1 - 20 of 5149 Posts
Enthusiast
Discussion Starter · #1 · (Edited)
Last Updated: November 13, 2020
Note: This content is licensed under Creative Commons 3.0. This means that you are free to copy and redistribute this material, but only if the following criteria are met: 1) You must give appropriate credit by linking back to this thread. 2) You may not use this material for commercial purposes or place this on a for-profit website with ads. 3) You cannot create derivative work based on this material.
NVIDIA GeForce® RTX 3080
RTX 3070 Owner's Club
→ RTX 3080 Owner's Club
RTX 3090 Owner's Club
Click here to join the discussion on Discord or join directly through the Discord app with the code kkuFR3d
Source: NVIDIA
SPECS (Click Spoiler)
Rich (BB code):
   Architecture Ampere
   Chip GA102-200-A1
   Transistors 28,300 million
   Die Size 628 mm²
   Manufacturing Process Samsung 8nm
   CUDA Cores 4352 (8704)
   TMUs 272
   ROPs 96
   SM Count 68
   Tensor Cores 272
   GigaRays -- GR/s
   Core Clock 1440 MHz
   Boost Clock 1710 MHz
   Memory 10GB GDDR6X
   Memory Bus 320-bit
   Memory Clock 2376 MHz / 19000 MHz
   Memory Bandwidth 760 GB/s
   External Power Supply 12-Pin
   TDP 320W
   DirectX 12.2 Ultimate
   OpenGL 4.6
   OpenCL 2.0
   Vulkan 1.2
   CUDA 8.6
   Interface PCIe 4.0 x16
   Connectors 1x HDMI 2.1, 3x DisplayPort 1.4a
   Dimensions 285 x 112mm (2-Slot)
   Price $699 US
   Release Date September 17, 2020
Rich (BB code):
RTX 3090    | GA102-300 |  8nm | 628mm² | 28.3 BT | 5248 CCs* | 328 TMUs | 112 ROPs | 82 SMs | 1695 MHz |  24GB | 1024MB x 24 | GDDR6X | 384-bit | 936 GB/s | 350W
RTX 3080    | GA102-200 |  8nm | 628mm² | 28.3 BT | 4352 CCs* | 272 TMUs |  96 ROPs | 68 SMs | 1710 MHz |  10GB | 1024MB x 10 | GDDR6X | 320-bit | 760 GB/s | 320W
RTX 2080 Ti | TU102-300 | 12nm | 754mm² | 18.6 BT | 4352 CCs  | 272 TMUs |  88 ROPs | 68 SMs | 1635 MHz |  11GB | 1024MB x 11 | GDDR6  | 352-bit | 616 GB/s | 250W
RTX 2080 S  | TU104-450 | 12nm | 545mm² | 13.6 BT | 3072 CCs  | 192 TMUs |  64 ROPs | 48 SMs | 1815 MHz |   8GB | 1024MB x 8  | GDDR6  | 256-bit | 496 GB/s | 250W
RTX 2080    | TU104-400 | 12nm | 545mm² | 13.6 BT | 2944 CCs  | 184 TMUs |  64 ROPs | 46 SMs | 1710 MHz |   8GB | 1024MB x 8  | GDDR6  | 256-bit | 448 GB/s | 215W
GTX 1080 Ti | GP102-350 | 16nm | 471mm² | 12.0 BT | 3584 CCs  | 224 TMUs |  88 ROPs | 28 SMs | 1582 MHz |  11GB | 1024MB x 11 | GDDR5X | 352-bit | 484 GB/s | 250W
GTX 1080    | GP104-400 | 16nm | 314mm² |  7.2 BT | 2560 CCs  | 160 TMUs |  64 ROPs | 20 SMs | 1733 MHz |   8GB | 1024MB x 8  | GDDR5X | 256-bit | 320 GB/s | 180W
GTX 980 Ti  | GM200-310 | 28nm | 601mm² |  8.0 BT | 2816 CCs  | 172 TMUs |  96 ROPs | 22 SMs | 1076 MHz |   6GB |  512MB x 12 | GDDR5  | 384-bit | 336 GB/s | 250W
GTX 980     | GM204-400 | 28nm | 398mm² |  5.2 BT | 2048 CCs  | 128 TMUs |  64 ROPs | 16 SMs | 1216 MHz |   4GB |  512MB x 8  | GDDR5  | 256-bit | 224 GB/s | 165W
GTX 780 Ti  | GK110-425 | 28nm | 551mm² |  7.1 BT | 2880 CCs  | 240 TMUs |  48 ROPs | 15 SMs |  928 MHz |   3GB |  256MB x 12 | GDDR5  | 384-bit | 336 GB/s | 250W
GTX 780     | GK110-300 | 28nm | 551mm² |  7.1 BT | 2304 CCs  | 192 TMUs |  48 ROPs | 12 SMs |  900 MHz |   3GB |  256MB x 12 | GDDR5  | 384-bit | 288 GB/s | 250W
GTX 680     | GK104-400 | 28nm | 294mm² |  3.5 BT | 1536 CCs  | 128 TMUs |  32 ROPs |  8 SMs | 1058 MHz |   2GB |  256MB x 8  | GDDR5  | 256-bit | 192 GB/s | 200W
GTX 580     | GF110-375 | 40nm | 520mm² |  3.0 BT |  512 CCs  |  64 TMUs |  48 ROPs | 16 SMs |  772 MHz | 1.5GB |  128MB x 12 | GDDR5  | 384-bit | 192 GB/s | 250W
   * Can execute twice as many FP32 calculations per clock compared to previous generation when only executing FP32 operations,
   ⠀⠀thus marketed as 10496 and 8704 CUDA cores
The RTX 3080 and RTX 3090 share the same PCB design, with the exception of NVLink missing and no memory modules on the back of the RTX 3080. The NVIDIA Reference PCB (2x8-pin) has room for 9 power stages on the left and 11 power stages on the right, with 4 of them allocated for memory. This means that the 3080/3090 reference PCB has a maximum of 16 power stages for the GPU. But since the RTX 3080 is a cut down version of the RTX 3090 with lower power demands, there is no need to fill all of the positions with power stages, capacitors, and inductors. Instead, NVIDIA partners decide how many to use on reference PCB-based cards. NVIDIA's Founders Edition feature a custom PCB this time around, with 18 power stages total: 15 for the GPU and 3 for the memory. For comparison, we can see that (so far) no partner card using the NVIDIA Reference PCB (2x8-pin) goes below 13 power stages for the GPU and 3 power stages for the memory. Coincidentally, this is the exact VRM allocation of the 2080 Ti Reference PCB. Some cards.
ASUS
AsusTek Computer (stylised as ASUS) was founded in Taipei, Taiwan in 1989, currently headquartered in Taipei, Taiwan.
MSRP+$ Per WattModelLengthSlotFanHDMIBIOSPowerStagesPower LimitBoostPCBPWMEANPN
$3002.732EKWB216mm2Water112x8-Pin16320/366 W1710 MHzReference471801799143890YV0F60-M0NM00
TUF300mm2.63222x8-Pin20320/375 W1710 MHzCustomuP9512R471801790932790YV0FB0-M0NM00
$1602.293TUF OC300mm2.63222x8-Pin20340/375 W1785 MHzCustomuP9512R471801792276090YV0FB1-M0NM00
Strix319mm2.83223x8-Pin22320/450 W1710 MHzCustomMP2888A471801790915090YV0FA0-M0NM00
Strix LE319mm2.83223x8-Pin22320/450 W1710 MHzCustomMP2888A471108100280290YV0FA6-M0NM00
$2302.066Strix OC319mm2.83223x8-Pin22370/450 W1905 MHzCustomMP2888A471801792878690YV0FA1-M0NM00
$3502.333Strix OC LE319mm2.83223x8-Pin22370/450 W1905 MHzCustomMP2888A471108100292590YV0FA5-M0NM00
EVGA
EVGA Corporation was founded in California, United States in 1989, currently headquartered in California, United States.
$1002.352XC3 Black285mm2.23112x8-Pin16320/340 W1710 MHzCustomuP9511R425081243835510G-P5-3881-KR
$1202.240XC3285mm2.23112x8-Pin16340/366 W1710 MHzCustomuP9511R425081243831710G-P5-3883-KR
$1402.295XC3 Ultra285mm2.23112x8-Pin16340/366 W1755 MHzCustomuP9511R425081243830010G-P5-3885-KR
$1702.196XC3 Ultra263mm2Hybrid112x8-Pin16340/366 W1755 MHzCustomuP9511R425081243827010G-P5-3888-KR
$2002.244XC3 Ultra263mm1.5Water112x8-Pin16340/366 W1755 MHzCustomuP9511R425081243826310G-P5-3889-KR
$1601.911FTW3300mm2.753123x8-Pin22380/450 W1755 MHzCustomuP9511R425081243829410G-P5-3895-KR
$1801.955FTW3 Ultra300mm2.753123x8-Pin22380/450 W1800 MHzCustomuP9511R425081243828710G-P5-3897-KR
$2001.875FTW3 Ultra289mm2Hybrid123x8-Pin22380/450 W1800 MHzCustomuP9511R425081243825610G-P5-3898-KR
$2301.917FTW3 Ultra289mm1.5Water123x8-Pin22380/450 W1800 MHzCustomuP9511R425081243824910G-P5-3899-KR
GALAX | KFA2 - Not available in North America
GALAXY was founded in Hong Kong, China in 1994, GALAXY and its European brand KFA2 (Kick Friggin Ass) merged in 2014 to form GALAX as a single unified brand, the name KFA2 still exist for the European market but all designs are GALAX, currently headquartered in Hong Kong, China.
SG317mm33112x8-Pin16320/320 W1710 MHzReferenceuP9511R489514714106038NWM3MD99NN
SG317mm33112x8-Pin16320/320 W1710 MHzReferenceuP9511R489514714118338NWM3MD99NK
GIGABYTE
GIGA-BYTE Technology (stylised as GIGABYTE) was founded in Taipei, Taiwan in 1986, currently headquartered in Taipei, Taiwan and California, United States.
$6992.184Eagle3202.83212x8-Pin17320/320 W1710 MHzCustom4719331307851GV-N3080EAGLE-10GD
$7292.144Eagle OC3202.83212x8-Pin17340/340 W1755 MHzCustom4719331307554GV-N3080EAGLE OC-10GD
$7692.078Vision OC3202.753212x8-Pin17370/370 W1800 MHzCustom4719331307561GV-N3080VISION OC-10GD
$7492.024Gaming OC3202.753222x8-Pin17370/370 W1800 MHzCustom4719331307530GV-N3080GAMING OC-10GD
$8492.295AORUS Master3193.53322x8-Pin20370/370 W1845 MHzCustom4719331307639GV-N3080AORUS M-10GD
AORUS Waterforce2522Hybrid322x8-Pin20370/370 W1845 MHzCustomGV-N3080AORUSX W-10GD
AORUS Waterforce2522Water322x8-Pin20370/370 W1845 MHzCustomGV-N3080AORUSX WB-10GD
$8991.998AORUS Xtreme3193.53323x8-Pin370/450 W1905 MHzCustom4719331307783GV-N3080AORUS X-10GD
INNO3D - Not available in North America
InnoVISION Multimedia was founded in Hong Kong, China in 1989, primarily recognized for its graphic cards marketed under the Inno3D brand, acquired by PC Partner in 2008, currently headquartered in Hong Kong, China.
Twin X2 OC27432112x8-Pin16320/320 W1725 MHzReference0835168001589N30802-106XX-1810VA34
iChill X330033112x8-Pin16340/340 W1770 MHzReference0835168001572C30803-106XX-1810VA37
iChill X430033112x8-Pin16340/340 W1770 MHzReference0835168001565C30804-106XX-1810VA36
iChill Frostbite2262Water112x8-Pin16340/340 W1770 MHzReference0835168001640C30803-106XX-1810VA37
MSI
Micro-Star International (stylised MSI) was founded in Taipei, Taiwan in 1986, currently headquartered in Taipei, Taiwan.
$6992.184Ventus3052.853112x8-Pin16320/320 W1710 MHzCustom
$7392.309Ventus OC3052.853112x8-Pin16320/320 W1740 MHzCustom4719072762520V389-001R
Gaming Trio3232.83113x8-Pin16340/350 W1755 MHzCustom
$7592.169Gaming X Trio3232.83113x8-Pin16340/350 W1815 MHzCustom4719072762544V389-005R
Suprim3123x8-PinCustom
Suprim X3123x8-PinCustom
NVIDIA
Nvidia Corporation (stylised nVIDIA) was founded in California, United States in 1993, currently headquartered in California, United States.
$6991.889Founders Edition285mm22111x12-Pin18320/370 W1710 MHzCustom812674024509900-1G133-2530-000
PALIT | GAINWARD - Not available in North America
Palit Microsystems (stylised PaLiT) was founded in Taipei, Taiwan in 1988, acquired the Gainward brand and company in 2005, currently headquartered in Taipei, Taiwan.
Phoenix2942.73112x8-Pin17320/350 W1710 MHzReference4710562241952NED3080019IA-132AX
GamingPro2942.73112x8-Pin17320/350 W1710 MHzReference4710562241945NED3080019IA-132AA
Phoenix GS2942.73112x8-Pin17320/350 W1740 MHzReference4710562242010NED3080S19IA-132AX
GamingPro OC2942.73112x8-Pin17320/350 W1740 MHzReference4710562242003NED3080S19IA-132AA
Phantom3042.73123x8-Pin340/400 W1755 MHzCustom4710562242119NED3080U19IA-1020P
GameRock30433123x8-Pin340/400 W1740 MHzCustom4710562242102NED3080U19IA-1020G
Phantom GS3042.73123x8-Pin370/440 W1860 MHzCustom4710562242140NED3080H19IA-1020P
GameRock OC30433123x8-Pin370/440 W1845 MHzCustom4710562242133NED3080H19IA-1020G
PNY
PNY Technologies was founded in New York, United States in 1985, currently headquartered in New Jersey, United States.
$502.343XLR8 Uprising294mm2.73112x8-Pin17320/320 W1710 MHzReferenceNCP816100751492639550VCG308010TFXMPB
$502.142XLR8 Revel294mm2.73112x8-Pin17320/350 W1710 MHzReferenceNCP816100751492639567VCG308010TFXPPB
ZOTAC
ZOTAC is under the umbrella of PC Partner, and was founded in Hong Kong, China in 2006, currently headquartered in Hong Kong, China.
$202.142Trinity318mm2.93112x8-Pin16320/336 W1710 MHzCustomuP9511R4895173622403ZT-A30800D-10P
$302.172Trinity OC318mm2.93112x8-Pin16320/336 W1725 MHzCustomuP9511R4895173622496ZT-A30800J-10P
Trinity OC White318mm2.93112x8-Pin16320/336 W1740 MHzCustomuP9511R4895173622717ZT-A30800K-10P
AMP Holo318mm2.93112x8-Pin19340/374 W1770 MHzCustomuP9511R4895173622465ZT-A30800F-10P
TECHPOWERUP | GPU-Z
Download TechPowerUp GPU-Z
NVIDIA | NVFLASH
Download NVIDIA NVFlash
BIOS | ROM
TechPowerUp BIOS Collection < Verified
TechPowerUp BIOS Collection < Unverified
FLASH | GUIDE (Click Spoiler)
└ Step 01 of 27 - Download NVFlash ┘
└ Step 02 of 27 - Downloads Folder ┘
└ Step 03 of 27 - Open Zip File ┘
└ Step 04 of 27 - Copy Files ┘
└ Step 05 of 27 - Create New Folder ┘
└ Step 06 of 27 - Name Folder ┘
└ Step 07 of 27 - Paste Files ┘
└ Step 08 of 27 - Installation Successful ┘
└ Step 09 of 27 - Find BIOS ┘
└ Step 10 of 27 - Download BIOS ┘
└ Step 11 of 27 - Name BIOS ┘
└ Step 12 of 27 - Copy or Cut BIOS ┘
└ Step 13 of 27 - Paste BIOS ┘
└ Step 14 of 27 - Download Successful ┘
└ Step 15 of 27 - Before Flash ┘
└ Step 16 of 27 - Maximum Power Limit (330W) ┘
└ Step 17 of 27 - Starting Command Prompt (Administrator) ┘
chdir C:\nvflash
└ Step 18 of 27 - Changing Directory ┘
nvflash64 --protectoff
└ Step 19 of 27 - Disable Flash Protection ┘
nvflash64 --save Partner2080TiModel.rom
└ Step 20 of 27 - (Optional) BIOS Backup ┘
└ Step 21 of 27 - BIOS Saved ┘
nvflash64 -6 Partner2080TiModel.rom
Y
└ Step 22 of 27 - Flash BIOS ┘
Y
└ Step 23 of 27 - Confirm Update ┘
exit
└ Step 24 of 27 - Flash Completed ┘
└ Step 25 of 27 - After Flash ┘
└ Step 26 of 27 - Maximum Power Limit (380W) ┘
chdir C:\nvflash
nvflash64 --protecton
exit
└ Step 27 of 27 - (Optional) Enable Flash Protection ┘
OVERCLOCKING | TOOLS
Download ASUS GPUTweak II
Download EVGA Precision X1
Download Gainward EXPERTool
Download Galax/KFA2 Xtreme Tuner Plus
Download Gigabyte AORUS Engine
Download Inno3D TuneIT
Download MSI Afterburner
Download Palit ThunderMaster
Download PNY Velocity X
Download Zotac FireStorm
QUESTIONS | FAQ
Question: Price per Watt?
Answer: Lower is Better! (Missing cards will be added as soon as they have power limit and price confirmed)
Values have been adjusted on Hybrid and Water cooled cards because of the effect that cooling a die has on effective power draw. The electrical resistance of silicon goes down as temperature decreases, power draw under identical loads and clocks also decrease. This effectively raises the power limit by approximately 30 and 35 Watt for Hybrid and Water, respectively.
ModelPower limit (Watt) / Above 320Price in USD (MSRP) / Above FEPrice per Watt
EVGA FTW3 3x8-Pin450W / +130 (41%)$789 / +90 (13%)1.753
EVGA FTW3 Ultra 3x8-Pin450W / +130 (41%)$809 / +110 (16%)1.797
ASUS TUF375W / +55 (17%)$699 / +0 (0%)1.864
ASUS ROG Strix OC 3x8-Pin450W / +130 (41%)$849 / +150 (21%)1.886
NVIDIA Founders Edition370W / +50 (16%)$699 / +0 (0%)1.889
ASUS TUF OC375W / +55 (17%)$749 / +50 (7%)1.997
Gigabyte AORUS Xtreme 3x8-Pin450W / +130 (41%)$899 / +200 (29%)1.998
Gigabyte Gaming OC370W / +50 (16%)$749 / +50 (7%)2.024
EVGA XC3366W / +46 (14%)$749 / +50 (7%)2.046
Gigabyte Vision OC370W / +50 (16%)$769 / +70 (10%)2.078
EVGA XC3 Ultra366W / +46 (14%)$769 / +70 (10%)2.101
Zotac Trinity336W / +16 (5%)$719 / +20 (3%)2.139
PNY XLR8 Revel350W / +30 (9%)$749 / +50 (7%)2.140
Gigabyte Eagle OC340W / +20 (6%)$729 / +30 (4%)2.144
EVGA XC3 Black340W / +20 (6%)$729 / +30 (4%)2.144
MSI Gaming X Trio 3x8-Pin350W / +30 (9%)$759 / +60 (9%)2.169
Zotac Trinity OC336W / +16 (5%)$729 / +30 (4%)2.170
MSI Ventus320W / +0 (0%)$699 / +0 (0%)2.184
Gigabyte Eagle320W / +0 (0%)$699 / +0 (0%)2.184
Gigabyte AORUS Master370W / +50 (16%)$849 / +150 (21%)2.295
MSI Ventus OC320W / +0 (0%)$739 / +40 (6%)2.309
PNY XLR8 Uprising320W / +0 (0%)$749 / +50 (7%)2.340
Nvidia GeForce RTX 3080 Early Look: Ampere Architecture Performance - Hands-On!
2080 Ti here, this is enticing but there's a huge price gap between the 3080 and 3090 and NV essentially confirmed my suspicion that the 3090 is basically a renamed Titan, meaning, a 3080 Ti or 3080 S with 20GB of VRAM being dropped in response to Big Navi is very likely. Seeing as how I was late to upgrade from 1080 Ti to 2080 Ti (6 months ago, used, $900) I am probably going to wait for 3080 Ti / 3080 S.
Im all in my dudes.... 2080 to 3080 here I come. +80% performance = I'll take it
Booo
Ha, I'm coming from 980ti. +300% performance?
Booo
i would preorder the 3080 FE right now if i could. very annoyed nvidia is not taking preorders -_-.
though, i hate to ask this, but do you think a 3600x will bottleneck the 3080? nvidia is touting these cards as pci-express 4, but all their testing was on a intel 10900k which only uses pci-express 3. makes me feel like pci-express 4 is not needed, or at least, didn't help ryzen come out on top to be used over intel for their testing.
i feel like i should sell off my 3600x for a 10600k or something.
3080 ftw!
To The Game
I wouldn't until we see what kind of affect pcie 3.0/4.0 has.
Booo
I was hesitant to get a 3080 since it only has 10GB of VRAM, but I used my time machine to preorder one just in case (it sold out in 2 minutes!).
Time machine?
The size, price, and probably performance, are all better for 3080 than people expected I think, whereas the price of the 3090 is now outside most people's reach.
So until there is a 3080/20 on the market - and that might not be until GDDR6x prices come down - it comes down to whether 10GB is enough - esp.if youre on a 11GB 1080ti looking to upgrade.
Although adding more cores increases performance in any game, just adding more VRAM doesnt and few games allocate up to available size. Only a small %ge of people have 11 or more GB of VRAM and game developers know this - and this isnt going to change now Nvidia are sticking with 10GB - so I think 10GB is still a safe option going forward.
Newb to Overclock.net
I'm rather curious if the 320-bit SKU was a die harvest issue, or were they choosing to limit VRAM to cut expensive G6X costs. Imagine buying 2x1GB Micron G6X chips yourself, soldering them on, and either getting a working 352-bit or full 384-bit card. Self-made 3085/3080 TI. Hopes aside, still a curious question.
Jensen says that 3080 is the flagship, a flagship that have less ram than a 1080Ti?
Ok I like the price but there is a gap between 3080 and 3090 that will be fitted soon.
Imho we will see a 3080Ti soon after Christmas
Booo
Guess I'll be looking at the EVGA 3080 XC3 Ultra. That should be the reference PCB design based on previously released cards, and easiest to get waterblocks for, such as Heatkiller. EVGA just confirmed that Hydro Copper will come later, no ETA. So I'm going with third party waterblock.
To The Game
I'm leaning towards the FE card since I've never owned a reference card. How's people experience with them? This new design seems extremely interesting.
As far as the 3080 and vram goes, I've tested various games I play over the last few days and the most vram I've seen used was 6gb at 3440x1440. Feel like newer games might start flirting with 8gb+ though 10gb should last until the 40xx come out. Regardless, I plan on keeping my 1080 ti as a back up. I'll pull the 3080 about a month out from the 40xx release and flip it. Point being, I don't see the 3080 as being a longer term option for me and feel like it's more of a stopgap until next gen. I'm hoping by then AMD has shown its cards and hopefully brought competition back to the higher end.
Time machine?
Just making a pun at the fact that there is an owners club before the card is even available for preorder!
Although to be fair I will be 3080 owner soon. I'm upgrading from a 2070 super which is only getting me 20-30 fps in MSFS. One thing that bugs me though is that NVIDIA says the 3080 is twice as fast as the 2080, but they only added 2GB more VRAM. If it's twice as fast shouldn't it have 16GB of VRAM? Although I'm not gaming in 8k or even 4k, just a measly 3440X1440 so I'll probably be ok... I hope.
To The Game
Was able to push that New World game over 10gb vram. Maxed out over 10gb vram and over 16gb system ram usage but didn't screenshot it. Think there's some kind of memory leak. Though I went afk and when I came back it had cut down to 9.5gb vram and 12.5gb system ram usage.
Still kinda lost
So is my power supply useless now?
