[NEW POLL] What Color do you have/will you get?
  • White
    Votes: 66 13.2%
  • Red
    Votes: 134 26.9%
  • Black
    Votes: 34 6.8%
  • SE White/Blue
    Votes: 22 4.4%
  • SE Black/White
    Votes: 65 13.0%
  • SE Black/Orange
    Votes: 151 30.3%
  • SE Gunmetal
    Votes: 27 5.4%
  • Modded
    Votes: 0 0.0%
1 - 20 of 5803 Posts
Below is a list of what will fit in your Phantom 410
Unmodded:
240mm radiator (30mm thick) in push or pull in the top, X-flow radiators may block the rear exhaust fan.
120mm radiator in push/pull (up to 80mm thick), rear exhaust, bottom intake, top front intake, push in either top slot. Bottom intake may interfere with a long PSU or its wires.
Modded:
Removing the bottom HDD Cage (four rivets) opens up the front of the case to a 240mm (possibly an 80mm in push/pull) rad, with the ports at the bottom (may be a tight fit) or with the ports up top, requiring a cut into the bottom 5.25" bays. The bottom front fan mount can be cut off to allow for a 240mm radiator in the bottom instead.
The top of the case can be cut to fit a 280mm radiator (with some cutting, 30mm rad in push or pull) or even a 360mm radiator in push or pull. The 360 would likely run into the fan controller/front IO
Information provided by phillyd
Push or Pull only:
You must mount the radiator on one side of the plate and the fans on the other.
Push/Pull:
If you use normal 120 or 140 mm fans inside the case, the rad on top of the case, and fans that are <16mm thick, you can do push pull with no modding and have plenty of room to spare in the phantom 410
1.Remove the top panel of the case and take off the top portion of the case (25 phillips screws estimate). This will allow you to freely sandwich the rad / top panel / fans together without running into the motherboard.
2.After removing the top, the fan controller + pwr/reset button wires wont allow you to completely take off the top, so I placed the case on it's side and let the top rest perpendicular to the case.
3.Place the radiator on the inside of the top peice with the fill port facing down in the center of the case. And the 90 degree swivel elbows facing the inside rear of the case. (Went this direction because my mobo would have gotten in the way of the fill port. Some people might get away the other way depending on their mobo) (TIP: I placed the waterblock in the 5.25" bay with the tubes going through the top fan hole so you dont have the block dangling while installing the rad)
4.Mount the fans on the top as pull (Swiftech logo facing up)
5. Place the top back into the frame of the case and screw in (make sure all your fan control + pwr button cables go into their proper notch)
6.Mount the backplate for the waterblock to mobo
7.Mount the waterblock (TIP: Because the length of the tube was too damn long I gave them a good bend before mounting the block)
8.Enjoy
*Thanks to Byomes for the install info & photos (link below)
http://www.overclock.net/t/1204530/official-phantom-410-mid-tower-owners-club/4500
ATX, MICRO-ATX, MINI-ITX & yes even E-ATX
Warning about E-ATX motherboards
The Phantom 410 was not designed for E-ATX boards but they will fit. E-ATX motherboards are wider so the motherboard may cover your grommets which may add to cable management issues.
We would also like to address some concerns this change may bring regarding our previously released products:
1. Phantom 820 already features the required fan spacing specifications for the NZXT Kraken X60.
2. Switch 810 has already begun production with revised top steel panels which allows for both 15mm and 20mm spacing.
3. Phantom 410 and Tempest 410 will happily accept the Kraken X40; however they will not be able to natively support the Kraken X60 due to their inherent hole spacing.
At the moment, NZXT's Switch 810 will be the only case receiving revised top steel panels for native Kraken X60 support. If you already own a Switch 810 and wish to purchase an NZXT Kraken X60, you may contact NZXT Support for a free replacement. The revised steel panels utilize screws for its installation, allowing users to easily replace the top steel panel with a standard Phillips head screwdriver.
Below is a how to guide on installing the Kraken X60 into the phantom 410 with some minor modifications, Please refer to this and do not clog the thread with questions re-installing this unit. Thanks to Kdman for the efforts!
(about half way down the page)
http://www.overclock.net/t/1204530/official-phantom-410-mid-tower-owners-club/4290
Applying For The NZXT Owners Club
When applying for the club you can either post directly into the thread or PM me. Please make sure you include images into both types of applications as this will help me sort who needs to go where. If there is any concerns or questions please feel free to PM me!
NZXT Reps, Facebook and Video's below
Design Mid-Tower Chassis
NZXT introduces the descendant of the revolutionary Phantom, the Phantom 410. The beautiful and sleek Phantom design set the trend of all white chassis and idealized optimal expansion and cooling. In comparison to its predecessor, the Phantom 410 delivers more value for every dollar spent and possesses an acrylic window that allows gamers to admire the power of their rig.
The Phantom 410 features an innovative right mounted HDD rails, a solution for easy hard drive replacement. This mid tower comes equipped with a dual radiator water cooling solution with a clearance of 30mm, an interior pivot 120mm/140mm fan slot, the capability of installing up to 8 fans, and a single 30W fan control. The Phantom comes with up-to-date internal 2x USB 3.0 headers that directly connect to the motherboard. Be the envy of all PC gamers - the Phantom 410 is bringing sexy back.
Clearance for top 240mm dual radiator for water cooling solutions
Adjustable interior pivot 120mm/140mm fan slot for directional air flow
Removable HDD cage to allow more room for extended video cards
Innovative right mounted HDD rails for easy hard drive replacement
Single 120mm/140mm side fan with acrylic window for interior viewing and cooling
Front Internal 2x USB 3.0 headers, 2x USB 2.0, audio and microphone input
30W 3-step fan control for setting up your system for silence or performance
Wire management support up to 25mm space for easy cable management
Screw-less 5.25" and HDD trays that secures 2.5" SSD
Cooling capability of up to eight fans (2x 120mm and 1x 140mm LED fan included)
TimUK
Peopie
EVILNOK
Maximuscr31
ComradeNF
Happynuts420
Liquidzoo
BURNINGchicken3
Mr-Mechraven
Bryan Cooper 10
GREG MISO
Dark7721
Dnnk
Figit090
PoisonousRakija
fishymamba
sanjax94
cisys
greenscobie86
ervhamzz213
Rasemotte
victini91
untitled
danbaldwin
GoLDii3
AaronMa
Archangel117
ChrisTahoe
Kelso88
Fudsey
Bengal
Toader
clonzelda
Enjoymuff
Swerly Bob
XingSG
Sean332458
Jwolf24601
Dreyvius
Arizonian
Jaygel
Jraveendranath
Mushroomwig
Callumpy
Burgies
MatheusMoraes
AZNCELTICSFAN96
dark7721
Alakay
Wooojciech1983
BeattieGFC
b2much7
Herp123
Radmanhs
NV43
LReyes66
Pablidito
Phillyd
Greg Miso
Kev_b
CodFish
xV1ral
Chino1974
IT Diva
Jmcoe86
modnoob
MJSdanger
Pseudonymous
W-moffat
InsideJob
GrimGelo
MrDinoX
Gunmetal
GunMetal
Ranmier
Apropo
Burgies
Ipv89
matiasaznar
Phoriver
jrccomputer
Strileckifunk
Brizzol
byomes
FonTix
xamon0288
galacticgaggle
White/Blue
Phillipa KDick
4LC4PON3
iwalkwithedead
Keltik
Black/White
Johnbmb2011
EVOWolfe
Xata
Frozenoblivion
Black/Orange
DarthWilson
Brandy1332
mokmoki
SIG CODE
[CENTER]:clock:[URL=http://www.overclock.net/t/1204530/official-phantom-410-mid-tower-owners-club#post_16269491][b]Official NZXT Phantom 410 Owner's Club[/b][/URL]:clock:[/CENTER]
Thread Ownership changed to Chino1974 by ENTERPRISE 02/06/2013
Originally Posted by PureBlackFire View Post
That case is sexy in Red and Black.
its sexy in white too. it needs some optional accent panels too.
I agree with this guy, the white looks great on the phantom, but on the 410 it looks cheap and too colorful, with all the black and blue. The red and black though are sweet!
how does it look cheap? i have it and it looks great.
Originally Posted by Retell View Post
Thanks for the support guys
no, thank you!
Originally Posted by TimUK View Post
I think the white is the nicest, and by the looks of things so do NZXT as it's used for there promotion video.
It's also not going to show the dust as bad.
agreed.
btw updated
Here's a few pictures of mine:
700
400
450
700
where do u have the blue led fan?
btw nice work with the cables, but this case almost makes it too easy
Originally Posted by phillyd View Post
[/SPOILER]
Currently it's in the default place (at the top) but i might switch it with the front one. I'm getting some white light's for the inside soon and i think the blue wt the front might look better.
I'l experiment a bit.
And yea thanks, the cables are fairly easy to hide with this case. Lot's of room behind motherboard tray.
Today I went to Fry's and just happened to see a white 410 right next to the full size phantom in black and the 410 looked rather cheap because it was to compact for the curves and angles to work for it. I also did not like how the bay drive door opened because its not clearly marked or easy figure out unless you know the case. The psu fan filter was a joke being a sheet that was not able to slide out easily without turning the case on its side... I am glad they made a smaller case for people who don't have alot of room for a big case I just wish they would have done a little better job to live up to the standards of the full phantom.
Congrats to making a 410 club NZXT cases are awesome!
so the one legitimately possible issue with the case you pointed out is not something most people have noticed. I honestly have no care for fan filters
but yeah i love the full phantoms but ive seen the white mid and full side by side and i preferred the look of the 410's door
Its just me, i find any plastic in the color white cheap, unless it made from the really good stuff. Otherwise id say NZXT choose white, because its there most populer order. I might be wrong, nice case though, ill stick with the original.
i wish i could have a full tower special edition but i dnt want a full tower case sitting on the top of my desk
Having a hard time deciding what color I want to order. Leaning towards black because it is easiest to buy parts for and do mods on in my opinion.
The white is nice though and red would piss off my fiancee (jealousy).
I've got till I get back from my ski trip on Sunday to decide. Hopefully they go on sale somewhere and more people post pics of their systems between now and then to help me choose
i will probably have new pics of mine up by then.
the red one is nice but the plastic and metal dnt quite match:
You know, I thought the different hues of red would bother me, but they don't. Besides, it isn't nearly as extreme in person. The flash of the cameras tend to highlight the difference more. At some point I might paint some sort of design into the side panels anyways. I just have to come up with a good idea first.
