Me i put +175 on gpu and + 1200 on memory, if i remember
Overclocking ur cpu can give higher score too i think.
I forgot to turn Shadowplay off. I got 14473 at +195 +1100 max fans in the beta bios with my case open
Ya its good too but not much difference, for this i dont know if i will try do something with mine, maybe i will just put waterblock and keep it like this.Don't remember, but about 14300-14500
Wow you have a beast of card dude ! Are you happy now ?
YesWow you have a beast of card dude ! Are you happy now ?
I clic auto notify for the hybrid cooler too, but i dont think i will buy it, coz from all i see with a hydrid cooler you wont clock much higher coz temp still a bit high, not like a real waterblock, me i have already a loop on my system, for someone who dont have then ya its better then nothing .YesI’m going to be putting the Hybrid Cooler on it when it becomes available. I knew there was something wrong, and turns out it was the shadow play recording in the background. Going to try the memory a little higher
Its more for noise than anything for me. This thing gets a little loud in my case for my liking.I clic auto notify for the hybrid cooler too, but i dont think i will buy it, coz from all i see with a hydrid cooler you wont clock much higher coz temp still a bit high, not like a real waterblock, me i have already a loop on my system, for someone who dont have then ya its better then nothing .
I really not sure i will buy the hibrid cooler, i keep thinking about it.
You beat my score in port royal, iam not so happy with this hehehehe![]()
Looks like a 2W shunt resistor instead of the standard 1W ones we're used to. They probably widened out the traces on the power planes so they needed a wider shunt.I'm newish to hardware modding, so forgive my ignorance but does anyone know what the hell these are, if they can be easily lowered in resistance, etc? Don't know how I would go about finding the spec sheet for one either. BZ just skips right over them and TiN never talks about them in guide.![]()
I'll LOL when the launch a KPE Classified in a few months along with the 3080Ti that has some true freak-ish binning which is a whole different class than "dud vs. not dud" binning.EVGA has said they are "Cherry picking dies". While thats not really binning since binning would be sorting them from best to worse to go into there product stack. They do say they test them at 2.1ghz in there chip tester before they are attached to the PCB. So all your really getting is more of a garantee your not going to get a super dud that wont go over 2ghz.
Hey dont stuck with fan at 100% dude, you can apply ur manual fan curve and this is what i do 1000rpm on 2D deskdrop and goes to 80% at 65c then 100% at 80c.Its more for noise than anything for me. This thing gets a little loud in my case for my liking.
over 22000 in Timespy for graphics
Well a kingpin is a Kingpin for sure, you cant go wrong.Guys, I think its abundantly clear that the 3090 Kingpin is the greatest card there is, was, or ever will be. This will become apparent once I take delivery of mine.
I have a similar experience with the KFA2 bios. the card seems to be more stable at higher clock and the fans run at their correct speed and keep the card cool-ish compared to the Gaming OC bios. Havent attempted to push my PR score with it though.Iv been playing with the KFA2 bios over the weekend on my XC3 and that IMO is the best 2 plug bios out at the moment.
350-390W, All DP ports should work for every one. Has a 18 phase design so power balance is better for the entry level cards.
Managed to get 4 more points then my best run on the gigabyte gaming oc bios, even tho average clock speed was down 25mhz
Oh I don’t that is only for benchingHey dont stuck with fan at 100% dude, you can apply ur manual fan curve and this is what i do 1000rpm on 2D deskdrop and goes to 80% at 65c then 100% at 80c.
I didnt ear the fan from my card coz i ear the fan from my front 280mm rad before and this rad have industrial Nocthua 140mm.
I did +220 on GPU, fans to 100%, no MEM overclock [MSI Ventus OC] and got 13210Is that at 100% fans? Which Bios? I’ll try that now.
This depend of the card you have and if the card already overclock from the reference boost clock speed.I did +220 on GPU, fans to 100%, no MEM overclock [MSI Ventus OC] and got 13210
Haven't ordered one yet. Waiting on Corsair or EKWB. Probably will get an EKWB.Where did you order your water block from ? My is shipped with a chinese dude on bike, probably arriving late 2022.
Default vbios, I did 115 gpu, 300 on mem, fans at 85% and got 13,456 in PR, 18,328 in TS.I did +220 on GPU, fans to 100%, no MEM overclock [MSI Ventus OC] and got 13210
