1521 - 1540 of 1540 Posts
Originally Posted by Nenkitsune View Post
the Roccat Isku keyboard has the standard capslock key function as the easyshift key (so you don't actually have a capslock key)
and yes, you could just assign all the easyshift stuff on the mouse to be the same as the standard layout.
the capslock thing took me a couple weeks to get used to. I'd try and hit capslock then realize that I assigned one of the thumb keys on the keyboard to be caps lock instead.
Oh, I see.
Surprised no one else has chimed in on the function here of Shift-Wheel.
In any case, thanks for your input!
I only discovered it because you mentioned it haha. Never noticed the option before so I tested it out to see what it was about.
Well, I also tried it out, and I'm not sure that's all it is. That's why I asked XD
Question, Can anyone help me with Macros for my Ryos MK & Tyon and connect everything via Talk?
PS:
How to create macro on X mouse button and press just once dedicated mouse button and command will execute
5x duck or something else?
Or if i press and hold button, it doesnt matter which way.. just want this loop or repeat.
I have problem with Roccat Tyon (it was causeing stuttering in every game and fps drop), can anyone here have this problem with this mouse? I will send it to warranty service but they will probably switch it for another Tyon. I think that Tyon joystik features in device manager was causing problems for me. When disabled stutter is still here but fps falls slowly.
Senior OCN Member
Anyone else that has problems with the left botton on their Roccat Kone XTD optical ?
I have had mine for a litte over a year and a half and my left click botton is having problem where sometime it does not respond at all and other times i double clicks even if i only click once
Dont know how many times i have used the left botton but i know its more then 4 million
How many is the XTD made for because i feel like i have worn mine out
A year and a half is not that long for a mouse and my older XTD laser also lasted less then two years
I was thinking about buying the newer Roccat Kone EMP but i dont really know anymore as i feel like Roccat quality is not all that great if you are going to use it every single day for hours on end
Maybe i should go back to Logitech again
By the way crazyg0od33 when is the last time you updated the owners list?
I no longer own a Roccat Isku FX keyboard.
Missing friends
No issues here
Missing friends
I can when I get home pm me to remind me
Missing friends
Np not home yet will peg you later tonight
Reactions: SmashTV
Senior OCN Member
My old Roccat Kone XTD Optical finally had its left mouse button die completely
Only had a little over 5 million clicks on it
Bought a Roccat Kone EMP to replace it.
Scientifical mystical one
Hey guys, I have a roccat KPM (been using it for about 2 years) and have noticed some issues with it. One, when I shutdown my computer and turn it on again, sometimes the mouse doesn’t work and I need to unplug and replug it in. Second, more annoyingly, the mouse will double click at times. Is there some new driver or firmware available that I need? I’m on Windows 10. Thanks everyone
RadeonMOD Author
How to make Autofire on Left Mouse Click? (I can do this on any other configurable button, but i need Autofire on left click)
Push-> Fire weapon, release Stop fire weapon -> That's it
Here is my two macros:
One is Autofire long, and second is 2x/3x Fire burst (depends on weapon, not Automatic but semi-Auto 1shot modello)
Tested today with BF1 (Medic & Assault - single shot weapons)
Make sure you'll have Profile keys Mirrored on SHIFT[+] Lock/Unlock Function and thats all
Yes it was that simple indeed, now we can wonder is Nyth really Best Mouse out there? YESSSS :D :D
How to make Autofire, Rapid Fire on Left Mouse Click with Roccat Nyth
