Note: I think .950v is the perfect balance between performance/efficiency for users with 330W power limits. For people who stuck with non-A chips 280W power limit undervolting to .900v helps.
Nice to find someone to share my experiencesNice guide mate! This sounds about right in my experience as well. I'm at 320W (by choice) and previously ran 1920 MHz at 925mV, 1935 at 931 and now 1950 at 950 (would be 1965 if card stayed below 45C). All of these stable for hours. Still testing.
As I have a non-A chip that stuck with a 280W power limits, I undervolt to 1890mhz/.900v. Average load during gaming is 250-270W. Maximum GPU temp without undervolting is 50C, with undervolting is 47C.@krizby at what undervolt value and clocks do you run your 2080TI at ?
Lol don't trust the wattage value that HWinfo give you dude, I see your bios is 400W at 100% and 450W at 112%, looking at AB graph your card sit at 100% power usage already. Just calculate wattage from the power % that AB give you.Tried the 450W HAF bios on reference-OC Palit, not working properly.
BIOS is stable and you can run games and such, but the card powerdraw maxes out at default 300w instead of 450w. Used Kombustor/PUBG as testing method, with it I can get the 380w bios to function as expected, 380w powerdraw.
Screenshot of HWINFO64 included as attachment.
checking on GPUz i don't like how it reports my GPU subvendor as NVIDIA instead of GALAX![]()
is that alright ?
Hello my friend..... Card work like a charm in my other windows setup. I think I may have buggered it up when I disabled it before flashing. I'll try again with my other setup to see if I can get in safe mode to see if I can make the required changes. I see it was flashed back to the stock bios so it is fine now. Don't really want to flash it again. I'll test it in this setup with the OS and see that all is still well.Ahem ? Nope to both...btw, my comment was a response to VPII's reported problem
Both my cards have Micron and both do 1040+ on VRAM w/o crashing though I still have to test for the most *efficient* setting rather than just outright *max* before lock-up etc.
Oops 417.35 driver install resulted in the same.... now I sit without the start-up options in advance menu for shift safe mode try to boot. Opening CMD as admin does not open, so maybe reinstall. WIndows 7 running fine with the card. I reflashed again and all good.Ahem ? Nope to both...btw, my comment was a response to VPII's reported problem
Hi, i've Samsung (instead Micron) memory on my ZOTAC 2080ti Triple fan, are you sure that i can put without problem the galax bios on it ?
Hi thereplayed a lot with my gpu, the core seems to be a dud. memory is insane though, I can hot 1400mhz no problem. so my gpu can do 2055 at 1.031v but it needs 1.081v for 2085 and 1.093v at 2100mhz...
I just ended up uundervolting it to 2055 at 1.031v This is for games btw.
Update Windows 10 reinstalled on original drive. Will test now with 417.58 driver to see if still an issue, if so I'll reinstall again.... just hope windows 10 don't give me activation issues. Worked fine now, I know that 416 drivers work without an issue. No G-sync monitor, but you never know.
Is a the samsung card better than the micron in terms of durability? I heard that the memory chips on early batches of 2080ti that broke is the micron one then samsung was used to replace the newer batches.
Wondering if there's a way I could tell the difference between the samsung and micron cards? Going to buy a founders from best buy and dunno if they use new or old batch of card.
417.58 Driver is a go.... no problems thus far all good. So thanks.... Windows 10 re activated and all good.... now just for a ton of downloads and with the speed here is SA.... a few days at least.Hi VPII - ..sounds like progress, and good to hear that your card is ok :thumbsups . Windows (both 7 and 10) have an entry for each GPU PER Bios, including a new ID flashed Bios on the same card...so a card with triple Bios will have three registry entries and if you run Tri-SLI, it's nine entries. Sometimes, it does not distinguish correctly between them anymore and you have a choice of either trying to hack the registry to death (searching for anything related to 'NVidia') or do a fresh WIN install. Subsequent activation issues can be a hassle, but probably the lesser of two evils... anyway, at least you know your card is ok and the Galax 380w is probably your best choice (w/ the extra cooling as it has been reported to run a bit toastier..). Also, you might want to uninstall MSI AB, including saved profiles !
