17981 - 18000 of 18019 Posts
It's imc diff, not MB.
Though Gigabutt bios sux.
This review of the 5900x shows that in gaming the 11900k beats the 10900k.
In the 11900k forum users say the 10900k beats the 11900k so I'm confused.
Which one is better for gaming of the two?
Depend on the skill level of the user ;)
Do you play 1080p 360hz?
If not, don't bother to. Buy whatever ;)
You've 10900k 11900k and 5950, for you which Is the best?
10900k I'm getting the most consistent fps in Battlefield V.
I'm playing BF games 99%
9 Cans of Ravioli
Mine is 79. Not bad for 10850k probably. But, the IMC, seems very bad.
Inviato dal mio AC2003 utilizzando Tapatalk
Better than my 10850K's 57 :D can still do 4266 on Z590 just fine, though. not sure if it's limited to higher from the IMC or board.
got a 10900K coming tomorrow, will see if it goes up or not.
So I've been tweaking for a bit and this seems to be the best stable configuration I can come up with.
think you meant to post here
I'm struggling to get 3866Mhz stable... I'm already running 1.46V DRAM voltage. Do you guys have any suggestions?
2517681
9 Cans of Ravioli
I couldn't get 4 DIMMs stable above 3733 on my XIII. I could boot at 4000 but nothing got it stable. Just sold it and swapped to a 16x2 kit.
How long should TM5 Universal2 be rin for? 1 hour min?
I got this to pass 55 min of TM5 Universal2. Not sure what the issue is when I start tweaking sub timings. I did run lower VCCIO on this run.
2517687
2517692
2517693
Hello, who can help go lower than 40ns?
Running Vdimm 1.41 vccio 1.185 SA 1.185.
Do not wanna raise up Vdimm to much.
I cannot go past 4000mhz on this board.
Can tighten timings, but when raise Vdimm to 1.5v and primary to 15 16 35
latency go to 38.9ns but system feels not so responsive.
Also i tried to lower by half Trfc and do not see sny improvement in ns latency.
This ram is Gskill Royal f4 4600 C18 GTRS 1.45V 2x8Gb.
Dont have ppd settings in this motherboard.
Help to go lower if possible, - thanks.
Try 1.53v vdram ,1.45 vccsa and more cooling on the dimms ;)
That doesn't sound like something you'd want daily. o_O What I can't understand is that I can easily run 3800 stable with heavy tweaking but barely get 3866 past the primary timings. Does this seem unusual for a 66Mhz bump?
Reactions: fray_bentos
How is 50-55C max DIMM temp under heavy memory testing?
Reactions: Astral85
Has anyone had their Windows Time stop syncing when RAM OC's run into errors? I've had this several times and have to re-sync the clock. Whenever I hit memory errors I frequently run chkdsk, SFC and DISM health checks and then make my daily backup image.
It's just to see if ut helping... if that is stable, set voltage down in small steps. :)
Under 40c on b-die, and it's more easy to get stable.
That's my bottleneck as well, that trade off.
Like, I need more voltage to be stable but then it gets hotter and makes it temperature unstable. So I lower voltage, temps fine, now it's voltage unstable..
I hate B-Die and it's temp sensitivity.. Max I can run in the summer VDIMM wise is 1.50v. That tops at ~45c which is still stable but 1.53v (for 4500C17) gets to 48c and that is the point at which my DIMM'S go "nope".
