you can use fan xpert to change the fan speed. issue is you can't find easy way to make it work on windows 10.I recently got back a MVG and noticed that its CPU_FAN and CPU_OPT headers work only in PWM mode. Is that the case for everyone?
I can't tell if I had this problem when I bought the motherboard since I was running a PWM water pump, but now I have a 120x38mm DC fan which I'd like the motherboard to adjust the speed.
what i usually did , i go for newer maximus install the ai suit of it that works in windows 10
