1 - 20 of 3,838 Posts
Discussion starter · #1 · (Edited)
Post Heaven Benchmark 4.0 scores here.
To keep everyone using the same settings, Please use the following settings with a DX11 capable card:
4.0 Settings
All scores must have data line in order to be considered for the Top 30:
Member Name --- Processor / Speed ---- GPU Name and # ---- FPS ---- Score
Please provide a screen shot that displays the score with the stone walkway displayed to confirm that Tessellation is turned on for score verification.
Use F12 while the Rock Walkway and Score Panel are showing and convert the tga file with the free software below. Like so:
Any score that is posted that does not follow the settings above or does not have the correct screen shot will not be counted.
In order to be in the Top 30 Chart, you must beat the score in the position 30 slot. All other scores will appear in the General Score Charts.
Driver Modifications:
Any setting or tweak that substantively alters the tessellation effect of the Rock Walkway in your screen shot is disallowed.
Basic NVCP and AMD CCC tweaks such as "High Performance Mode" single monitor, etc are allowed, so long as the screenshot conforms to visual inspection.
NOTE: Disabling SLI or CFX is insufficient when claiming a lower GPU count for a score. Eg, for a single card run, all other graphics cards,including the iGPU must be switched off (not detected by Unigine)
Display of the Spreadsheet has been disabled under the new forum format.
PLEASE click the link below to see a read-only updated Heaven 4.0 Top 30
Heaven Top 30
or:
https://drive.google.com/open?id=1d5ZpydfFuJ77ZZPtofuiwl-eJkbM60oGyfSEDMPlVPQ
Heaven DX11 Download link: http://unigine.com/products/heaven/download
tga to jpeg: tga2jpg.zip 1118k .zip file
Heaven 4.0 Benchmark High Resolution Submissions
Same general requirements as above: screenshot w/ rock walkway, dataline (ocnname --- cpu@GHz --- GPU(s) ---- FPS --- Score)...
For 1440P: 8x AA _________________For 4K (3840x2160): 2x AA
Please note the settings above and make sure your runs are configured correctly.
Each user can have only one entry in the overall Top 30: Your best score which is > than the score in position 30 at the time the entry is made.
tsm106 --- i7 2600K / 5.2GHz ---- Trifire 7970, 1300 / 1725 ---- 178.8 ---- 4505
375
There's some room in the tank still. Can run a wee bit more clock, 5.3 and 1320/1750 but temps are high today. Another day so it seems...
375
Icehotshot --- i5 2500K / 4.5GHz ---- Nvidia gtx 570, 915 / 1830 / 2050 ---- 39.9 ---- 1005
Hopefully when I get this gpu water cooled I can do some 1ghz runs with it.
only 6970s but count me in
Blindsay --- 2700k / 4.6GHz ---- 2x 6970, 925/ stock / 1425 ---- 60.4---- 1521
2gb of ram, really? I'd probably run out of memory if I tried to open paint with that..lol get at least 4gb or 8gb. Any good game these days will want to chew up at least 4gb of ram so get 8gb.
Yea, I'd get a new CPU. Can't hurt. Sandy bridge i5-2500k would help a ton.
Originally Posted by vedaire View Post
vedaire --- fx-8150 / 3.6Ghz ---- HD7970 925/1375 ---- 84.6fps ---- 2130
wow, that is a high score for a single HD7970 at default clocks ?
i see now it is CrossfireX
