Oh, Crap...Help
408 8
I did something incredibly stupid. I accidentally set res settings too high in F.E.A.R. and now my monitor won;t display it. Does anyone know of any way to reset defaults without uninstalling game?
Status
Not open for further replies.
1 - 9 of 9 Posts
You should be able to change the res of the game in one of the .ini or a configuration files of the game usually found in the system folder or equilvent for different games. I dont have the game so i dont know exactily where to find the file(s)
Old Timer
Originally Posted by HardwaterH4ck3r
the thing is.......
it's bootleg.
I will pertend I didnt here that and try and help you out.
I had that happen to me in BF2 one time and what I had to do was find the configuration file (which I opened in notepad) and set the default res from 1600x1200 back down to 1280x1024. I dont know were it is in F.E.A.R., but look about for it. Keep clicking on files untill you find something that looks good.
C:\\Documents and Settings\\All Users\\Documents\\Monolith Productions\\FEAR\\settings.cfg
delete it or edit "ScreenWidth" and "ScreenHeight" in notepad
Hope you got what you needed, because since this is admittedly a bootlegged copy, this conversation is over...
1 - 9 of 9 Posts
Status
