1 - 20 of 143 Posts
PC Gamer
The Only Rule:
You must post an image of your case to be added to the case club.
Please click the link below to be instantly brought to the Official
NZXT Classic Series Club
https://docs.google.com/spreadsheet/pub?key=0AnLxsr0XaC3pdHdZSGRuUGY2dWpGRzY3Y1dmbXg2YVE&output=html&widget=true
Introducing the NEW Phantom 820
Plastic/Steel Full Tower Chassis
The Phantom 820 is engineered to chill even the most demanding systems, equipped with triple 200mm and a 140mm fans. Maximize the potential by mounting up to nine fans to achieve unrivalled airflow in your chassis. Push the envelope and utilize liquid cooling systems that feature a push-pull configuration with top 280/360mm and bottom 240/280mm radiators up to 60mm thickness for unmatched performance. In addition, a rugged base design lifts the enclosure above the ground for display and increased airflow. The Phantom is reinvented again by following it's legacy of remarkable asymmetrical and award winning design.
MODELPhantom 820
CASE TYPEFull Tower
FRONT PANEL MATERIALPlastic/Steel
DIMENSIONS (W x H x D)235mm (W) x 650mm (H) x 612mm (D)
Special FeaturesIntegrated HUE LED lighting system, SD Card Reader, 4-channel 15-watt Fan Digital Controller
COOLING SYSTEM
[email protected] Front
[email protected] Top
[email protected] Side
[email protected] Rear
Fan Blades white fin/black frame
Fan Capacity Top: 2x 200mm/2x 140mm/3x 120mm
Front: 1x 200mm
Bottom: 2x 140mm/2x 120mm
Rear: 1x 140mm/1x 120mm
Side: 1x 200mm
Pivot: 1x 140mm/1x 120mm
Radiator Capacity Top: 2x 140mm/3x 120mm
DRIVE BAYS4 EXTERNAL 5.25" DRIVE BAYS
6 INTERNAL 3.5" DRIVE BAYS
Screwless Rail Design
MATERIAL(S)Steel, Plastic
EXPANSION SLOTS9
WEIGHT15kg, 32lbs
MOTHERBOARD SUPPORTE-ATX, XL-ATX, ATX, MICRO-ATX, Mini-ITX
Phantom 820 Case Review:
http://youtu.be/e35ZrZTvYuQ
nVIDIA 8800GTX Compatible
Steel Chassis
See-through smoked acrylic for 5.25" LCD Devices
Screwless Design
Standard dual 120mm silent fans
Intel HD© and AC 97 Audio Support for 7.1 and 5.1 audio systems
Support for 4 internal hard drives
Magnetic closing door
USB 2.0 and Firewire Support
Steel Midtower
Introducing the NZXT Apollo, the perfect combination of cooling, value and design. The Apollo features a steel chassis, two standard 120mm fans, and support for the latest technology like firewire, and Intel HD and AC 97 Audio Support for 7.1 and 5.1 sound systems. It features a smoked front acrylic used to display LCD displays hidden behind the front panel.
MODELAPOLLO
CASE TYPEMID TOWER FULL SIZE STEEL CHASSIS
DIMENSIONS (W x H x D)218 x 438 x 536 mm
COOLING SYSTEMFRONT, 1 X 120 mm (Optional)
REAR, 1 X 120 mm FAN
SIDE PANEL, 1 X 120 mm BLUE LED FAN
DRIVE BAYS10 DRIVE BAYS
5 EXTERNAL 5.25" DRIVE BAYS
1 EXTERNAL 3.5 " DRIVE BAYS
4 INTERNAL 3.5" DRIVE BAYS
SCREWLESS RAIL DESIGN
MATERIAL(S)SECC STEEL CHASSIS
EXPANSION SLOTS7
WEIGHT7.2 kg
MOTHERBOARD SUPPORTATX, MICRO-ATX, BABY AT
Apollo Case Review:
http://www.youtube.com/watch?v=zurZyJ2cjOI
NZXT Crafted Series Design: NZXT's latest addition to the
Crafted Series takes cues from gaming culture with elegant curves and a newly designed clear side panel
Spacious Interior and Solid Construction: Built from solid .88mm and 1.00mm steel, the Guardian 921 gives the user ample space for large, high-end video cards and space for up to four internal hard drives
Constant Temperature Monitoring: Three temperature probe monitoring system allows the user to constantly gauge thermals within the system at all times to prevent overheating
Multimedia and peripheral inputs: E-SATA, Intel HD audio, mic, and two USB inputs are standards with the Guardian 921 allowing for maximum peripheral input
Silent Cooling: Comes standard with 3 120mm fans installed to maximize cooling performance with minimal noise
Updated Design: The all new Guardian 921 RB features a bottom mounted PSU, CPU heatsink cutout, and an extra slot for a 140mm fan at the top for more cooling performance. The all new Guardian 921 RB comes in both red/blue LED combinations
B
lack Steel Midtower
NZXT celebrates the rebirth of the Guardian 921 with the renewed Guardian 921 RB. Expanded upon its predecessor, Guardian 921 RB reflects the gamer design, structural integrity, and temperature monitoring system of the original while displaying a wide range of new features to complete the system builder's dream budget case. New features include a bottom oriented power supply mount, CPU heatsink cutout, and an extra 140mm fan slot. Game beyond your limits with Guardian 921 RB.
MODELGUARDIAN 921 RB
CASE TYPEBLACK STEEL MID TOWER
DIMENSIONS (W x H x D)206X459X522 mm
COOLING SYSTEMFRONT, 1 X 120 mm LED FAN [Included]
REAR, 1 X 120 mm FAN [Included]
SIDE PANEL, 1 X 120 mm LED FAN [Included]
TOP, 1 x 120/140mm
DRIVE BAYS9 DRIVE BAYS
3 EXTERNAL 5.25" DRIVE BAYS
2 EXTERNAL 3.5 " DRIVE BAYS
EXPANSION SLOTS7
WEIGHT8.2 kg
CPU COOLER CLEARANCE144.4mm (with fan)
169.4mm (without fan)
Guardian 921 RB Review:
http://www.youtube.com/watch?v=GsfvXnJiRVc
Expansion galore: Nine 5.25" bay setup or Five 5.25" and Four 3.5"
Latest Hardware Support: VGA clearance room for 300mm cards like the ATI 5970
CPU Heatsink clearance: 131.5mm w/ 200mm fan, 165mm w/o side fan installed.
Dual 200mm intake Large air system: 200mm front fan, dual top 140mm fan, Side 200mm fan, rear 120mm exhaust. NZXT includes the chassis with all fans except for one top 140mm fan
Control the flow: Gaming, overclocking, or office work the dual 8W per channel fan control allows control over the dual 200mm fans that spin up to 150 CFM each
Monitor your system: A three C/F temperature display at front panel allows the user to see temperatures inside the chassis even with the door closed. A slant on the door allows for easier viewing from above.
Punched side panel: Besides aesthetics, the side mesh and extrusion allows for even greater and ease of wire management on the right side panel
Meshed front: 5.25" meshed bays, meshed door, and meshed bottom panel allows for air to flow into the system with ease.
Wire Routing: Motherboard punched holes allows for quick CPU bracket removable and optimal wire routing.
NZXT Solid State bracket allows for two SSD drives to be installed
Pre-drilled water cooling holes on the backplate
Front mounted 2 USB, Audio, and E-SATA ports
Mounting holes for dual radiator at the top
Removable filter at the bottom PSU
9 Bay Black Midtower
Introducing the Hades, a chassis that provides an array of advanced features for the most demanding PC enthusiast. Airflow is optimized with 5 fans (dual 200mm intake, 200 mm front fan, dual top 140mm fans, side 200mm fan, and rear 120mm exhaust). NZXT includes all the fans with the exception of the top 140mm and also provides a dual fan 8W per channel controller giving enthusiasts freedom to manage intake and exhaust airflow. A three temperature display on the front panel allows the user to see the temperature inside the chassis even when the door is closed. Additionally, the meshed 5.25" bays, door, and bottom panel allows for air to naturally flow into the system with ease.
Hades also boasts premium expandability with up to nine 5.25" bay setup or five 5.25" and four 3.5." It also features VGA clearance room for 300mm cards like the new ATI 5970. The punched side panel and motherboard tray with rubber grommets on the motherboard routing holes enables advanced wire management and quick CPU bracket removal. Additional advanced features include a solid state bracket allowing for two SSD drives, pre-drilled water cooling holes on the backplate, mounting holes for a dual radiator at the top, and a removable filter at the bottom PSU.
MODELHades Series
CASE TYPEMid Tower Steel
FRONT PANEL MATERIALPLASTIC
DIMENSIONS (W x H x D)200 X 430 X 501 mm / 7.87" x 16.9" x 19.7"
COOLING SYSTEM
FRONT, 1 X 200mm red LED (included)
REAR, 1 X 120mm (included)
SIDE, 1 x 200mm (included)
TOP, 2 X 120/140mm (1 include 140mm)
9 EXTERNAL 5.25" DRIVE BAYS
4 INTERNAL 3.5" DRIVE MOUNTS
MATERIAL(S)Steel with black finish
EXPANSION SLOTS7
WEIGHT6.95 kg
CPU COOLER CLEARANCE124.9mm (with fan)
154.9mm (without fan)
Hades Case Review:
http://www.youtube.com/watch?v=P8cRKXDmxQo
Immense Performance: 5 fan capability ( Front fan, Top 140mm fan, Side 120MM LED fan rear 120mm exhaust included ), fans rated at 43CFM, 23dB(A)
Fan control: Determine noise and airflow based on your needs, dual intakes and dual exhausts are controlled independently
Black on Black: Smoked clear window and a black interior gives the best combination of black on black.
Meshed front panel allows for more airflow
5.25" Stealth bay to keep a clean look
Turned HDD also helps with providing a cleaner look.
High end graphics card support, extra space is especially designed to fit longer 10.5" cards
Side mounted USB, Audio, and E-SATA ports
Black Steel Mid Tower Chassis
As with all of NZXT's cases, Lexa S is designed for enhanced airflow with capability for 5 fans including 120mm fans on the front, side, and exhaust with a 140 mm fan on top. NZXT includes the side, rear, top, and front fans along with a fan controller that controls dual intakes and exhausts independently and effectively optimizes your computers performance based on your preference for pure power or whisper quiet operation.
Lexa S offers gamers sleek aesthetics with a smoked clear window and all black interior along with a 5.25" stealth bay, turned HDD cage, and punched holes in the motherboard which makes for a cleaner look and gives enthusiasts a solution for superior cable management. Additional features include an ambient light over the 5.25" drives for extra visibility at LAN parties and a bracket for two Solid State Drives.
MODELLexa S SERIES
CASE TYPEMID TOWER Black interior chassis
FRONT PANEL MATERIALSteel
DIMENSIONS (W x H x D)196 X 480 X 528 mm
COOLING SYSTEM
FRONT, 1 x 120mm , 23db/42CFM (included)
SIDE, 1 x 120mm LED [email protected], 23db/42CFM (included)
TOP, 2 x 140/120mm (1 140mm included)
REAR, 1 x 120mm, 23db/42CFM (included)
DRIVE BAYS3 DRIVE BAYS
7 INTERNAL 3.5" DRIVE BAYS
MATERIAL(S)Steel Construction
EXPANSION SLOTS7
WEIGHT7 kg
CPU COOLER CLEARANCE141.0mm (with fan)
166.0mm (without fan)
Lexa S Case Review:
http://www.youtube.com/watch?v=ZX2DeBCjXko
High Performance Cooling Advantages - Phantom's extensive cooling capabilities include 7 fan cooling options with dual 200mm, single side 230/200mm (NZXT only guarantees fitment with NZXT's FN-200), triple 120mm, and front 140mm fans. For enhanced control and expandability, NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
Simple Installation - Phantom celebrates an array of innovative features designed to enhance every stage of the build. Meticulous wire management is easily attainable with large spacing behind the motherboard. The innovative all-new 5.25" screwless rails make installing and swapping HDDs an effortless process. Rubber grommets dampens vibration during operation.
Additional Advanced Features - Further distinct features include an LED on/off button to control fan lighting, rubber PSU and case feet to reduce vibration, easily removable front and top panels, and top mounted USB, Audio/Mic, and E-SATA ports.
Extensive Compatibility and Expandability - Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today's hottest components. Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25" bays.
Enthusiast Steel Full Tower
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs - we run the extra mile so you won't have to settle with the typical rectangular box.
The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25" screwless system, vast space to encompass 7 hard drives, and five 5.25" bays enable smooth customization. Establish your power, your presence.
MODELPhantom Series
CASE TYPEFull Tower Steel
DIMENSIONS (W x H x D)222 x 540 X 623 mm
VGA Clearance Maximum350mm
COOLING SYSTEM
FRONT, 1 X 140mm
SIDE, 2 x 120mm, 1 x 200/230 (2 x 120mm included)
TOP, 2 X 200mm (1 x LED 200mm included)
DRIVE BAYS5 EXTERNAL 5.25" DRIVE BAYS
7 INTERNAL 3.5"/2.5" Slots
EXPANSION SLOTS7
WEIGHT11 kg
MOTHERBOARD SUPPORTE-ATX, ATX, MICRO-ATX, BABY AT
Phantom Case Review:
http://www.youtube.com/watch?v=xnLnzIxk104
Clearance for top 240mm dual radiator for water cooling solutions
Adjustable interior pivot 120mm/140mm fan slot for directional air flow
Removable HDD cage to allow more room for extended video cards
Innovative right mounted HDD rails for easy hard drive replacement
Single 120mm/140mm side fan with acrylic window for interior viewing and cooling
Front Internal 2x USB 3.0 headers, 2x USB 2.0, audio and microphone input
30W 3-step fan control for setting up your system for silence or performance
Wire management support up to 25mm space for easy cable management
Screw-less 5.25" and HDD trays that secures 2.5" SSD
Cooling capability of up to eight fans (2x 120mm and 1x 140mm LED fan included)
Design Mid-Tower Chassis
NZXT introduces the descendant of the revolutionary Phantom, the Phantom 410. The beautiful and sleek Phantom design set the trend of all white chassis and idealized optimal expansion and cooling. In comparison to its predecessor, the Phantom 410 delivers more value for every dollar spent and possesses an acrylic window that allows gamers to admire the power of their rig.
The Phantom 410 features an innovative right mounted HDD rails, a solution for easy hard drive replacement. This mid tower comes equipped with a dual radiator water cooling solution with a clearance of 30mm, an interior pivot 120mm/140mm fan slot, the capability of installing up to 8 fans, and a single 30W fan control. The Phantom comes with up-to-date internal 2x USB 3.0 headers that directly connect to the motherboard. Be the envy of all PC gamers - the Phantom 410 is bringing sexy back.
MODELPhantom 410
DIMENSIONS (W x H x D)215 x 516 X 532 mm
VGA Clearance Maximum305mm (w/o fan), 280mm (installed), 230mm (full pivot)
COOLING SYSTEM
FRONT, 2x120mm or 1 X 140mm (1x120mm included)
SIDE, 1 x 120mm or 1 x 140mm
TOP, 2 X 120/140mm (1 x 140mm included)
DRIVE BAYS3 EXTERNAL 5.25" DRIVE BAYS
6 INTERNAL 3.5" Slots
MATERIAL(S)Steel
EXPANSION SLOTS7
WEIGHT9 kg
MOTHERBOARD SUPPORTATX, MICRO-ATX, MINI-ITX
Phantom 410 Case Review:
http://youtu.be/VeVnlKRQYrk
Unique hybrid full tower chassis optimized for extreme liquid cooling, airflow, or silence
Supports high-end water cooling solutions up to three fans for push and pull configuration: 90mm of internal top space with top 360/420mm and bottom 140/240mm radiator support for unmatched liquid cooling
Four watercooling cutouts for easy liquid cooling management on the rear panel
Spacious CPU cutout for mounting high-end CPU coolers without removing the motherboard
Removable top 5.25" plates to accommodate wide radiators
Clever hybrid fin design allows the user to choose between maximum airflow or sound reduction
Innovative right-mounted HDDs for easy hard drive replacement
Removable HDD pull-out cages and large storage capacity for 7 hard drives
Equipped with two 140mm pivot fan slots for directing airflow at 15⁰ to the VGA and CPU
Rear white light for visibility in dark environments with a toggle switch
Dual high-speed USB 3.0, hard drive dock along with a SD card reader for transfer and quick access to multimedia
5.25" hard drive hot swap with SATA III support
Nine expansion slots for installing EATX motherboards with Quad SLI or Triple Crossfire
Supreme cooling capacity with up to ten 140/120mm fans
Stress-free wire management and 23mm clearance in the rear allows for superb wire-tucks
Ten large specialized cutout holes for easy cable management
Easily removable bottom filters in the front and rear to prevent dust from entering
Tool-less 5.25" and 3.5"/2.5" SSD hard drive installation for convenience and ease of accessibility
Large acrylic window with a view to show off the interior of your rig
Hybrid Full Tower Chassis
Experience the pinnacle of chassis design! Switch 810 is an epic hybrid case built for the hardcore PC enthusiast. This full tower chassis introduces a first of its kind concept for more versatility and adaptability to any configuration. It can be modified for superior water cooling or superb airflow through seamless operation. The Switch 810 is the ultimate powerhouse suitable for any type of PC enthusiast - whether you are liquid cooling, silent performance, or extreme airflow. You will have full control to customize all the features of Switch 810 based upon your preference.
Some unique features that set Switch 810 apart is the adjustable Hybrid Fins that reduce sound up to 40-60% when closed or open passageways for maximum airflow. Keep dust out by simply shifting the Hybrid Fins closed. Switch 810 has a rear LED light for illuminating the I/O in the dark, removable HDD cages for bottom radiator installation, a stealth bay, ability to mount triple 120/140mm radiators with 90mm of space, and potential to install up to 7 HDDs. For the first time, NZXT is introducing advanced HDD cages equipped with two 140mm pivot fans for directing airflow to the VGA and CPU. Anything is achievable with this chassis. You can only explore the infinite possibilities of PC expansion with the Switch 810.
MODELSwitch 810
CASE TYPEHybrid Full Tower
DIMENSIONS (W x H x D)235 x 595 X 585 mm
VGA Clearance Maximum375mm (w/out fan), 350 (installed), 285 (full pivot)
COOLING SYSTEM
FRONT, 2 X 120/140mm (1x 140mm included)
REAR, 1 X 120/140mm (1x 140mm included)
TOP, 3 X 120/140mm (1x 140mm included)
BOTTOM, 2x 120/140mm
INTERIOR, 2x 120/140mm (1x 140mm included)
SIDE, Large acrylic window
EXPANSION SLOTS9
WEIGHT9.1 kg
Switch 810 Case Review:
http://youtu.be/ZMsruac6tG0
Dual Radiator Ready: The NZXT Tempest is pre-drilled for mounting a dual 120mm radiator at the top of the chassis, currently compatible and tested with Swiftech MCR220, Asetek Dual radiator solution, and Thermaltake TMG2.
Airflow King: Dual 120mm intake, Dual 140mm Exhaust with an additional side 120mm fan and rear 120mm fan all included.
Maximize Expandability: E-ATX support allows more compatibility with high end components including large graphics cards
Easier accessibility & cable management: Cable routing is pre-drilled on the motherboard so users can hide cables behind the motherboard tray, allowing more a cleaning look and better airflow. Power, E-SATA, USB and Reset buttons are mounted at the top to give better accessibility.
Bottom mounted PSU: PSU mounting at the bottom allows for more security and separation of heat from the CPU
Server-like HDD space: Dual 120mm fans cool cages that hold up to 8 HDDs allowing for large capacity systems while maintaining cool temperatures
Enthusiast Steel Mid-Tower
Introducing the Airflow King.
NZXT, a company built on realizing the dreams of gamers worldwide, is proud to announce the NZXT Tempest. Tempest features breakthrough features in every category satisfying the high performance demands of PC Enthusiasts and Gamers worldwide. Tempest stakes its claim as Airflow King with 6 fans including dual intake(120mm), dual exhaust(140mm) with additional side and rear fans(120mm) all included. Tempest maximizes expandability with E-ATX support allowing for more compatibility with high end components including larger graphics cards. Cable routing is pre-drilled so users can hide cables behind the motherboard tray, allowing for a cleaner appearance and improved airflow. Tempest also features server-like HDD space by using dual 120mm fans to cool cages holding up to 8 HDDs allowing for large capacity systems while maintaining cool temperatures.
MODELTempest SERIES
CASE TYPEMID TOWER Steel
DIMENSIONS (W x H x D)211.5 X 521.5 X 562 mm
COOLING SYSTEMFRONT, 2 X 120 mm Blue LED (included)
REAR, 1 X 120 mm (included)
SIDE PANEL, 1 X 120mm Blue LED (included)
TOP, 2 X 140mm Fan (included)
3 EXTERNAL 5.25" DRIVE BAYS ( up to six 5.25" )
1 3.5" External bracket
8 INTERNAL 3.5" DRIVE BAYS
EXPANSION SLOTS7
WEIGHT11.2 kg
MOTHERBOARD SUPPORTE-ATX ATX, MICRO-ATX, BABY AT
Tempest Case Review:
http://youtu.be/Bk2dTkTYeQ4
Massive mesh styling for improved cooling and optimal airflow
Includes one 120mm and one 140mm fan with a cooling potential of up to 8 fans with the ability to change positions on the side fan
Screw-less 5.5" and 3.5" bays for easy installation and expansion
USB 3.0 for up-to-date high speed data transfer
Easy cable management for routing cables to enable better airflow inside your system
Enthusiast Mid Tower Chassis
Let's face it - gamers' rooms get extremely hot. Between your monitor and intense 1v1 matches, your entire environment is trapped with heat. This becomes problematic because not only are you affected but your PC as well. All that raw power needs to be contained and cooled. The Tempest 210 is the ender to your heat issues with its mesh design. The massive mesh design maintains a constant stream of fresh air inside your case while keeping the hot air out. As a bonus, this case has the capacity to mount up to 8 fans with the ability to change positions on the side fan. Get rid of your heating issues by investing in the Tempest 210 as the master of chilling.
MODELTempest 210
CASE TYPEMid Tower
FRONT PANEL MATERIALSteel/Plastic
DIMENSIONS (W x H x D)195mm x 450mm x 497mm
VGA Clearance Maximum230mm w/ hard drive, 330mm w/o hard drive
CPU Heatsink Support160mm
Wiring Space20mm
COOLING SYSTEM
FRONT, 2 X 120mm
REAR, 1 X 120mm @ 1200rpm (included)
TOP, 2 X 120/140mm (1x 140mm included)
BOTTOM, 1 x 120mm
DRIVE BAYS3 Tool-less EXTERNAL 5.25" DRIVE BAYS
8 Tool-less INTERNAL 3.5" HDD Drives
MATERIAL(S)Steel with painted interior
EXPANSION SLOTS7
WEIGHT6.6kg
External Connections1 x Standard Audio/Mic, 1 x USB 3.0,1 x USB 2.0
Tempest 210 Case Review:
http://youtu.be/K_DypG-2H_E
Large honeycomb steel mesh design for optimal airflow
Dual radiator support for all-in-one liquid cooling solutions
Latest Audio, USB 2.0, and USB 3.0 internal support
Top storage compartment and cable routing for convenience
Innovative dual 120mm side fan slot or adjustable single fan slot to target hot spots in the case
Dual touch powered 120mm front fans equipped with easily removable filters for easy maintenance
Mid Tower Chassis Airflow Case
An aggressive cooling solution forged for your rig, the Tempest 410 Midtower completes your fine-tuned machine by taking advantage of the airflow required for the enthusiast's overclocking needs. The Tempest legacy expands its maximized ventilation through the extra-large honeycomb mesh design, dual radiator support, and dual touch powered front fans. If you are looking for a new cooling edge for your gameplay, Tempest 410 will bring you the results of epic win.
MODELTempest 410
DIMENSIONS (W x H x D)215 x 481 X 496mm
VGA Clearance Maximum315mm w/o HDD, 290mm w/ bracket, 250mm w/ HDD installed
CPU Heatsink Support170mm
COOLING SYSTEM
FRONT, 2 X 120mm @ 1200rpm (1x included)
SIDE, 2 X 120mm
REAR, 1 X 120mm @ 1200rpm (1x included)
TOP, 2 X 120/140mm
BOTTOM, 1 x 120mm
8 INTERNAL 3.5"/2.5" Slots
EXPANSION SLOTS7
WEIGHT7.8KG
MOTHERBOARD SUPPORTATX, MICRO-ATX, MINI ATX, FLEX ATX, MINI ITX
Tempest 410 Case Review:
http://youtu.be/0e7YEiQPJoY
Large clear side windows allows for viewing of CPU and components
An aggressive cooling solution forged for your rig, the Tempest 410 Elite Midtower completes your fine-tuned machine by taking advantage of the airflow required for the enthusiast's overclocking needs. The Tempest legacy expands its maximized ventilation through the extra-large honeycomb mesh design, dual radiator support, and dual touch powered front fans. In addition to the basics, the Elite includes USB 3.0 and an acrylic side panel for interior viewing. If you are looking for a new cooling edge for your gameplay, Tempest 410 will bring you the results of epic win.
MODELTempest 410 Elite
COOLING SYSTEM
FRONT, 2 X 120mm @ 1200rpm (2x included)
TOP, 2 X 120/140mm
BOTTOM, 1 x 120mm
EXPANSION SLOTS7
WEIGHT7.8KG
Tempest 410 Elite Case Review:
http://youtu.be/KxvHdTAJi44
The King reborn: Dual 120mm intake, Dual 140mm Exhaust with an additional side 120mm fan and rear 120mm fan makes NZXT Tempest one of top cases in cooling, maximizing air circulation in all areas. The new Tempest EVO has upgraded nine blade design fans that deliver more air at low noise levels
Maximize Expandability: E-ATX support allows more compatibility with high end components including large graphics cards, high end power supplies. and server boards
Enhanced accessibility & cable management: Cable routing is pre-drilled on the motherboard so users can hide cables behind the motherboard tray, allowing more a cleaning look and better airflow. Power, E-SATA, USB and Reset buttons are mounted at the top to give better accessibility. The Tempest EVO has increased space behind the motherboard panel from a punched side panel design and a CPU punchout for heatsink removal
Overclocking and water cooling friendly: The Tempest is predrilled for watercooling tube access and supports a dual 120mm radiator at the top panel.
Black on Black: All new black interior, smoked side panel gives the Tempest an all new sleek look.
Black Enthusiast Steel Tower
Announcing the Tempest EVO, a sleek, all black, steel mid tower gaming chassis. Building off of the original Tempest's award winning design, the EVO brings advanced cooling power, expandability, and cable management. The Tempest EVO maximizes airflow circulation with Dual 120mm intake, dual 140mm top exhaust, side 120mm, and a rear 120mm fan. NZXT even redesigned the fan blade design so they effectively deliver more air at lower noise levels. Additionally, the bottom mounted PSU provides better airflow and separation of heat from the CPU.
The Tempest EVO puts a premium on expandability with E-ATX support allowing for compatibility with higher end graphics cards, power supplies and server boards while the server-like HDD space holds up to 8 HDDs ensuring that enthusiasts can make significant upgrades to their system without having to replace the chassis. Installation and upgrades are a breeze with pre-drilled cable routing on the motherboard allowing for a cleaner look and improved airflow. The case also features added space behind the motherboard panel from a punched side panel design that allows for easy heatsink removal. Tempest EVO is well equipped for overclocking and watercooling enthusiasts with predrilled watercooling tube access and support for a dual 120mm radiator at the top panel.
MODELTempest SERIES
EXPANSION SLOTS7
WEIGHT11.2 kg
CPU COOLER CLEARANCE134.5mm (with fan)
159.5mm (without fan)
Tempest Evo Case Review:
http://youtu.be/4zrqZFgU4a0
Durable Non-slip finished top handle for portability
Black Interior
Dual 5.25" slots and four 3.5" slots (internal and external)
Wire routing holes + extruded side panel provides extra space for cable management
Dual 8W channel fan control
Fits at least 350mm video cards like the ATI 5970
ATX PSU with removable filter + anti-vibration rubber support
Dual external watercooling cutouts
Dual top 120mm exhaust for optimal cooling
Top mounted (2x)USB, E SATA, External HD Audio + Mic
Fan LED on/off function: Turn off lights during night time use
CPU heatsink cut-out + 170mm heatsink support
Supports 200mm fan intake on side mesh (NZXT only guarantees fitment with NZXT's FN-200)
Extra large mesh holes for optimal airflow
Removable Hard drive cage
Included thumbscrews for all drives
Gaming mATX chassis
Small footprint, Big power
Introducing NZXT's new VULCAN Micro ATX gaming case, the ideal bring-your-own-computer option for professional gaming LAN parties. The Vulcan maximizes power in a compact 16" x 7" x 16.6" body, which is approximately 40% smaller than the typical super full tower. Indulge in the ample space that includes advanced cooling capabilities with 2 x 120mm (one included), 1 x 200mm, 1 x 80mm, a front 120mm intake fan (included), and more space to fit up to two 350mm cards in SLI and Crossfire configurations. The durable non-slip top handle and anti-vibration rubber support idealizes portability, enabling you to easily transport your ultimate gaming machine anywhere.
MODEL Vulcan Series
CASE TYPE Gaming mATX Chassis
LED Color Orange
Front panel connectors 1 x HD Audio/Mic, 2 x USB 2.0, 1 x eSATA
FRONT PANEL MATERIAL Plastic / Steel Mesh
DIMENSIONS (W x H x D) 180mm (W) x 422.5mm (H) x 406mm (D) / 7" x 16.6" x 16"
Dimensions w/o Handle 180mm (W) x 380mm (H) x 406mm (D) / 7" x 14.9" x 16"
VGA Clearance Maximum 350mm
CPU heatsink height support 165mm (without 35mm thick side 200mm fan)
COOLING SYSTEM
FRONT, 1 X 120mm (included)
REAR, 1 X 92/80mm
TOP, 2 x 120mm (1 x Orange LED fan included)
SIDE, 1 x 200mm
DRIVE BAYS 6 DRIVE BAYS
2 EXTERNAL 5.25" DRIVE BAYS
2 EXTERNAL 3.5" DRIVE BAYS
2 INTERNAL 3.5" DRIVE BAYS
MATERIAL(S) Steel with powder black coating inside
EXPANSION SLOTS 4
WEIGHT 5.80 kg / 12.8 lbs
MOTHERBOARD SUPPORT MICRO-ATX, ITX
Vulcon Case Review:
http://youtu.be/V_zt_pqmz3o
Full tower steel chassis
quad 120mm fans dedicated for CPU and GPU cooling
Dual 120mm exhaust
Screwless installation for 5.25" and 3.5" devices
Intel HD audio compatibility
Top mounted USB, Audio, and E-SATA Ports
Sturdy 1.0mm steel chassis
Introducing the Zero 2, the follow-up to the successful ZERO, featuring the same extreme cooling capabilities, the ZERO 2 is the perfect home to enthusiast and gaming users. Featuring a sturdy 1.0mm steel chassis, the Zero's structural integrity cannot be doubted. Weighing at 10.2KG the zero 2 is a beast of its own. Zero 2's quad side fans are perfect for users running multi GPU systems.
MODELZero 2 SERIES
CASE TYPEFULL TOWER Steel
DIMENSIONS (W x H x D)210.5 X 532 X 536 mm
COOLING SYSTEM
FRONT, 1 X 120mm Blue LED (included)
REAR, 2 X 120mm (included)
TOP/BOTTOM, 1 X 80mm, 2 x 80mm fans (optional)
SIDE, 4 x 120mm (optional)
DRIVE BAYS13 DRIVE BAYS
EXPANSION SLOTS7
WEIGHT10.2 kg
Zero 2 Case Review:
http://youtu.be/xYjIbV84qMw
I do believe my Tempest Evo Is a crafted series case
PC Gamer
Ok guys the page is done for now. Lots of information on each Crafted Series Case along with video's. Thanks & looking forward to adding you.
the PSU cover is actually just a peice of folded cardboard with an nzxt logo slapped on it
im looking into making a more permanent solution for that however : http://www.overclock.net/t/1203021/cover-for-psu-wires/0_30
yours looks pretty nice as well.
@OP i added the sig text to my sig. hopefully we can get some more people in here
Hey guys, I'm dropping by to inform you that the Classic Series Club has posted a link on their OP to inform others that there is now an official Crafted Series Club! Here's how the link looks:
NZXT Crafted Series Club
If you're not too crazy about it, I can change it to whatever you like, just let me know.
By the way OP, you might want to add what one needs to do in order to apply for the club to avoid possible confusion.
PC Gamer
Yes I am not done with it yet. I am working on that as you posted this :)
I'll add some liquid cooling info about the Tempest 210. I was going to use this in my Budget BOINCer rig, along with dual 240mm radiators. While the top of the case supports both 140mm and 120mm fans, the 120mm fans are centered in the 140mm openings. This does not allow a 240mm radiator to be mounted, unless you use just 4 screws on top, rather than 8. A 2x140mm radiator may fit the fan mounts, however the motherboard may not fit due to its placement. A workaround would be 2, 120mm radiators mounted in the 120mm fan locations.
For the front of the case, the fan spacing seems correct for a vertical 2x120mm radiator, however the 5 1/4" bays will need a small rectangle cut out for the top of the radiator as the overall height between base on the bays is roughly 5mm short. The XSPC RS240 radiator will also not slide between the 3 1/2" bays and the front of the chassis, but a BlackIce Stealth 240 may. The fans will then need mounted between the front bezel and the chassis. To do so, 25mm fans will not work without modification. The chassis grills on the front are raised, so they would need cut as well as the dust filter removed. Slim fans should work, though you will want to create a "shroud" using foam to fill the gaps if the grill is not cut out.
4LC4PON3, the Sig line you have provided in the OP links to the OP EDIT POST page, might want to fix that
PC Gamer
Sorry guys the Sig line has been fixed. must of been tired or something.
Hey guys, QQ!
Will the back panel of the tempest evo (the panel with the bulge in it) fir onto the Lexa S? Though I have successfully hidden all my cables behind the mobo tray, it's a tight fit, and was wondering if this panel would fit, because it would give some room for the cables to breathe, and it wouldn't take so much effort to put the back panel on. Thanks!
PC Gamer
Discussion Starter · #13 ·
You have been added. We need MORE lol
PC Gamer
Discussion Starter · #16 ·
wow thats alot of power for a 460 lol. man this thread died before it started. I did not realize how many people do not own any crafted models
Hey guys first post so big noob here. I joined up when I heard from the RFD forums about the Shimian/Catleaps - didn't even know case owner clubs existed
Hope I'm not too late to the Crafted Series party.
Proud owner of a Lexa S (built in late 2010 but I still love her
400
Lexa S in her habitat:
400
Can I be added to the club with a video?
Video of full-specs:
Looks absolutely brilliant! I am thinking about switching out my Lexa S front panel for one I modded to be flat black. Hmmm.
Got a few upgrades, so I snagged a few pics. Corsair Nova 60GB SSD boot drive, Asus wireless card and Asus Xonar 5.1 sound card.
450
450
450
1 - 20 of 143 Posts
