Hey there.
I've been utterly pissed lately about this very expensive motherboard I bought (the Rampage IV Extreme).
Here's my problem. I have tested my CPU (i7-3930K) to be ROCK stable at 1.185vcore using 38 multiplier.
So now I wanted to use offset voltage like I did on my P8Z68-V Pro I had before.
So I go in and set it to 'Offset' and use minus '-' and I set it at -0.100. Save and exit.
Nothing happens, just black screen, no posting but my pc is running and nothing happens until I reboot it and it says "overclocking failed press f1 to enter setup". I do it again and again.. same thing happens.
Now I try with -0.040 and it boots directly into Windows 7 no problem! However, the voltage is quite high (1.245) and not my desired 1.185v.
So I try again, restart and boot into bios. Change offset to -0.100 and save & exit. Nothing, same as before. No posting, black screen, but the pc is running.
I try every combination of offset value, LLC (Regular, Medium, High) and phase change from Standard to Optimized and even Auto..
So I reset my bios and tried using just offset setting it to -0.100v and I could boot!. My RAM here is default 1333MHz. Now I went in again and just changed RAM speed to 2133MHz and saved.
NOTHING! Black screen, PC running.
What's up with that? I tried both XMP profile and setting it manually.
I can run rock stable using manual voltage and 2133MHz ram.
My theory is that using CPU offset voltage somehow offsets my RAM voltage aswell and makes them not boot or something? But I have no way to see that.
My specs:
Intel Core i7-3930K
Noctua NH-D14 SE2011
Asus Rampage IV Extreme
Corsair Dominator-GT 32GB DDR3 2133MHz (8x4)
MSI N580GTX Lightning
Corsair Professional Series Gold AX850
Samsung 830 Series 256GB SSD
My specs:
Intel Core i7-3930K
