WELCOME TO THE GTX 780 LIGHTNING OWNER'S CLUB!
(Image Courtesy of @skyn3t. Thank him for the awesome job on the banner!)
https://docs.google.com/spreadsheet/pub?hl=en&hl=en&key=0AtCE1IKeIwUYdF9na3RGTlNGOHJNT29qVU9lT0JERWc&output=html&widget=true
How to be added:
Please post a GPU-Z Validation with your OCN Username as the Owner of the Validation Link and I'll add you to the owner's list!
Also, if I haven't gotten to you (as I'm generally extremely busy), please send me a PM on OCN with your GPU-Z validation, and I'll add you to the list.
8/30/2013 (3:35pm CST): Username in GPU-Z Validation MUST be the same as your OCN Username
MSI Afterburner 3.0.0 BETA15 SE (For Lightning 680/770/780)
STOCK GTX 780 Lightning BIOS(s):
**USE AT YOUR OWN RISK**
GTX 780 Lighting BIOS: 300% PLimit (MSI @ Guru3D)
Skyn3t's Regular/LN2 "Unlocked" vBIOS:
Skyn3t's Regular/LN2 "Unlocked" vBIOS >>HYNIX MEMORY SUPPORT<<:
Skyn3t's EZFlash Tool! (For all your vBIOS flashing needs! No nudes.)
**The users Kinaesthetic and skyn3t will not be held liable for any dead/killed card. Always take precautions when flashing your card with a different vBIOS. Thanks!
Enjoy!
MSI Fan Control Software for the GTX 780 Lightning (Thanks to FtW 420!)
"Unlocking" Voltages:
How to be added:
- Direct Link Download (Will start 5 seconds after page has loaded)
- Regular BIOS:
GK110 (Lightning BIOS).zip 66k .zip file
- LN2 BIOS:
- Refer to Skyn3t's BIOS below. The official 300% PLimit BIOS is borked. I will not be posting this due to the severe problems this vBIOS has. Please do not attempt to PM me asking for it. I won't give it away, and I'd advise the few that actually still have the file downloaded to not give it away. Thanks!
sky-LN2-vbios-300w-640w-rev2.zip 471k .zip file
sky-stock-vbios-300w-640w-rev2.zip 471k .zip file
- MSI (1462)
- *sky-LN2-vbios-300w-640w-rev2
- vbios rev2 80.10.3A.00.49
- Boost disabled
- 1.212v unlocked
- Under-volting
- Default power target 100%: 300w; 300% slide: 640w
- sky-stock-vbios-300w-640w-rev2
- vbios rev2 80.10.3A.00.47
- Boost disabled
- 1.212v unlocked
- Under-volting
skyn3t vBios Regular/LN2 "Unlocked" Hynix Memory
B1 Chip
B1 Chip
sky-LN2-vbios-300w-640w-rev3.zip 67k .zip file
- MSI (1462)
- vbios rev2 80.80.21.00.3D
- Boost disabled
- 1.212v unlocked
sky-stock-vbios-300w-640w-rev3.zip 67k .zip file
- MSI (1462)
- vbios rev2 80.80.21.00.36
- Boost disabled
- 1.212v unlocked
- LN2:
sky-LN2-vbios-300w-640w-rev4.zip 131k .zip file
This revision contains performance
for Hynix VRAM (602-V296-03S)
B1 Chip
Base core clock 980 Mhz
vBios 80.80.21.00.3C
Boost disabled
1.212v unlocked
Default power target 100% 300w by 300% slide 640w
- Stock (Regular)
sky-stock-vbios-300w-640w-rev4.zip 135k .zip file
N780 Lightning with Hynix VRAM (602-V296-03S) Contains Performance BIOS
vBios 80.80.21.00.60
Boost disabled
1.212v unlocked
- Link
- >>Located under EVGA PrecisionX Downloads<<
Enjoy!
- Navigate your way to this (Link) for Rbby's Tool.
- Once downloaded, right click it and go to "Properties".
- Under the Compatibility Tab, check the "Run As Administrator" checkbox, and then close the Properties tab window.
- Run Rbby's Tool, then open up MSI Afterburner (Specifically version 3.0.0 BETA 15 SE: >Download Link<)
- Follow the instructions for software overvolting as per his thread: Link
- Enjoy unlocked voltages! (for Vcore at least
