UPDATE 6/5/2014
DON'T ABANDON YOUR X58 JUST YET!
i thought about getting a x79 or the new haswell, however i recently found out i didn't have to! i recently upgraded to the xeon x5650 hexacore and have seen significant result.
with a modest easy oc to 4ghz
and wallah! instant ivy bridge performance!
with the x5650 being 80-90 USD it is very affordable and far more economic compare to upgrading to a new platform.
if you own one or curious of buying one or just interested in general. post here! POST YOUR P6X58D BUILD TODAY WITH PICS!
during my stay on this forum i seen couple p6x58d posts here and there. really scattered and doubt anyone would find them all. so why not make it into a collective/informative thread. cheers!
WHERE TO BUY YOU ASK?
ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
Open Box: ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
New E revision.
http://www.newegg.com/Product/Produc...Tpk=p6x58d%20e
Whats the difference?
Originally Posted by Kitarist View Post
Thats it!!!
WOULD ENABLING SATA6+USB3 BOTTLENECK 16/16 CFX &SLI?
RAM NOT WORKING? OR ISN'T DISPLAYING THE CORRECT AMOUNT? READ BELOW.
WE HAVE A NEW SIG ~~ courtesy of Riskitall84
[/CODE]
and by popular demand...the E Sig
[/CODE]
Customer Choice Award1x Winner of Customer Choice Award - Intel Motherboards
owner list:date of entry not alphabetical ~ if you don't see yourself on this list please P'M me about it, i'll try my best to update this regularly.
Successfully Overclocked past 4GHZ!
00smurf~4.8ghz~975 extreme
DOM.~4.8ghz
ibew112~4.72ghz~980x
[AK]Blak-Hawk~4.51ghz
quentin~4.5ghz
xDelx~4.5ghz
techjesse~4.5ghz w/ht disabled.
Jt~4.4ghz~975 extreme
cccdjb~4.4ghz
capt_zman~4.4ghz
zamdam~4.4ghz @ 1.45v
christrodr~4.3ghz
superj1977~4.3ghz
[email protected]~ I7 950 @4.3ghz
gibsonnova74~ I7 950 @4.2ghz
reficul~4.2ghz
BlueFox~4.2ghz
bunzrok~4.2ghz
Captain Zman~4.2ghz
craptastic7~4.2ghz
wikidboo~4.2ghz
Lrs3329~4.2ghz
HomeTeam4.2ghz
EaglePC4.2ghz
~LL~ 4.2ghz
maximus7651000~4.2ghz
Shozzking~4.2ghz
kzinti1~4.2ghz
xmisery~4.2ghz with Low Stable voltage
Kckyle~4.1ghz
BranFB~4.1gh ~HT
tvick47~4.01ghz
IEATFISH~4.0ghz
sidcitris~4.0ghz
jjeffreys~4.0ghz
CULLEN~4.4ghz
AutoItKing~4.23ghz
Myrlin~4.2ghz
luke997~4.2ghz
Revy106~4.2ghz
|Nexus|~4.2ghz wHT
slidez~4.2ghz
WhiteDog~4.2ghz w/ht
Myrlin~4.2ghz
mrasstits~4.2ghz
TheSwami~4.2ghz
Arclite~4.2ghz
sarsonm~4.1ghz @1.2v~ cool as ice
FuriousReload~4.0ghz
arking~4ghz
perkeo~4.2ghz
d0rkb0y~4.0ghz
Dirtydeedz~4.0ghz
lux~4.0ghz
whoisron~4.0ghz
paco1~4.0ghz
raul602~4.0ghz
goldtreasure~4.0ghz
dullboi~4.0ghz
krescent~4.0ghz
lawrencendlw~4.0ghz
thisischuck01~4.01ghz~HT on
rent.a.john4.0ghz
brent1118~4.0ghz
ceilingfan~4.0ghz
mothug~4.0ghz
SeanWebster~4.0ghz
ASUS does it again with the P6X58D motherboard!
The P6X58D motherboard provides you a host of new features and the latest technologies. It supports Core i7 (LGA1366) and delivers better overclocking capabilities with less power consumption. It features Triple channel DDR3 2000(O.C.)/1333/1066 memory support and breaks the boundaries to bring you the multi-GPU choice of either SLI or CrossFireX. In addition, TurboV helps you to overclock easily without the need of experience!
ASUS is an industry leader known for making innovative and reliable motherboards. Bring home the experience and craftsmanship of ASUS and build your next system in confidence today!
a little OC tip from our very own xmisery
New E revision.
P6X58D-E has Marvell® 9128 While P6X58D Premium has Marvell® 9123 Controller. (It means the E version has a better controller and supports RAID better)
P6X58D-E also has better VIA® VT6308P controller while the P6X58D Premium has VIA® VT6308 (IEEE 1394)
P6X58D-E Only has 1 Gigabit LAN controller Marvell 88E8056® While P6X58D Premium has 2.
P6X58D-E doesnt have the RESET button on the motherboard while the P6X58D Premium has, but both have the POWER and MEMOK buttons.
P6X58D-E also doesnt come with 1 x Optional Fan for water-cooling or passive-cooling while P6X58D Premium does.
"The Premium has 2 additonal heatpipes for cooling (1 to the Southbridge and 1 above the Northbridge) whereas the E version does not have this."
I hope this will answer some questions to some people who want to know what are the differences between those two motherboards.
Originally Posted by cyclone3d ![]() The Premium has one more LAN port than the E. The E supports RAID on the SATA 6Gb controller while the Premium does not. |
Thats it!!!
Originally Posted by 2010rig ![]() Is it true that if we want to go SLI with the P6X58D-E, that we NEED to disable USB 3.0, AND SATA 3 in order for the PCI-E lanes to both run at 16x? |
Originally Posted by xmisery source ================================================== ============= This thread is a basic troubleshooting guide users who have memory detection issues. For example the motherboard is only detecting 4 GBs instead of 6 GBs or 8 GBs instead of 12GBs. This issue is fairly common on Intel X58 based systems and affects all brands of motherboards. X58 is Intel's first platform with the memory controller built into the CPU. Good contact between the CPU and the socket pins is very important and bad contact is usually the cause of "missing" memory as well as other causes listed here: Poorly fitted CPU cooler ( too much tension, not enough tension, uneven tension) Fix: Adjust tension of aftermarket cooler, Test with stock cooler, reseat CPU and cooler. *Most people fix the problem just by reseating the cpu and cooler* Bent CPU socket pins. (damaged board, poor installation, poor cooler tension, uneven pressure etc) Fix: Inspect CPU socket for bent pins, some users have been able to straighten the bent pins and solve the problem. Otherwise if its too badly damaged you might need to RMA the board. (Note: Asus might refuse RMA if bent pins were caused by user) Faulty ram Fix: Test each stick individually( in slot A1) to see if it boots. Run memtest. Test with another memory kit if possible. Insufficient voltage Fix: Set "Dram bus voltage" to 1.64v (or whatever your memory spec says) and set QPI/Dram voltage to max 1.35v (Max 1.35v is recommended for users with 12 Gigs and/or running at speeds of 1600Mhz or higher. If running under 1600Mhz with 6 Gigs you may only need 1.25v QPI/Dram voltage. Another option is to set XMP profile in the bios. Wrong windows version: Fix: Some new builders are unaware of limitations using 32 bit Windows. Windows 32 bit can only recognize and address under 4 GBs of system memory. Install 64 bit version of windows. Short Circuit: (with some aftermarket coolers/cases) Fix: The backplate of some aftermarket coolers touch the motherboard tray causing a short circuit. Test with stock cooler or make adjustments. Faulty motherboard Fix: Least likely cause but if all other fixes have been tried RMA the motherboard Some notes for people using 12 Gigs of memory. 12 Gigs of memory is only supported at 800-1333Mhz. Some users can run 1600Mhz successfully with some voltage tweaking but 1333Mhz is the max supported speed using 12 gigs. I hope that helps. If anyone wants me to add something let me know. ================================================== ============= |
Originally Posted by xmisery ![]() ================================================== P6X58D Premium BIOS Update Changelog ================================================== Description P6X58D Premium BIOS [1002] - Released (2010/09/10) - Improve system stability Description P6X58D Premium BIOS [0904] - Released (2010/08/27) - Added Marvell 9120 support and updated option ROM to v1.0.0.1025 - Fixed CrashFree function failed in BIOS 0903 - Improve system stability Description P6X58D Premium BIOS [0813] - Released (2010/06/22) - Support IXTU (Intel Extreme Tuning Utility) Description P6X58D Premium BIOS [0808] - Released (2010/04/20) - Improve memory compatibility Description P6X58D Premium BIOS [0703] - Released (2010/02/25) - Improve system stability - Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us Description P6X58D Premium BIOS [0604] - Released (2010/01/29) - Fix DRAM Voltage is abnormal in TurboV Description P6X58D Premium BIOS [0506] - Released (2010/01/11) - Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us Description P6X58D Premium BIOS [0402] - Released (2009/12/01) - Enhance OC Profile storage space from 2 to 8 slots. - Enable instant display of Target CPU & DRAM Frequency under Ai Tweaker Description P6X58D Premium BIOS [0301] - Released (First) ================================================== ================================================== P6X58D-E Xtreme BIOS Update Changelog ================================================== Description P6X58D-E Xtreme BIOS [0303] - Released (2010/06/08) - Improve memory compatibility - Improve system stability - Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us Description P6X58D-E Xtreme BIOS [0204] - Released (2010/04/13) Description P6X58D-E Xtreme BIOS [0108] - Released (First) ================================================== |
Originally Posted by Riskitall84 ![]() ![]() Alex |
[CODE] [CENTER][URL="http://www.overclock.net/intel-motherboards/662236-asus-p6x58d-premium-thread.html"]:clock:[B]--[/B] [B]The Asus P6X58D Premium Thread[/B] [B]--[/B]:clock:[/URL][/CENTER]
[CODE] [CENTER][URL="http://www.overclock.net/intel-motherboards/662236-asus-p6x58d-premium-thread.html"]:clock:[B]--[/B] [B]The Asus P6X58D -E Thread[/B] [B]--[/B]:clock:[/URL][/CENTER]
kckyle~ admin
xmisery ~ OC Guru
reficul
IEATFISH~ forum mod
tvick47
OutlawII
Bearlout
JimW
Sno
sora1607
maximus7651000
wikidboo
bunzrok
fallen again
Ghoxt
pfran42
Mniceguy
Pheros
Captain Zman
00Smurf~extreme 975E
BlueFox
Hfire3
craptastic7
M3T4LM4N222
Riskitall84
Jtvd78
~LL~
mike.dp.05
Grindhouse
cccdjb
Jt705~ 975 extreme
kboom1~ 960 extreme
ekovalsky
Ew1029
blackdragon24
Lrs3329
HomeTeam
EaglePC
sidcitris
Aetro
DOM.
T2HWSSPDCO
jjeffreys
CULLEN
AK_Zeke
Necrosys
c0stantine666
hollywood406
JamezMcQueen
TheSwami
Mr.Mike
luke997
Revy106
|Nexus|
DocJohn
slidez
NemesisCavalry
Dirtydeedz
Myrlin
theshadow1234
buffalofloyd
quentin
whoisron
TheSwami
Arclite
Jamos169
nateobot
AK_Zeke
capt_zman
sarsonm
zamdam
b0klau
FuriousReload
arking
perkeo
Gormak
paleblue
d0rkb0y
Dirtydeedz
darith
daskog
lux
whoisron
paco1
raul602
goldtreasure
Tad
wontonforevuh
techjesse
dullboi
rattlerskin
Cyberman
faraz1729
lemo
Zudeo
tarnumf
mgutz
CPT Ethanolic
Sast
R1_Cowboy
samuel002
YaGit™
Shiggity
goonar
xDelx
krescent
Atlasprime
SandHammer
Cuar
dead_buzzard
rattlerskin
broken pixel
samuel002
Fantomau
~sizzzle~
ibew112
xBlitzerx
BranFB
[AK]Blak-Hawk
ridge7064
lawrencendlw
thisischuck01
_Chimera
elricm
EasterEEL
B2K24
cyclone3d
ChadVader
Shozzking
Gorn~980x
kzinti1
gavindoc
phillydee
rent.a.john
dantoyang
Nakattk
Azone42
TheLastPriest
Cisco99
Richard Eckert
ata786rz
ibew112~980x
Westie69
teh1buck
Jangle
sti-06
personaobscura
Bandeezee
Yangtastic
J-Diddy
pzyko80
Enphenate
brent1118
ceilingfan
mothug
shingurai
WhiteDog
mrasstits
gibsonnova74~forum mod
AutoItKing
christrodr
superj1977
SeanWebster
ski-bum
warfox101
pangeltveit
Nakattk
[email protected]
Colt
desent
denydog
guitarisawesome
PC Gamer
shinigamibob
cheater1
Tex1954
jmaz87
aicha
TurboTronix
dank2hydro
pangeltveit
ski-bum
joe pineapples
EasterEEL
EasterEEE
c_loke
jahworks
Jokah
HanmaT
niclope420
[email protected]
Droogie
ROM3000
Eviang
Cykososhull
mechavore884
steadly2004
goesto11
KeyBoard_Ninja
Jmaz87
xodsxboi215x
Ski-bum
DaveLT
gre0481
xmisery ~ OC Guru
reficul
IEATFISH~ forum mod
tvick47
OutlawII
Bearlout
JimW
Sno
sora1607
maximus7651000
wikidboo
bunzrok
fallen again
Ghoxt
pfran42
Mniceguy
Pheros
Captain Zman
BlueFox
Hfire3
craptastic7
M3T4LM4N222
Riskitall84
Jtvd78
~LL~
mike.dp.05
Grindhouse
cccdjb
Jt705~ 975 extreme
kboom1~ 960 extreme
ekovalsky
Ew1029
blackdragon24
Lrs3329
HomeTeam
EaglePC
sidcitris
Aetro
DOM.
T2HWSSPDCO
jjeffreys
CULLEN
AK_Zeke
Necrosys
c0stantine666
hollywood406
JamezMcQueen
TheSwami
Mr.Mike
luke997
Revy106
|Nexus|
DocJohn
slidez
NemesisCavalry
Dirtydeedz
Myrlin
theshadow1234
buffalofloyd
quentin
whoisron
TheSwami
Arclite
Jamos169
nateobot
AK_Zeke
capt_zman
sarsonm
zamdam
b0klau
FuriousReload
arking
perkeo
Gormak
paleblue
d0rkb0y
Dirtydeedz
darith
daskog
lux
whoisron
paco1
raul602
goldtreasure
Tad
wontonforevuh
techjesse
dullboi
rattlerskin
Cyberman
faraz1729
lemo
Zudeo
tarnumf
mgutz
CPT Ethanolic
Sast
R1_Cowboy
samuel002
YaGit™
Shiggity
goonar
xDelx
krescent
Atlasprime
SandHammer
Cuar
dead_buzzard
rattlerskin
broken pixel
samuel002
Fantomau
~sizzzle~
ibew112
xBlitzerx
BranFB
[AK]Blak-Hawk
ridge7064
lawrencendlw
thisischuck01
_Chimera
elricm
EasterEEL
B2K24
cyclone3d
ChadVader
Shozzking
Gorn~980x
kzinti1
gavindoc
phillydee
rent.a.john
dantoyang
Nakattk
Azone42
TheLastPriest
Cisco99
Richard Eckert
ata786rz
ibew112~980x
Westie69
teh1buck
Jangle
sti-06
personaobscura
Bandeezee
Yangtastic
J-Diddy
pzyko80
Enphenate
brent1118
ceilingfan
mothug
shingurai
WhiteDog
mrasstits
AutoItKing
christrodr
superj1977
SeanWebster
ski-bum
warfox101
pangeltveit
Nakattk
[email protected]
Colt
desent
denydog
guitarisawesome
PC Gamer
shinigamibob
cheater1
Tex1954
jmaz87
aicha
TurboTronix
dank2hydro
pangeltveit
ski-bum
joe pineapples
EasterEEL
EasterEEE
c_loke
jahworks
Jokah
HanmaT
niclope420
[email protected]
Droogie
ROM3000
Eviang
Cykososhull
mechavore884
steadly2004
goesto11
KeyBoard_Ninja
Jmaz87
xodsxboi215x
Ski-bum
DaveLT
gre0481
DOM.~4.8ghz
quentin~4.5ghz
xDelx~4.5ghz
cccdjb~4.4ghz
capt_zman~4.4ghz
christrodr~4.3ghz
superj1977~4.3ghz
reficul~4.2ghz
BlueFox~4.2ghz
bunzrok~4.2ghz
Captain Zman~4.2ghz
craptastic7~4.2ghz
wikidboo~4.2ghz
Lrs3329~4.2ghz
HomeTeam4.2ghz
EaglePC4.2ghz
~LL~ 4.2ghz
Shozzking~4.2ghz
kzinti1~4.2ghz
Kckyle~4.1ghz
BranFB~4.1gh ~HT
tvick47~4.01ghz
IEATFISH~4.0ghz
sidcitris~4.0ghz
jjeffreys~4.0ghz
CULLEN~4.4ghz
AutoItKing~4.23ghz
Myrlin~4.2ghz
luke997~4.2ghz
Revy106~4.2ghz
|Nexus|~4.2ghz wHT
slidez~4.2ghz
Myrlin~4.2ghz
mrasstits~4.2ghz
TheSwami~4.2ghz
Arclite~4.2ghz
arking~4ghz
perkeo~4.2ghz
d0rkb0y~4.0ghz
Dirtydeedz~4.0ghz
lux~4.0ghz
whoisron~4.0ghz
paco1~4.0ghz
raul602~4.0ghz
goldtreasure~4.0ghz
dullboi~4.0ghz
krescent~4.0ghz
lawrencendlw~4.0ghz
rent.a.john4.0ghz
brent1118~4.0ghz
ceilingfan~4.0ghz
mothug~4.0ghz
SeanWebster~4.0ghz
