16381 - 16400 of 16402 Posts
I read an article that seemed to indicate two bridges might make a diff in framerates for a few games and it might have only been one.
That's interesting. I would plug in the second bridge if I had one. I'm having trouble finding ONE for sale locally and for some reason I can't post in the for sale/wanted section so I can't even ask if someone nearby has an extra one for sale.
Overclocking
just one final thing to my 980 ti
Max "power limit" (121%) through bios meaning no more MSI Afterburner to apply the 121% Limit. I know where to adjust this value in Maxwell II BIOS Tweaker but NOT sure if it's safe to do.
AKA
"Def (mW) 100% 350w" now 425w
"Max (mW) 121% 425w" changes to 100%
Which means 100% default power limit no need for any program?
professional curmudgeon
AKA
short answer:
yep. just make sure to use math for the 6 and 8 pin 100% ie 175(6) and 250(8) for 425.
E: i don't count the pci-e slot power - the 66/75 i use for wiggle room, i never touch that.
Overclocking
short answer:
well I took the risk. Just finished 3rd run of superposition 8K custom (to eat up 6GB Vram).
Power limit 420w out of 425w [+101% afterburner]
Fan RPM 4000rpm all modes
Memory 3505Mhz -> 3850 [+51 afterburner]
Fixed P02 mem clock in recording mode [3505 to 3850]
benchmark hits shy of 410w!
Overclocking
short answer:
You could pull 200w+ out of the motherboard. I wouldn't recommend doing it though lol
What is the Radeon R9 in your system? are you trying to run 2 completely different graphics cards? if so, it does not work well.
Please read up on the troubleshooting that we're doing with this 980 Ti. The Radeon's only purpose is as a spare (working) graphics card to provide display-out. Swapping the R9 for a GTX 750 Ti as the primary GPU makes no difference (confirmed).
If the 980 Ti is the only card in the system, the system will not boot (replicated on 3 separate computers). If it's a secondary card, the system will boot, but the driver won't load on the 980 Ti.
As an aside, AMD and Nvidia cards can co-exist in the same system without issue. That hasn't caused problems in a long, long time.
Just living in a van...
August 2019 Foldathon!
Hello 980Ti Owner's Club!
I apologize for potentially derailing otherwise productive conversation, but this will only take a moment (yes this is a canned message I'm using in other clubs too, sorry)
You might have noticed the banner link to the upcoming Foldathon, August 2019 Edition. The OCN Folding team has been losing 24/7 membership for some time, and to make up for that we encourage other OCN users to jump in for a couple of days and donate a little bit of CPU and GPU time to helping find a cure for a variety of diseases, notably various cancer's but also Alzheimer's and others. We'd really appreciate it if you would join us!
Link to the Foldathon is here: August 2019 Foldathon
Link to the Stanford [email protected] Website is here: [email protected] Windows Download Page
I promise it's easy to set up! You don't need to worry about changing driver's or anything like that. Just do the following:
1a. If you don't already have an FAH passkey, create one here: Passkey Request Form
1b. If you haven't had a passkey before, you might want to run this for a day or two leading up to the Foldathon in order to qualify for bonus points.
2. Download/install the installer: [email protected] Windows Download Page
3. Once installed it'll autorun, enter your account and passkey you just created, and enter "37726" as your team number for OCN
4. Once you have it working, head to the Foldathon page (linked above) to register!
After that, you're pretty much done! If you don't want your CPU to run you can either pause it individually or disable it completely in the advanced controller - Configure -> Slots -> Select CPU -> Select 'Remove' -> DONE.
This whole process will take less than ten minutes, I promise. Put that studly computer to work and help us out! You can always shut down or remove the FAH controller afterwards. :)
Hi, i have downloaded a bios mod OC from gtx 780 ti owners club for my Asus 780 Ti with a fixed clock.
It works Amazing. Now i want flash my Asus GTX 980 Ti but i dont find any Bios mods for Download. The settings are to complicated for me.
Can pls someone Upload or give me a link for Asus GTX 980 Ti with a fixed Clock setting (High but stable). some games makes problems with the boost function.
Hey everyone,
I've been trying to see what my max OC is on my hydro copper 980ti, and so far I can only get +150 on core (brings me to about 1500). I'm wondering if someone can help me get more out of the card, so here's my stock BIOS. I don't really know anything about increasing voltages or anything.
Why can't this GPU compete with the RX 5700 XT? It has 96 ROP's and 176 TMU's right?
Completely different architectures and generations.
Hi, i'm using Nvidia GTX 980Ti Ref, GPUZ Validaion, ASCI 75.2%, stable oc is 1479MHz @ 1230mV using AB. I'm trying to mod the stock bios but i run into some problem, after flash the mod bios the latest nvidia driver doesn't work anymore, windows still see it's as 980ti but there is no nvidia control panel. Could anyone take a look at my bios and give me some tips please?
File GM2001281V is the one i modded, i tried to add 1281V.
Edit: So i tried different nvidia driver version 385.41 and it works. So far so good. 1542 seems stable for me atm, max load power consumption is 357w. It's probably because it has 6+8 pins power input..idk. Anyway, does anyone know how to dial back the voltage a bit or is it safe to run 1274mV constantly everyday? The card idle is 95w.
Can't install that driver on my computer :(
Hey, how exactly did you install that old driver? I downloaded the driver, but when I try to install it it says it's not compatible with my Windows 10 (I have latest windows updates and stuff). I uninstalled with DDU and stuff before.
Hello everyone.
Firstly my gpu is a ''Zotac 980ti amp omega''
Wondering if anyone could help me?
Few months ago flashed my bios on my gpu to a much higher voltage and clocks etc everything works fine im just abit concerned about the constant 91/92c temps when playing games and what was around a 36c idle is now 45/50c which im assuming iv kinda cooked my thermal paste (Which im planning on changing in the next week while off work.)but for now i just wanted to go back to stock bios.
The problem is i made a backup of the stock bios via gpuz but some reason it will not flash back on its constantly telling me its wrong firmware yet all ID etc matches so it says..
Iv tried couple different versions of NVFlash and ether flat out refuses to work saying missmatch but then another version says its storing the firmware after the beep dose its thing then i restart come back to check and its still the extreme version.. iv tried to get screenshots but im just not fast for the missmatch error.
iv added some screenshots hopefully it will help and any help id be very grateful.
Does anybody have a stock bios for the pny variant of the 980 to. Very much appreciated. Thanks in advance
I tried to post a copy of my stock PNY Bios to Tech Power up but it doesn't show up. Have you had any luck with modded BIOS getting above 1456 core? The power limit is SOOOO low on these cards
Hope this tread is still active !! I recently bought an used 980TI EVGA HYDRO COPPER and I modded the bios by myself, reaching a 1500 on the core clock and 8120 on the memory, but I would like to know if I modded the bios correctly: it seems to me that my 980ti is not so good in OC or I made some mistakes modding the Bios (I spent a lot of time on it, making dozens of experiments) !!!
I'm on water so I don't have troubles about heat and temps !! Thanks for interesting !!
(This message contains my originl Bios and the one I make changes on)
Gtx 980ti increase power limit/voltage
Hello! I got a MSI gtx 980 ti armor 2X OC watercooled with the kraken g12.
With afterburner I get 1500 MHz stable with max temp at 52 degrees celcius.
I maxed out msi afterburner with +87mV and +10% power limit.
Now I want to increase voltage and power limit to further increase the clocks as I have a lot of thermal headroom.
Stock voltage at load is 1.23V reported in MSI afterburner
Question is, what's the easiest way? I work with soldering electronics in a microscope so hard modding is possible.
Another option is flashing the bios. Where do I find a bios for this, or what values do i modify in the bios?
Cyclops helped a lot ppl to mod their bios. Just ask nicely he will do it. I have 1.274V bios for ref card, pulling 400w in OCCT. Pretty insane. Make sure you have an extra fan blowing directly to he backplate, it's gonna be really hot.
https://www.overclock.net/forum/69-nvidia/1467851-nvidia-maxwell-kepler-bios-editing-thread-gtx-2xx-9xx-now-supported-385.html
