17321 - 17340 of 17401 Posts
Listen man, SOMEBODY is doing it. It's either gskill, intel or people from this website. i'm 100% positive. This isn't my first rodeo ok? My IQ is 168, I know whats going on ok? All it takes is for one industry employee to flip ok? Enough of this nonsense.
Hi...
Do you think there is a way to lower latency?
I'll appreciate any suggestion ! :)
2488524
2488522
OC...D
Hi...
lower the RTLs if the sticks and board can handle it. RTLs are the most important timings affecting latency or any measurement which requires a trip off the sticks. Also tWR and tWCL should be able to go at least 2 ticks below CAS. Then.. is CAS (tCL) the lowest value the stick can POST at?
Reactions: The Pook
Memory speed test:Aida 64 vs Geekbench 3
This is older set.:
2488763
2488764
And the newest set:
2488765
2488766
Aida 64 result is almost same,but Geekbench 3 get 250 points more.Much bigger improvement.
@SoldierRBT
ich have tested a little bit for hot summer, how stable it will be with [email protected],55V.
With my Set slope is odt 80/48/40 arround 35° bootstable.Over that it gives boot problems and by 40° H2O and 45°+ on mem i have get a mem error.
Gsat is also okay, the most Problem is really the boot stability.
I will never seen more as 35°H2O so it is ok.For really hot Temps 50° on Mem i think is 4600CL17-17 the Limit.
4700Cl17 for 24/7 is too much with hard subs from 18°-35°H2O with low voltage's in my case.
@SoldierRBT
Been using 4600C17-17 1.56v for past month no issues. 4666C17-17 1.58v it's stable but I had boot issues from time to time. 4700C17-17 haven't been able to boot. 4700C16-17 boots but it's hard to make it stable, probably a bench profile.
@SoldierRBT
Test it with higher ODT's, before i had 80/40/34 but at higher H2O temps it's not good.
In my case 80/48/40 are better for more temp range.
80/40/34 is good at cold temps.
For simulate summer i have stop all fans and have run Furmark for over 30min to reach up to 40°H2O.
I want to know how the max stability range is.
I think 4666CL17-17 will be stable in every case with my watercooling System.
P.s.
You can also do one setting for summer and one for cold temps at same frequency.
Any ideas on how to get 68k read out of this thing? Ripjaws heatsinks 1.5v dram 1.38 sa/io, 49 ring. Thanks in advance!
2489022
Sadly this kit walls at 4600 18-19-41 (or 17-19-40), giving me 3-6 errors in TM5 extreme. I dont trust ripjaws "heatsinks" to feed them more than 1.57v.
We are using watercooling on the dimm :D
Rip V heatsinks is easy to uninstall 🥳
Reactions: menko2
Hi, I use 3000mhz cl15 micron e die cheap ram and tweak this image. I just changed the main timings, I don't understand subtimings. "This value is too much" do you have any suggestions that you can say lower this? Or is there any tip you can give to lower latency in rocket lake? Like round trip latency and ppd.
Micron E Die
2489085
This is my setup: i7 10700k, 16gb patriot 4400mhz cl 19, z490 unify. I running memory 4400mhz cl 17 18 18 36 at 1.520 ram voltage and 1.38/1.28 sa/io. Latency around 36 ms. I think it is not bad, but i would like to squeeze out some more performance if possible. Iols are 64-68, 7-8. Any advices would be very appreciated.
I'm stuck at this point with the guide i have been using. There is no mention about RTL, IO-L, TCKE and other values.
Higher than 4300mhz causes problems.
The ram-kit is g.skill 3600mhz [email protected]
I'm running the ram at 1.5v, SA 1.40v, IO 1.30.
Any help with some values that can be improved?
2489147
I Have a maximus xii Extreme with 4x8gb at 4300 16-16-16-34 and cpu at 5.2/46.
An Apex With 2x8 4533 17-17-17-36 cpu 5.3/50.
My cpu with the Extreme Is 7-8º hotter i think for dual rank or dual dimm.
If I put 2x16 on the Apex the temperature and clock Will be the same as the Extreme?
