_dg [4]
tWRRD_sg [28]
tWRRD_dg [24]
tRDRD_dr [5]
tRDRD_dd [0]
tRDWR_dr [10]
tRDWR_dd [0]
tWRWR_dr [7]
tWRWR_dd [0]
tWRRD_dr [5]
tWRRD_dd [0]
TWRPRE [32]
TRDPRE [6]
tREFIX9 [127]
OREF_RI [0]
TXP [4]
PPD [0]
MRC Fast Boot [Disabled]
Delay after Train [Disabled]
DRAM CLK Period [Auto]
Memory Scrambler [Enabled]
Channel A DIMM Control [Disable DIMM0]
Channel B DIMM Control [Disable DIMM0]
Trace Centering [Disabled]
MCH Full Check [Enabled]
Mem Over Clock Fail Count [Auto]
Training Profile [Standard Profile]
DLLBwEn [2]
Legacy Mode [Disabled]
SPD Write Disable [TRUE]
XTU Setting [Auto]
Voltage Monitor [Die Sense]
CPU Load-line Calibration [Level 8]
Synch ACDC Loadline with VRM Loadline [Disabled]
CPU Current Capability [140%]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Disabled]
Active Frequency Mode [Disabled]
CPU Power Duty Control [Extreme]
CPU Power Phase Control [Extreme]
CPU Power Thermal Control [130]
CPU VRM Thermal Control [Enabled]
DRAM Current Capability [130%]
DRAM Switching Frequency [Manual]
Fixed DRAM Switching Frequency(KHz) [500]
CPU Core/Cache Boot Voltage [Auto]
DMI Boot Voltage [Auto]
CPU System Agent Boot Voltage [Auto]
CPU VCCIO Boot Voltage [Auto]
PLL Termination Boot voltage [Auto]
CPU Standby Boot Voltage [Auto]
CPU Core Auto Voltage Cap [Auto]
CPU VCCIO Auto Voltage Cap [Auto]
CPU System Agent Auto Voltage Cap [Auto]
Package Temperature Threshold [Auto]
Regulate Frequency by above Threshold [Auto]
CPU Core/Cache Current Limit Max. [255.75]
Long Duration Package Power Limit [4095]
Package Power Time Window [448]
Short Duration Package Power Limit [4095]
IA AC Load Line [0.01]
IA DC Load Line [0.01]
TVB Voltage Optimizations [Disabled]
V-Max Stress [Disabled]
Overclocking TVB [Disabled]
Offset Mode Sign 1 [+]
V/F Point 1 Offset [Auto]
Offset Mode Sign 2 [+]
V/F Point 2 Offset [Auto]
Offset Mode Sign 3 [+]
V/F Point 3 Offset [Auto]
Offset Mode Sign 4 [+]
V/F Point 4 Offset [Auto]
Offset Mode Sign 5 [+]
V/F Point 5 Offset [Auto]
Offset Mode Sign 6 [+]
V/F Point 6 Offset [Auto]
Offset Mode Sign 7 [+]
V/F Point 7 Offset [Auto]
Offset Mode Sign 8 [+]
V/F Point 8 Offset [Auto]
Realtime Memory Timing [Enabled]
FCLK Frequency for Early Power On [1GHz]
Initial BCLK Frequency [Auto]
BCLK Amplitude [Auto]
BCLK Slew Rate [Auto]
BCLK Spread Spectrum [Auto]
BCLK Frequency Slew Rate [Auto]
PCIE/DMI Amplitude [Auto]
PCIE/DMI Spread Spectrum [Auto]
PCIE/DMI Frequency Slew Rate [Auto]
PCIE/DMI Slew Rate [Auto]
Cold Boot PCIE Frequency [Auto]
DRAM VTT Voltage [0.70000]
VPPDDR Voltage [2.50000]
DMI Voltage [1.15000]
Internal PLL Voltage [Auto]
GT PLL Voltage [Auto]
Ring PLL Voltage [Auto]
System Agent PLL Voltage [Auto]
Memory Controller PLL Voltage [Auto]
CPU Standby Voltage [1.00000]
PLL Bandwidth [Auto]
Eventual DRAM Voltage [Auto]
Eventual CPU Standby Voltage [Auto]
Eventual PLL Termination Voltage [Auto]
Eventual CPU VCCIO Voltage [Auto]
Eventual DMI Voltage [Auto]
PVD Ratio Threshold [Auto]
System Agent Bandgap Workaround [Auto]
Cooler Efficiency Customize [Keep Training]
Cooler Re-evaluation Algorithm [Normal]
Optimism Scale [100]
Ring Down Bin [Disabled]
Min. CPU Cache Ratio [47]
Max CPU Cache Ratio [47]
BCLK Aware Adaptive Voltage [Enabled]
CPU Core/Cache Voltage [Manual Mode]
- CPU Core Voltage Override [1.200]
DRAM Voltage [1.40000]
CPU VCCIO Voltage [1.16000]
CPU System Agent Voltage [1.20000]
PLL Termination Voltage [1.00000]
PCH Core Voltage [1.05000]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM0 Rank1 BL7 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHA DIMM1 Rank1 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM0 Rank1 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank0 BL7 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL0 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL1 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL2 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL3 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL4 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL5 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL6 [Auto]
DRAM DATA REF Voltage on CHB DIMM1 Rank1 BL7 [Auto]
PCI Express Native Power Management [Disabled]
DMI Link ASPM Control [Disabled]
ASPM [Disabled]
L1 Substates [Disabled]
PCI Express Clock Gating [Enabled]
PEG - ASPM [Disabled]
Software Guard Extensions (SGX) [Disabled]
Tcc Offset Time Window [Auto]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetch [Enabled]
Intel (VMX) Virtualization Technology [Disabled]
Active Processor Cores [All]
Hyper-Threading [Enabled]
Hyper-Threading of Core 0 [Enabled]
Hyper-Threading of Core 1 [Enabled]
Hyper-Threading of Core 2 [Enabled]
Hyper-Threading of Core 3 [Enabled]
Hyper-Threading of Core 4 [Enabled]
Hyper-Threading of Core 5 [Enabled]
MonitorMWait [Enabled]
Boot performance mode [Turbo Performance]
Intel(R) SpeedStep(tm) [Auto]
Intel(R) Speed Shift Technology [Disabled]
Turbo Mode [Enabled]
CPU C-states [Disabled]
Thermal Monitor [Enabled]
Dual Tau Boost [Disabled]
VT-d [Disabled]
Memory Remap [Enabled]
PCIEX16_1 Link Speed [Auto]
PCIEX16_2 Link Speed [Auto]
PCIe Speed [Auto]
SATA Controller(s) [Enabled]
SATA Mode Selection [AHCI]
Aggressive LPM Support [Disabled]
SMART Self Test [None]
SATA6G_1(Black) [Enabled]
SATA6G_1 Hot Plug [Disabled]
SATA6G_2(Black) [Enabled]
SATA6G_2 Hot Plug [Disabled]
SATA6G_3(Black) [Enabled]
SATA6G_3 Hot Plug [Disabled]
SATA6G_4(Black) [Enabled]
SATA6G_4 Hot Plug [Disabled]
SATA6G_5(Black) [Enabled]
SATA6G_5 Hot Plug [Disabled]
SATA6G_6(Black) [Enabled]
SATA6G_6 Hot Plug [Disabled]
PTT [Disable]
Discrete Thunderbolt(TM) Support [Disabled]
Above 4G Decoding [Enabled]
Re-Size BAR Support [Disabled]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
SanDisk [Auto]
U32G2_3 [Enabled]
U32G2_4 [Enabled]
U32G2_5 [Enabled]
U32G1_7 [Enabled]
U32G1_8 [Enabled]
U32G1_E1 [Enabled]
U32G1_E2 [Enabled]
U32G1_E3 [Enabled]
U32G1_E4 [Enabled]
USB11 [Enabled]
USB12 [Enabled]
U32G2_1 [Enabled]
U32G2_C6 [Enabled]
Network Stack [Disabled]
PCIe Bandwidth Bifurcation Configuration [Auto]
HD Audio [Enabled]
Intel 1G LAN [Disabled]
MARVELL 5G LAN [Disabled]
USB power delivery in Soft Off state (S5) [Enabled]
Connectivity mode (Wi-Fi & Bluetooth) [Enabled]
When system is in working state [All On]
Q-Code LED Function [POST Code Only]
When system is in sleep, hibernate or soft off states [Stealth Mode]
M.2_1 Configuration [Auto]
M.2_2 Configuration [Auto]
M.2_3 Configuration [Auto]
U32G2_C6 Type C Power Mode [Auto]
Restore AC Power Loss [Power Off]
Energy Star Ready [Disabled]
ErP Ready [Disabled]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
Device [Samsung SSD 860 EVO 1TB]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
Chipset Temperature [Monitor]
T_Sensor Temperature [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Chassis Fan 3 Speed [Monitor]
High Amp Fan Speed [Monitor]
Water Pump+ Speed [Monitor]
AIO Pump Speed [Monitor]
CPU Core Voltage [Monitor]
12V Voltage [Monitor]
5V Voltage [Monitor]
3.3V Voltage [Monitor]
Flow Rate [Monitor]
AI Cooling [Disabled]
CPU Fan Q-Fan Control [PWM Mode]
CPU Fan Step Up [0 sec]
CPU Fan Step Down [0 sec]
CPU Fan Speed Low Limit [200 RPM]
CPU Fan Profile [Manual]
CPU Fan Upper Temperature [65]
CPU Fan Max. Duty Cycle (%) [60]
CPU Fan Middle Temperature [50]
CPU Fan Middle Duty Cycle (%) [50]
CPU Fan Lower Temperature [30]
CPU Fan Min Duty Cycle (%) [30]
Chassis Fan 1 Q-Fan Control [Disabled]
Chassis Fan 2 Q-Fan Control [PWM Mode]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [0 sec]
Chassis Fan 2 Step Down [0 sec]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Profile [Manual]
Chassis Fan 2 Upper Temperature [80]
Chassis Fan 2 Max. Duty Cycle (%) [60]
Chassis Fan 2 Middle Temperature [50]
Chassis Fan 2 Middle Duty Cycle (%) [50]
Chassis Fan 2 Lower Temperature [30]
Chassis Fan 2 Min Duty Cycle (%) [35]
Chassis Fan 3 Q-Fan Control [PWM Mode]
Chassis Fan 3 Q-Fan Source [CPU]
Chassis Fan 3 Step Up [0 sec]
Chassis Fan 3 Step Down [0 sec]
Chassis Fan 3 Speed Low Limit [200 RPM]
Chassis Fan 3 Profile [Manual]
Chassis Fan 3 Upper Temperature [80]
Chassis Fan 3 Max. Duty Cycle (%) [60]
Chassis Fan 3 Middle Temperature [50]
Chassis Fan 3 Middle Duty Cycle (%) [50]
Chassis Fan 3 Lower Temperature [30]
Chassis Fan 3 Min Duty Cycle (%) [35]
High Amp Fan Q-Fan Control [DC Mode]
High Amp Fan Q-Fan Source [CPU]
High Amp Fan Step Up [0 sec]
High Amp Fan Step Down [0 sec]
High Amp Fan Speed Low Limit [200 RPM]
High Amp Fan Profile [Standard]
Water Pump+ Q-Fan Control [Disabled]
AIO Pump Q-Fan Control [Disabled]
CPU Temperature LED Switch [Enabled]
Launch CSM [Disabled]
OS Type [Other OS]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
AMI Native NVMe Driver Support [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
Setup Mode [Advanced Mode]
Boot Sector (MBR/GPT) Recovery Policy [Local User Control]
Next Boot Recovery Action [Skip]
Flexkey [Reset]
Setup Animator [Disabled]
Profile Name []
Save to Profile [1]
DIMM Slot Number [DIMM_A2]
Download & Install ARMOURY CRATE app [Disabled]
By the way, guys, I have already been sent a whale F4-4000C16D-32GTSRA, on May 5-10 it should be with me. Let's see what he's capable of.
I also notify you about XMP 4000 14-15-15-35 1.55V.
@aznguyen316 , Let's correspond in private messages?
Just hangin' out
