I found some weird thing about the CPU PLL when I was testing last night.
My CPU temp goes UP when I make the CPU PLL LOWER than 1.832.
It passes the test (used quick LinX w/AVX all ram) fine with 1.750.
But it gives me 3c higher in temp.
I though I was doing something wrong so I went back to 1.832 and test it and did the 1.750 again.
But the results were the same. (I tested it 3 times back and forth)
1.832 runs cooler than 1.750.
Weird but that is what I got and also I get better score at 1.832 (133+GFlops) opposed to 1.750 (131~2GFlops).
Someone should try this and see if it does to you, too...
